Old Nov 02, 2005, 10:29 AM
pulquijet is offline
Find More Posts by pulquijet
Argentina
Joined Aug 2003
Pusher motor help needed
Hi : I am very new at electric planes.
Need to fit a brushed motor in a pusher configuration.
Without a pusher prop,how I have to do?
Thank in advance for your help.
Regards,
pulquijet is offline Find More Posts by pulquijet
Old Nov 02, 2005, 11:27 AM
BeavrdamElectric is offline
Find More Posts by BeavrdamElectric
Beaverdam Creek, VA
Joined Aug 2005
What kind of motor are you using? Some have neutral timing and run the same either direction. Others will see a small performance drop running opposite to their design. On some the timing is adjustable.
Good Luck!
BeavrdamElectric is offline Find More Posts by BeavrdamElectric
Old Nov 02, 2005, 11:45 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
You can use a 'normal prop' - just fit it with the normal front of the prop (convex blade surface, usually with letters embossed on it) facing forward, run your motor in reverse (so the prop spins clockwise when viewed from the REAR of the plane) and as they say "Bob's your uncle!".
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Nov 02, 2005, 06:51 PM
Argentina
Joined Aug 2003
Thank Phil for your quick answer to my doubts.
Regards,
pulqui
Hummingboard- tail motor help needed Fixer Micro Helis 4 Dec 28, 2003 02:46 PM
E-Zone Extra 300L Motor help needed pmjass Sport Planes 0 Nov 30, 2002 04:36 PM
Crazy Max motor help needed sn1973 Parkflyers 6 Nov 01, 2002 05:06 PM
Motor Help Needed. akh223 Parkflyers 1 Sep 26, 2002 05:09 AM
Could it be my motor? Help needed.... kenny_dilger Electric Plane Talk 3 Dec 20, 2001 07:54 PM
