Finally!
Nice work Scott! Looks good! I really like the screw that holds the darn spinner!It's been so long I'd forgotten the motor you're going to use... mega16/7/4? on 4S? Bruce |
Latest blog entry: Durafly Vampire 70mm
Ya know this speed run thing would make a great online contest, all you need to enter is a video of the run/runs with a time/date stamp on it to validate the vid and the doppler program Waveosscope to proccess the video to get the speed data.
Cheers, Eric B. |
Latest blog entry: T/A 37 Tweet/Dragonfly
Not in the F-86 catagory anyway... Theres 3 "competitions" All Winners will receive NOTHING! bragging rights and maybe a few oohs and aahs... ALFA F-86 ALFA MiG ALFA TA-183(which I think you might already hold the record for!) |
Ok,
alfa fan unit walkura 75mm rotor cut down to 60mm mega 16/15/3 motor cc45 esc park bec self made rotor adapter no fan inlet ring too long wires( will shorten up for instalation and solder all connections) new TP prolite 1320 batt in 4s( need to cycle and warm up) now I need to get more batts for 5s Spec after 10 secs of runn 13.7 volts 20.0 amps 274 watts 37.500 rpm( tested with globee tack set to 3 blades then X by .6 ) reading 62.500rpm with those numbers I should be able to runn 5s and still not cook any of the equipment. Hey Justin I need to use your thrust test stand! it takes me too long to make things or i would build one (maybe later) But it sure put out a lot of wind and has a nice whine!! Scott I have a short video how do I load it? |
| Thread Tools | |
| For Sale For Sale - FS - GWS 350 Motor / Power System - D Geared - Prop, Spinner, Deans inc. | freedomflyer | Aircraft - Electric - Power Systems (FS/W) | 1 | Jun 26, 2006 03:25 PM |
| For Sale FS - GWS 350 Motor / Power System - D Geared - Prop, Spinner, Deans included! | freedomflyer | Aircraft - Electric - Power Systems (FS/W) | 1 | Jun 09, 2006 04:16 PM |
| Discussion Alternate airframe for Alfa Mig fan/motor?? | gambit7 | Electric Ducted Fan Jet Talk | 5 | Feb 21, 2006 04:29 PM |
| Hobbico Press release - Ultrafly D/13/32 Brushless Motor Power Upgrade Kit | Dave Lauck | Product Announcements | 0 | Sep 28, 2005 03:01 PM |
| hyperion motor and Alfa fan? | andre petit | Electric Ducted Fan Jet Talk | 0 | May 12, 2005 04:59 PM |
