Old Nov 03, 2005, 03:43 AM
Freddy Bear is offline
Find More Posts by Freddy Bear
Freddy Bear's Avatar
Hobart Tasmania
Joined Aug 2005
Help!
lost my glider
I managed to loose my glider to a hungry sea the other day. I think the receiver stopped listening to my commands (battery died) I was on the third flight, about three minutes in, on a five-minute engine run, at about five hundred feet. Not a good place to be free flying with a RC glider. I jumped in the car and headed off in hot pursuit.
The engine had died but it was gliding in a large circle over a large expanse of salt water. It was then I thought that was the last I’ll see of that. This had not been a good morning.
In the afternoon about four o’clock I received a phone call “have you lost a glider” I was delighted. A chap named Glen had been driving along and spotted the plane in the shallows from a bridge. He took the glider home and washed out the sand and salt water in his bath. We arranged a meeting place and after handing him a reward a chat and hand shake we parted company. The glider was home again with very little damage before the sun had set. After cleaning and drying the receiver and connecting it up, all was working fine.
I’m working on trying to see if my receiver can operate on six-volts.
Maybe someone will know, or be able to put me in touch with someone who does. [/
The RX is a
CHALLENGER 720
DBM & X-TAL FILTER
HP-7RM36F
FM
Duel Conversion Narrow Band Receiver.
Will this run on six-volts?
If you have some info could you please PM me
TX
I run a FIELD FORCE 7 FUTABA
FP-T7UAPS
PCM-PPM SELECTABLE
[IMG]
The Reason I wanted to get the six-volt pack was to give me a greater margin of battery safety for high altitude.
I know from experience that it is not good to fly on low batteries but it is difficult to predetermine capacity with nicads because of the sudden drop at the end of their life.
When the batteries were new (and even then you might get a dud) you had some idea of their longevity.
On some days I would fly for Four hours driving seven servos and still have plenty over at the end of the day.
The batteries I used were old ones but I have a discharger that told me the batteries were good.
Maybe time to get a better discharger one with an amp meter built in or something.
The other thing I thought of was to double up that way if one pack drops the other would take over.
A little extra to carry will only speed the glider a little
Freddy Bear is offline Find More Posts by Freddy Bear
Old Nov 03, 2005, 07:24 AM
DFW_HLG_TG is offline
Find More Posts by DFW_HLG_TG
DrCarter
Princeton, TX
Joined Jan 2005
I was looking into using a 5 cell pack awhile back. From what I understand it will use more current and you have to watch the battery just as close. Are you using 1 or 2 packs? I would try to have a separtate pack on the radio gear. Also, If the pack is new, you will need tho cycle it a few times before it will reach 100%. I have had new battries put out only 30% the first time charged.
DFW_HLG_TG is offline Find More Posts by DFW_HLG_TG
Old Nov 03, 2005, 07:39 AM
MTT is offline
MTT
Find More Posts by MTT
MTT
I care about rising air !
MTT's Avatar
United States, OH, Norwood
Joined Feb 2002
Why do you want to use a 6V pack ?
5 cell ( 6V ) packs are used on very large models, where the voltage drop along long servo leads could be an issue, and by folks who fly aerobatics, and want very quick and crisp response.
For you plane ( looks to me like something in the 2-3m span range ) a 5cell pack would be absolute overkill.
Anyway, the way I understand it, you want ot go to the 5cell pack for increased capacity ?
You don't need 5 cells, just buy a new good quality 4 cell pack, and you will be fine.
Michael
MTT is offline Find More Posts by MTT
Old Nov 03, 2005, 09:51 AM
MikeBanyai is offline
Find More Posts by MikeBanyai
Petoskey, Michigan 49770
Joined Aug 2001
WalMart has rechargeable 2500 MAh NMH for about 10 bucks for 4 if I recall right. You can make up a pack and never be in the drink again due to batteries. This assumes of course that you have a way to charge and moniter them. The typical wall charger that comes with your radio only puts out 60 milliamps so will take 2400/60= 40 hrs to charge and even then may not do the job compleatly. Hobbico has a fifty buck field charger that can charge radio and reciever batts at the same time...good luck
MikeBanyai is offline Find More Posts by MikeBanyai
Old Nov 03, 2005, 09:57 AM
SoCalGliderFlyr is offline
Find More Posts by SoCalGliderFlyr
Think Thermals!!!!
SoCalGliderFlyr's Avatar
Costa Mesa, California
Joined Mar 2004
They have WalMarts in Tasmania?
Fred, Where do you buy from? Mail order?
