Old Nov 08, 2005, 12:44 AM
bmiller is offline
Find More Posts by bmiller
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Originally Posted by Paul DF jet man
if you want a smoke system how about these
http://www.hobby-lobby.com/atricks.htm
LOL! I'll have to put that on my T-Bird F-16!
also wouldn't mind dropping a bomb or 2!
bmiller is offline Find More Posts by bmiller
Old Nov 08, 2005, 12:51 AM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Hey Guys, Plenty of room behind the canopy to adj cg. the problem is the height.but not a big prob.
Old Nov 08, 2005, 01:33 AM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Cool, with the bottom removed from the cockpit you should be good to go!
Didn't know you could slide it past the opening, On the F-86 the packs are centered under the 'pit w/ the electronics right behind them.
Old Nov 08, 2005, 02:19 AM
roccobro is offline
Find More Posts by roccobro
Watts your motivation
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
Paul- I had looked at those smoke packs and didn't even notice the "small" ones until now. That would be cool with one on a wing tip or as a drop tank. Not too much weight to worry about with this kind of power. Shoot the smaller smokes could be made into a motor cone extension to aid in fan dynamics and look like a burn out!
Scott- What is the max width and depth (into fuse)? These PQ packs are 4" long and 1" wide, 1 1/4" tall. I'm really tempted to order two more 2s 1320's. Grrr...
Justin
roccobro is offline Find More Posts by roccobro
Old Nov 08, 2005, 03:01 AM
euromodels is offline
Find More Posts by euromodels
Sydney
Joined Nov 2004
Originally Posted by mfranke
Justin
does the fan drop right in? This must be a different version of the MK2.
How long did it take you to get the fan from them. It also looks like their adapter is pre drilled out too?
Mark
Hi,
We have the fans modified for Mega motors + 1/8" shaft adaptors in stock.
Regards,
Zdenek
Euromodels
euromodels is offline Find More Posts by euromodels
Old Nov 08, 2005, 03:13 AM
roccobro is offline
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
There you go.
Justin
Old Nov 08, 2005, 10:32 AM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Justin, I will check tonight!
S
Old Nov 08, 2005, 01:38 PM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
Zdenek that is very cool!
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Nov 08, 2005, 04:11 PM
Corey11c is offline
Find More Posts by Corey11c
AFM's fastest slow guy.
Corey11c's Avatar
Santa Cruz Mountains, CA
Joined Oct 2005
I just got my Huck in from Hobby Lobby and I bought a Mega 16/15/3 and I'm gonna run a TP 4S1P 2100mAh pack. This is my first electric aircraft, so we'll see how it goes. Wish me luck.
Corey11c is offline Find More Posts by Corey11c
Old Nov 08, 2005, 04:16 PM
Tumbler is online now
Find More Posts by Tumbler
Tumbler's Avatar
New Jersey
Joined Feb 2003
Uh Oh, I could be wrong but I think you got the wrong motor. The 16-15-3 is for the Wemotec Minifan. I think you wanted the 16-7-3.
Tumbler is online now Find More Posts by Tumbler
Old Nov 08, 2005, 04:25 PM
Corey11c is offline
Corey11c's Avatar
Joined Oct 2005
It's the same diameter as the 16/7/3, it's just a little longer casing. The 16/7/3 also wasn't in stock at my local hobby shop. If there's any problems I'll have other than the case length please let me know.
Old Nov 08, 2005, 04:49 PM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
Also, how does the fan blade detach from the stock motor. I don't want to break it by prying on it.
As far as problems go there are none. Performance will be another issue the kv of the 16/15/3 is a lot lower than the 16/7/3 you will not see near the rpms from the 16/15/3 the weight is quite a little more as well
power is offline Find More Posts by power
Old Nov 08, 2005, 04:50 PM
roccobro is offline
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
A couple things. First, there is no stock motor. The rotor, fan housing and adapter are loose in a box. so no problems there.
Second as Power points out, the 16/15/3 has a kv (rpm per volt) of 3000 and while the weight won't effect you too much (7grams heavier than the Himax), you'll need some serious batteries (5s minimum) to get up to the rpms to match the 16/7/3 is spinning at on 3s with a kv of 5580. I'm interested to hear how she does. The 16/15/3 is a great motor for alot of applications. The /2 would be better for this one if you want to stay with that motor size.
To anybody with the F-86 or mig, what is the battery box size? Somebody said a 4s 1320 won't fit. I want this information so others can choose the proper batteries (besides the TP 1320's ) and not get bummed.
Justin
Old Nov 08, 2005, 08:12 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
The first Hucks had Speed 300's in them or the BL CZ motors IIRC.
Eric B.
AirX is offline Find More Posts by AirX
Old Nov 08, 2005, 09:31 PM
Corey11c is offline
Corey11c's Avatar
Joined Oct 2005
Well, I'm working on making the motor fit in the housing right now. A little more machining and it will be done. I'll let you guys know how it does with the 16/15/3 on 4s1P
For Sale For Sale - FS - GWS 350 Motor / Power System - D Geared - Prop, Spinner, Deans inc. freedomflyer Aircraft - Electric - Power Systems (FS/W) 1 Jun 26, 2006 04:25 PM
For Sale FS - GWS 350 Motor / Power System - D Geared - Prop, Spinner, Deans included! freedomflyer Aircraft - Electric - Power Systems (FS/W) 1 Jun 09, 2006 05:16 PM
Discussion Alternate airframe for Alfa Mig fan/motor?? gambit7 Electric Ducted Fan Jet Talk 5 Feb 21, 2006 05:29 PM
Hobbico Press release - Ultrafly D/13/32 Brushless Motor Power Upgrade Kit Dave Lauck Product Announcements 0 Sep 28, 2005 04:01 PM
hyperion motor and Alfa fan? andre petit Electric Ducted Fan Jet Talk 0 May 12, 2005 05:59 PM
