Old Nov 03, 2005, 03:33 PM
alexcmag is offline
Find More Posts by alexcmag
alexcmag's Avatar
Sao Paulo, Brasil
Joined Aug 2004
Beech 18 (twin) - Oi Squadron
Last Oct 23 we made a electric flight demonstration on an air show (Aviator Day in Brazil).
I recently made two multiple engine models (50in Canadair CL215, 120in MartinMars), but both are high wing bomber waterplanes.
One of the demonstrations of air show was "Oi squadron", a aerobatics squadron with three AT-6 Texan and on Beechcraft E-18. The Beech flies some basic aerobatics and deploy parachutes.
Some days ago a friend seeking for TwinStar info found a picture with cargo bay deployng parachutes and suggest me to make this mod on MartinMars, but it is not the rule of MartinMars.
So I remembered the Beech 18 from "Oi squadron" and decided to make it, 1/10 scale:
Some data about this model: http://membres.lycos.fr/wings2/d18/d18.htm
It will be:
Wingpan: 1.5m (60in)
Avg. chord: 22cm
Length: 1.04m (41in)
Wing area: 32.4 sq.dm.
If final weight fits around 900g (32oz), it will have a 27g/sq dm of wing load, enough to make a scale flight, with stall speed of 13kts (without flaps), cruise speed at 21kts (10% of the full-size airplane, will give the same speed feeling when flying). The max speed with full power will be greater then the full scale top speed, but it is not trouble since I can decide what kind of flight I want.
With 2 GWS 400 motors geared 3:1 with 10x6 props the prop will be on scale too (no need to increase landing gear size) and with 3S LiPo thrust will be greater then weight with good pitch-speed, enough to carry 300g (11oz) of payload without trouble.
Estimated weights:
Wing: 250g
Fuselage: 250g
Motors: 180g
Battery: 150g
Receiver: 10g
ESC: 10g
3 servos: 30g
Linkings: 20g
Total: 900g
In fact this airplane is great for a R/C model.
The fuselage is almost a box, only rounded on nose and top, very easy to make.
Stab area is excelent (25% of wing area) with 40% of elevator.
Dual vertical fin has a good area too and good deflection of rudder.
The Aileron and flaps are on a line, so I can make a full-wing aileron without going out of scale.
Landing gear is short and near leading edge of wing, same place I usually place my landing gears.
Wing has a good area, low aspect ratio and a good dihedral, perfect for R/C. Newer versions (E18 and later) have an extension of leading edge on tips for washout.
The only not perfect part is the low wing, where I will need to place the cargo bay, but with 12 inches of root chord and 6 inches of fuselage width, making a door big enough to deploy parachites will not make it weak.
alexcmag is offline Find More Posts by alexcmag
Old Nov 03, 2005, 03:55 PM
alexcmag is offline
alexcmag's Avatar
Sao Paulo, Brasil
Joined Aug 2004
More pictures:
Old Nov 03, 2005, 08:35 PM
temacc is offline
Find More Posts by temacc
H2OFLY
Portland Oregon USA
Joined Feb 2000
GREAT looking airplane with that more pointed nose, and Super paint job!
Terry
temacc is offline Find More Posts by temacc
Old Nov 04, 2005, 05:20 AM
alexcmag is offline
alexcmag's Avatar
Sao Paulo, Brasil
Joined Aug 2004
Thanks. I hope the foam model can look close to this painting, but will not be perfect, of course.
Yesterday I printed the side and top view and used as template to cut side walls on 13mm (1/2 in) inexpensive white EPS foam, I will try to cut top panel and mount the fuselage tonight.
I forgot to say before, but this projects have some goals:
- Must be cheap (less then $10 of foam)
- Must be fast to build
- Must carry payload
Old Jan 22, 2006, 01:16 PM
temacc is offline
H2OFLY
Portland Oregon USA
Joined Feb 2000
Looking Good!
Terry
Old Jan 22, 2006, 02:26 PM
alexcmag is offline
alexcmag's Avatar
Sao Paulo, Brasil
Joined Aug 2004
Originally Posted by Terry
Looking Good!
Terry
Thanks.
Test flight will be on next saturday.
Long term build along: Beech 18 at 20% SheldonYoung Scale Kit/Scratch Built 54 Jun 09, 2011 09:29 PM
Retracts for Tom Hunt's Beech 18 astroboy Electric Plane Talk 8 Aug 05, 2010 04:19 AM
K&A Twin Beech 18...anyone got one? David Hogue Scale Kit/Scratch Built 12 Jan 05, 2006 12:48 AM
Beech 18-Who does this kit???? CESARNOGUEIRA Scale Kit/Scratch Built 6 Dec 18, 2001 12:55 AM
Cool Yellow Aircraft F-18 Twin EDF GregG Electric Ducted Fan Jet Talk 39 Jul 18, 2001 01:21 PM