SoCalGliderFlyr is offline Find More Posts by SoCalGliderFlyr
Old Nov 03, 2005, 10:11 AM
Joined Aug 2001
Sorry, I didn't catch the Tasmania reference, The concept of useing 2400 MAH NmH vs 600 MAh NiCAds still applies...warmest regards,
Old Nov 03, 2005, 11:04 AM
Think Thermals!!!!
Joined Mar 2004
I like the 2400's too. On my way to Walmart this afternoon! Hope this doesn't upset Fred. Maybe we can send him RC Care Packages!!!
What do I charge them with? Time and rate?
Old Nov 03, 2005, 07:51 PM
Hobart Tasmania
Joined Aug 2005
I usually buy locally at a place that has a larger turn over of stock but this doesn’t mean that you buy quality. Maybe I need to get some sanyo.
But budget dictates what is used.
[IMG][IMG][/IMG]
Old Nov 04, 2005, 08:08 AM
FLYRCM is offline
Find More Posts by FLYRCM
Joined Oct 2005
Radio ditch into the sea
Our club used to fly in Hong Kong right next to the harbour. From time to time, someone's aeroplane lost control and ditched into the harbour (salt water) . The first thing we did when we picked up the plane was to disconnect the battery & dumped the whole radio into fresh water. We rinsed it a few time and let it sit dry.
The crucial part is to disconnet the battery ASAP or in your case, no more power running through the electroncis. The power in the battery will corrode the electonics component away. Just like the electrolysis experiment you done in science project at school.
Dumping the whole airborne unit in fresh water will save the unit most of the time unless the unit has been sitting in salt water with power to it for a prolong period of time.
FLYRCM is offline Find More Posts by FLYRCM
Old Nov 04, 2005, 09:04 AM
2motheus is offline
Find More Posts by 2motheus
3 Sons - Legos and Lift
2motheus's Avatar
Grand Rapids, MI
Joined Apr 2004
I've also heard that dunking things in alcohol helps get water out. But I'm not sure what that might do to the light lubricants in the servo mechanics.
2motheus is offline Find More Posts by 2motheus
Old Nov 05, 2005, 06:00 AM
Hobart Tasmania
Joined Aug 2005
The water didn't get into the servos I think the lubricant kept the water out.
Old Nov 05, 2005, 09:42 PM
Hobart Tasmania
Joined Aug 2005
HI Socialgliderflyr,
The charger I have tells me nothing except RED LIGHT ON when charging. I do my tests with a multitester and a discharger I built. When the batteries drop there voltage a relay drops out and charging begins.
I am also doing some tests with a square wave driver at twelve volts. This has a pot to lengthen or shorten the DC pulse at 50Hz.
I have found that you can rejuvenate nicads and get them working again.
Old Nov 10, 2005, 04:32 AM
Hobart Tasmania
Joined Aug 2005
Michael
Thanks Michael,
I know it is probably too much putting a five-cell pack in the glider so I’ll get a new set of Nicads.
??? What is the advantage of Ni-MH over Nicads and what is the best way to charge both in the field.
I go camping and there is no power to use the standard charger.
My son has a fast nicads charger for his cars with a timer and I have an identical charger that I could alter. Would this charger be any good to charge Ni-MH with a small modification????
Old Nov 10, 2005, 07:28 AM
MTT is offline
MTT
MTT
MTT's Avatar
Joined Feb 2002
I don't know enough about chargers and the different types of batteries to answer those questions.
For charging in the field, there are lots of chargers available, which run off a 12V car battery, and do a good job.
For my NiCd's I use a FMA direct SuperNova ==> SuperNova , and an Astroflight 110D ==> Astroflight 110D.
For my LiPo's I use a Schulze isl 6-330d ==> Schulze 6-330d
All of these run on 12 V DC , to use them at home n the shop, you will need a 12 V power supply, or a car battery, but then that's another battery to worry about...
Michael
Old Nov 16, 2005, 09:54 PM
histarter is offline
Find More Posts by histarter
Permanently Banned
Dallas TX
Ugh, Raise voltage with 5 cells and circulating current increases! This translates to reducing run time. [Wrong way to go]
Primative.
histarter is offline Find More Posts by histarter
Lost my Pibros! rkrishnan Beginner Training Area (Aircraft-Electric) 4 Aug 01, 2001 11:08 AM
lost my plane today bronco Electric Plane Talk 17 Jun 28, 2001 12:56 AM
Lost my A/B sailplane today Andy W Electric Plane Talk 19 May 25, 2001 12:56 AM
I lost my c/f 280 Lightstik slowflyer Parkflyers 15 May 05, 2001 11:35 PM
Ive lost my mind! Need help quick! JEWINE Beginner Training Area (Aircraft-Electric) 8 May 05, 2001 08:46 AM
