Old Jan 12, 2006, 11:39 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Scott,
Does the Alfa for Mega motors have a larger motor holder? I only have the standard MkII version.
Eric B.
AirX is offline Find More Posts by AirX
Old Jan 13, 2006, 12:29 AM
bmiller is offline
Find More Posts by bmiller
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Originally Posted by turbonut
Bruce, I have a 480 fan and the problem I see is the hub is too large. You will loose a lot of the FSA due to the cone size.I dont think it will work well..But then again?
You going to the ama? I will be there tomarrow when they open at noon!
Scott
Urgghh!!! I can't win!
Gotta work tomorrow so no can go til saturday(NOT FAIR!)
Snoop out the fan units willya!
Would cutting down a Schuebler rotor upset everyone on the EDF forum?
Or is that considered defacing artwork!
bmiller is offline Find More Posts by bmiller
Old Jan 13, 2006, 01:33 AM
Henry V is offline
Find More Posts by Henry V
Henry V's Avatar
Long Beach
Joined Jan 2004
Tried to tach the alfa/wattage today, but my tach does not read 6 blades O well
Bruce, first time uh? You'll be like a kid in candy store Don't get to crazy!
Henry V is offline Find More Posts by Henry V
Old Jan 13, 2006, 03:08 AM
Chris Nicastro is offline
Find More Posts by Chris Nicastro
Chris Nicastro's Avatar
Post Falls, ID United States
Joined Feb 2004
Originally Posted by AirX
Cof G,
Does the Hyperion tachometer work with 6 blades? If not how did you go about calculating the rpm?
Here is a measurement pic of a rotor for illustration of how to get the angles for calculating the pitch.
Eric B.
Yes it does.
Thanks for the photo.
The M fan from Alfa has a 28mm ID motor tube that fits the Mega motor exactly. You have to remove the sticker from the can its that tight. You also should CA the motor in place since it sits back in from the mounting plate you would usually bolt a motor up against.
If your tach can read three blades can you divide the reading from a six blade rotor in half and be fairly accurate? Never done it before.
Chris
Chris Nicastro is offline Find More Posts by Chris Nicastro
Old Jan 13, 2006, 03:21 AM
Joined Feb 2004
"Would cutting down a Schuebler rotor upset everyone on the EDF forum? "
Hmmm let me think.....120MPH Alfa F-86 or a pretty fan unit......mmm..yeah....CUT IT!!!!
Chris
Old Jan 13, 2006, 09:30 AM
Henry V is offline
Henry V's Avatar
Long Beach
Joined Jan 2004
I tried that hoping that i would be able to just divide it, but it doesnt even register on the tach meter...
OMG! 120 mph on a foam plane! . will the plane even hold up?
Henry
Old Jan 13, 2006, 02:35 PM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Scott, Can I "borrow" your schuebeler rotor?
Most of the tachs out there won't do 60,000rpm, using 3blade it would then have to read 120,000rpm!
120mph? It'd be worth it if the wings ripoff!!!
Old Jan 13, 2006, 03:06 PM
Henry V is offline
Henry V's Avatar
Long Beach
Joined Jan 2004
I finnally was able touse new TP prolite..these batteries are awsome!
Anyways, update on the Alfa/cut-down 6 blade wattage with the AON4900
28amps.
302watts
I like it alot...placed it on a scale and got 15 oz of thrust...3-4oz more than the TP 2nd Gen..
Henry V
Old Jan 13, 2006, 03:25 PM
Tumbler is offline
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
28amps.
302watts
Henry V
Something seems wrong here. I was getting about 15 ozs of thrust on my 2025-5300 on a 3-cell Polyquest 2200 12c oly drawing 24 amps and 230 watts. Are you sure you aren't getting more thrust than that???
Brian
Tumbler is offline Find More Posts by Tumbler
Old Jan 13, 2006, 03:31 PM
Henry V is offline
Henry V's Avatar
Long Beach
Joined Jan 2004
I could be...the scale was kinda unstable..so I'll try again tonight
Tumbler is offline
Tumbler's Avatar
Joined Feb 2003
Chris,
I got the Hyperion 5000 the other day. I forgot to check the shaft size and can't use it until i find someone to ream metal hub out for me. I am such a moron for not checking. Did you ever measure the thrust with that motor on 3 and 4 cells?
Here's a tip for everyone.......
I have used about 5 Alpha fans and have noticed after 5o or so flights the motor moves as a result of the screw holes opening up a little under stress and vibration. The causes the fan to rub on the sides of the housing. I used a piece of PC board or you could use light ply and cut in a disc and glued on the inside of the motor mount and then drilled out for the shaft and motor screws. This will keep that from happening.
Just an idea.
Brian
Old Jan 13, 2006, 05:01 PM
Joined Feb 2004
Good tip, I did notice that at one point.
Yes I got one thrust number;
on 4S 31-33A = 690-700g thrust on my scale in the Mig, not outside the airframe. The rpm was 60400 out of the frame. These numbers are saved on my Hyperion meter.
3S was an actual flight and I didnt get any thrust numbers before the event happened. It really moved on 3S though, you will like it.
Chris
Old Jan 13, 2006, 07:37 PM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Sounds good Henry! much better than the old pack!
I wonder what the 4900 would do on 4S w/alfa rotor????
I think the wattage rotor is too much load if you try 4S with the 4900.
Old Jan 13, 2006, 08:13 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
CofG,
You would have to divide by 3 would you not if it reads only two blades, and if it can read 3 times the rpm's.
I will get back tomorrow on the tensile strength calculation for rotor blades, I validated that the calculation is correct last night and am putting it into format.
Eric B.
Last edited by AirX; Jan 15, 2006 at 10:06 AM. Reason: Added Tensile Strength Calculation
Old Jan 14, 2006, 12:16 AM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Herb went to the AMA show and I had asked him to pick up a mini480fan if there were any, And I'm going tomorrow sometime, Then if I still can't get a usable rotor, I'll cutdown my cutdown kyosho rotor thats in my old Mega/3 WPF! And maybe I'll end up with a spare mini480 to put in something!
For Sale For Sale - FS - GWS 350 Motor / Power System - D Geared - Prop, Spinner, Deans inc. freedomflyer Aircraft - Electric - Power Systems (FS/W) 1 Jun 26, 2006 03:25 PM
For Sale FS - GWS 350 Motor / Power System - D Geared - Prop, Spinner, Deans included! freedomflyer Aircraft - Electric - Power Systems (FS/W) 1 Jun 09, 2006 04:16 PM
Discussion Alternate airframe for Alfa Mig fan/motor?? gambit7 Electric Ducted Fan Jet Talk 5 Feb 21, 2006 04:29 PM
Hobbico Press release - Ultrafly D/13/32 Brushless Motor Power Upgrade Kit Dave Lauck Product Announcements 0 Sep 28, 2005 03:01 PM
hyperion motor and Alfa fan? andre petit Electric Ducted Fan Jet Talk 0 May 12, 2005 04:59 PM
