Old Feb 04, 2006, 09:22 PM
roccobro is offline
Find More Posts by roccobro
Watts your motivation
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
Yes it will scoot. But you have two big advantages too. The 16/15/x motor has a ton more torque than the 2015 or 16/7/x motors, and the rotor your spinning is making alot more thrust at that rpm, and will make even more than the Alfa did for every rpm increase. I wouldn't be too suprised if your making the same thrust at those watts than the alfa does at similar loading. I hope it holds to the power levels we're reaching for!!
Justin
roccobro is offline Find More Posts by roccobro
Old Feb 04, 2006, 09:37 PM
bmiller is offline
Find More Posts by bmiller
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Awww no flight test today....Scott I'm surprised you're hitting that high an rpm with the walkura rotor! Flew my 4S F-86 twice today still with the damaged Alfa rotor.
The less efficient rotor spins faster and again the motor started cutting out at WOT. So I flew it just below WOT. I gotta get going on that kyosho rotor!
I also crashed my SU-27 pusher thru a tree then into the ground! Oops pilot error!
Fixable but it'll be ugly so I bought another one!
If yours cuts out, disable the current limiting. It should help.
Bruce
bmiller is offline Find More Posts by bmiller
Old Feb 04, 2006, 11:23 PM
Nobert is offline
Find More Posts by Nobert
Nobert's Avatar
Tucson Avra Valley, Arizona, United States
Joined Jul 2002
Scott
Castle recommends that the current limiting be disabled on ducted fans.
Neal
Nobert is offline Find More Posts by Nobert
Old Feb 04, 2006, 11:54 PM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Hey Guys, I will cut the current limiting out! Thanks..It did cut off with the 3s pack but not the 1320 4s..I think because the better batts!
Justin yea a bit too much torque! I ran it some more and it tried to rip out at the mounts so I had to ca the crap out of all the joints.Now the fan is off centre a bit and rubbed the blades a touch.But not too bad.
Bruce I was supprized about the rpm also.the fan doesnt seem to be streaching too much.it didnt rub untill the mounts came loose.tomarrow I will stop by pegasus and pick up a 3s 1320 so I can try 5s
Scott
turbonut is online now Find More Posts by turbonut
Old Feb 05, 2006, 10:49 PM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Cool Scott! Were you able to fly it today?
HEY GUYS! Theres a prototype ME-262 and its made by either Alfa or Flyin Styro!
And its being test flown somewhere in germany! This is word of mouth and unconfirmed as of yet. But my source is pretty good!
Imagine 2 overpowered alfafans on that!!!!!!!
Old Feb 05, 2006, 11:13 PM
Tumbler is online now
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
haha, i beat them to it last year. Two Alphas in there. Its fast!!!
Tumbler is online now Find More Posts by Tumbler
Old Feb 05, 2006, 11:47 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
... This is word of mouth and unconfirmed as of yet. But my source is pretty good! ...
Bruce you can't keep your mouth shut can you Alfa, btw. 110cm wingspan, available mid march.
Herb is offline Find More Posts by Herb
Old Feb 06, 2006, 12:15 AM
Pilot44 is offline
Find More Posts by Pilot44
Let er Rip
Pilot44's Avatar
Long Island, NY
Joined Oct 2003
Well, that 262 would be something eh...
Jim
Pilot44 is offline Find More Posts by Pilot44
Old Feb 06, 2006, 05:29 PM
netmechanic is offline
Find More Posts by netmechanic
Watts the Point
netmechanic's Avatar
KY,USA
Joined Jul 2004
Hey Justin,
Can Someone tell me the difference in the MKI and MKII fans. I'm sure it's back in the thread but I'm too lazy to look.
What are the differences in output, amps, bla bla bla.
Here's a pic of the two I have although I don't know which one is the MKI and the MKII so feel free to school me on it.
netmechanic is offline Find More Posts by netmechanic
Old Feb 06, 2006, 07:50 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Hi Netmech,
The one on the right is the MKII, looks just like mine...
Cheers,
Eric B.
AirX is offline Find More Posts by AirX
Old Feb 06, 2006, 08:11 PM
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Just buy swithching to the mk2 rotor my huck picked up over 10mph!
Scott
Old Feb 06, 2006, 08:24 PM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Just compare them,
mk1 less pitch, skinnier blade.
It all adds up to less thrust at any given rpm compared to the mk2
Old Feb 06, 2006, 08:30 PM
roccobro is offline
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
Eric and Bruce are right. I wouldn't even bother with the mk1 rotor. You'd need to spin 80k to match what the mk2 does easily.
Page one and two has charts the show the diff between the two, but I don't have any amp readings as I never tried it.
Justin
Old Feb 06, 2006, 11:32 PM
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Ok all the repairs are done and the 3s pack is on the charger now.should be posting the spec in about 30 to 40 min..if it doesnt fly apart at 45k rpm...
Old Feb 07, 2006, 12:56 AM
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
O my Gosh that was a noise and a half..
5s 1320 prolites
after 15 sec.
26amps
15.7 volts
410 watts
peak at first wot
480w
29+ amps
after a 30 sec pull
motor was 116 deg f
batts 122 deg f
I was soooo excited I forgot to check rpm. So I throttled up and a wire broke at the solder joint next to the motor..It was not hot so I think it was because the wires were loose in the slip stream and moving around a lot.I will fix it tomarrow and check rpm then.So now its time to mount it in a plane!
Scott
PS those times were just me counting to my self not a stop watch..
Also 1/3 throtle is 140 watts. the most the other motor did at wot.
For Sale For Sale - FS - GWS 350 Motor / Power System - D Geared - Prop, Spinner, Deans inc. freedomflyer Aircraft - Electric - Power Systems (FS/W) 1 Jun 26, 2006 03:25 PM
For Sale FS - GWS 350 Motor / Power System - D Geared - Prop, Spinner, Deans included! freedomflyer Aircraft - Electric - Power Systems (FS/W) 1 Jun 09, 2006 04:16 PM
Discussion Alternate airframe for Alfa Mig fan/motor?? gambit7 Electric Ducted Fan Jet Talk 5 Feb 21, 2006 04:29 PM
Hobbico Press release - Ultrafly D/13/32 Brushless Motor Power Upgrade Kit Dave Lauck Product Announcements 0 Sep 28, 2005 03:01 PM
hyperion motor and Alfa fan? andre petit Electric Ducted Fan Jet Talk 0 May 12, 2005 04:59 PM
