Old Oct 31, 2005, 11:25 PM
BMtech is offline
Find More Posts by BMtech
Scorpian 60'' 2012
BMtech's Avatar
Kurrajong Australia
Joined Jul 2005
How do you make ailerons from flat stock?
I Know this is a simple thing but what is a good way to make ailerons from flat stock?
Any help will be appreciated.
Rick
BMtech is offline Find More Posts by BMtech
Old Oct 31, 2005, 11:52 PM
steve wenban is offline
Find More Posts by steve wenban
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
Razor plane and sandpaper Rick
SteveW
steve wenban is offline Find More Posts by steve wenban
Old Nov 01, 2005, 12:01 AM
TFLG is offline
Find More Posts by TFLG
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
Pay attention, cuz this is complomicated
Take the flat stock you have mount a chevy small block on the front of it. Add 4 wheels, brakes, a gas tank, steering wheel and a nice comfy seat. Now hop on and drive to Hobby People or the closest hobby shop. Walk to the balsa wood rack. Carefully check every piece of aileron stock for a nice light, straight one. Walk to the check out, pay your $3 and then drive home! Viola!
Or you could just use a big flat sanding block with some 60 grit taped to it!
TFLG is offline Find More Posts by TFLG
Old Nov 01, 2005, 12:08 AM
Pismo is offline
Find More Posts by Pismo
Jim in San Diego
Pismo's Avatar
United States, CA, San Diego
Joined Nov 2002
LMFriggin'O
Too bad I can never find a straight one and, I could pay for 50 of 'em with the time I spend on sanding them out.
Pismo is offline Find More Posts by Pismo
Old Nov 01, 2005, 12:18 AM
Joined Dec 2003
true grit
Originally Posted by Pismo
LMFriggin'O
Dude you need to buy some heavier grit paper if it taking you that long
SteveW
Old Nov 01, 2005, 12:19 AM
Pismo is offline
Jim in San Diego
Pismo's Avatar
Joined Nov 2002
Are you counting bugger cleaning time?
Old Nov 01, 2005, 12:20 AM
surfimp is offline
Find More Posts by surfimp
Piscine Promulgator
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
Bravo, TFLG! That was one of the funniest posts I've read in a long, long time.
Steve
surfimp is offline Find More Posts by surfimp
Old Nov 01, 2005, 12:25 AM
BMtech is offline
Scorpian 60'' 2012
BMtech's Avatar
Kurrajong Australia
Joined Jul 2005
Yea Yea No Chevys here
Its just hard to get straight stock here.
But the 60 grit sounds good.
Old Nov 01, 2005, 12:26 AM
Joined Dec 2003
Mind you since the Mrs bought the belt sanderfor me Ive found it does it all including my nails
SteveW
Old Nov 01, 2005, 12:35 AM
TFLG is offline
TFLG's Avatar
Joined Feb 2002
Have you shot an Aileron into the wall yet?
It's amazing how a 1 ounce piece of balsa wood can be shot right through 3/8" drywall by a belt sander. And you should see what they will do to a glass fuse if your not carefull
I wish I could find that picture!
TFLG
Old Nov 01, 2005, 12:39 AM
Joined Dec 2003
No T not yet but I usually aim it out the back door and yell fire in the hole when I start to sand even the dog run for cover
SteveW
P.S. I've seen a C size oxy bottle take off across the floor and out through the side of the hanger
Old Nov 01, 2005, 06:07 AM
guy mckenzie is offline
Find More Posts by guy mckenzie
Joined Jun 2005
TE / aileron stock will not always do the trick. Some sections vary from semi symetrical at the root to symetrical at the tip, in effect giving a little wash out. Such an aileron needs to be razor planned / sanded from thicker sheet removing material from both the bottom and top surface plus the possibility of a taper in aileron width, to follow the intended wing section.
The joy of scratch building for some! It's easier to build the whole wing, including aileron in foam and to cut the aileron out and then face the LE of the aileron and TE of the wing for strength and hinging after removing an equivalent width of foam.
Be grateful for ARTF, they usually do it better!
guy mckenzie is offline Find More Posts by guy mckenzie
Old Nov 01, 2005, 11:29 AM
2lsvtec is offline
Find More Posts by 2lsvtec
217 Schnell
2lsvtec's Avatar
Joined Dec 2004
mmmmm M3 CLS? very very nice car, carbon roof, seats, hood, lip and 30 more hp under the hood and 300 lbs. lighter, what more could you want!!!
nick
2lsvtec is offline Find More Posts by 2lsvtec
Old Nov 01, 2005, 11:33 AM
InTheLift is offline
Find More Posts by InTheLift
It could happen...
InTheLift's Avatar
Torrance, California
Joined Jan 2004
ROTLMAO!!!!!
Sounds like you just needed to go to bed there Brian! LOL!!! You Engineers are SO silly!
InTheLift is offline Find More Posts by InTheLift
Old Nov 01, 2005, 11:45 AM
pinolefm1 is offline
Find More Posts by pinolefm1
Permanently Banned
pinolefm1's Avatar
Joined Aug 2005
SteveW
Since I bought this "power plane" I've forgotten where my razor plane is at...much quicker and far more precise..plus you don't have to study the grain first like you should with a razor plane.
HTH
Steve
pinolefm1 is offline Find More Posts by pinolefm1
Discussion How do you make the transition from normal to idle up? Decnav Micro Helis 15 Jun 13, 2007 01:25 PM
Alert How do you launch a sailplane from flat ground? soholingo Sailplane Talk 46 Nov 17, 2006 12:08 PM
How do you make a stand-alone video from XTR AndyOne Simulators 2 Mar 08, 2005 10:03 AM
How do you make decals with a computer? Andy W Scale Kit/Scratch Built 50 May 24, 2003 09:12 PM
How do you make channels in foam? Jim McPherson Foamies (Kits) 8 Sep 21, 2001 08:00 PM
