Hi Justin,
Deformation and return to shape is called (elasticity) not unusual for any material (steel will do the same thing but it is not elastic as ABS is), it is when it deforms and then will not return to shape that damage has occured. Since the gap widened the blade stretched a millimeter, rubbed increasing gap tolerance and then went back to shape. Very common on all fans even the microfan at 130watts. Eric B. |
Latest blog entry: T/A 37 Tweet/Dragonfly
Hah! maybe somebody can find some sort of space shuttle or dental drill ceramic bearings in the right size! Then the next thread will be on how to install them!LOL
Latest blog entry: Durafly Vampire 70mm
I don't have the bearing size specs but here are some with 3.2mm id and close to outer measured size (and ceramic!).
http://www.bocabearings.com/main1.as...7&n=SR2C-UU_#7 Justin |
Geez....
Looks like 89,000rpm w/grease and 109,000rpm w/oil! sweet! GASP!!! $29.95 EACH!? Everybody better hurry up, they only have 390 left in stock!
Justin, the rpm specs are on the Mega site for each motor. The specs are listed below the chart.
http://www.megamotorusa.com/brettcam...7-3.htm?id=482 Mike |
Latest blog entry: test
Hi Justin,
Please confirm if possible, Does the mega 16/7/xx bolt right in the mk2 alfafan unit or do you have to "open er up" like power did in his thread? The mega 16/7/xx WILL bolt right in the alfafan mk1? And then you should use a mk2 rotor because the mk1 rotor is junk? Thanks, Bruce |
GREAT tests... !
My my, you HAVE been a busy boy !
![]() Quote:
![]() Quote:
Frankie and Benny advised us all that the Feigao motors were not to be used over around 5 amps - see here - first paragraph under the top picture... Ha ! It didn't stop me throwing caution to the wind ( literally - I FLEW the things ) - and running them at around 9A ( admittedly for only 3˝ to 4 minutes at a time… )You have to push things a little - if only to make sure that the manufacturers are being straight with us...! ![]() Thatovalguy warned me ( in one of my threads ) that you cannot expect a warranty to be in place in such cases... Like I'm going to bemoan the loss of a couple of tidgy motors after having had WEEKS of fun with them... ![]() ( BTW - the motors are FINE ! )Thanks for the test results, Justin, Keven.
Latest blog entry: Unethical selling on eba... that sales...
| Thread Tools | |
| For Sale For Sale - FS - GWS 350 Motor / Power System - D Geared - Prop, Spinner, Deans inc. | freedomflyer | Aircraft - Electric - Power Systems (FS/W) | 1 | Jun 26, 2006 03:25 PM |
| For Sale FS - GWS 350 Motor / Power System - D Geared - Prop, Spinner, Deans included! | freedomflyer | Aircraft - Electric - Power Systems (FS/W) | 1 | Jun 09, 2006 04:16 PM |
| Discussion Alternate airframe for Alfa Mig fan/motor?? | gambit7 | Electric Ducted Fan Jet Talk | 5 | Feb 21, 2006 04:29 PM |
| Hobbico Press release - Ultrafly D/13/32 Brushless Motor Power Upgrade Kit | Dave Lauck | Product Announcements | 0 | Sep 28, 2005 03:01 PM |
| hyperion motor and Alfa fan? | andre petit | Electric Ducted Fan Jet Talk | 0 | May 12, 2005 04:59 PM |
