Old Nov 07, 2005, 02:47 PM
Tumbler is offline
Find More Posts by Tumbler
Tumbler's Avatar
New Jersey
Joined Feb 2003
Originally Posted by bmiller
ROTFLOL,
I wish you had video of that flight!!!!
I'm going for it!
Oh i was LMAO!! sounded like a hair dryer without and intake or anything. i need new impeller for mine because i have so many flights on it, its worn out. I am going to try 4S on the 5300 too. If it burns up, 'll try something else.
Brian
Tumbler is offline Find More Posts by Tumbler
Old Nov 07, 2005, 02:59 PM
bmiller is offline
Find More Posts by bmiller
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
haha,
If it burns up I'll put another 5300 in it and stay at 3s lighter/more convenient.
I figure The F-86 ducting is smaller/less efficient than the migs and less air is less amps. You should use the wornout rotor too!
bmiller is offline Find More Posts by bmiller
Old Nov 07, 2005, 03:23 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
hey Justin I think if I cut the fake cocpit out so the canopy is opened up we can fit more battery
Scott
Old Nov 07, 2005, 04:13 PM
roccobro is offline
Find More Posts by roccobro
Watts your motivation
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
Definitely Scott. Can those two just be seperated? I'll have to transplant my Park BEC to the P-45 for the 16/7/3 on 4s run. I'd really like to try the 4200 on 5s first and don't want to solder at the field. Hmmm, minor details...
Justin
roccobro is offline Find More Posts by roccobro
Old Nov 07, 2005, 06:47 PM
mfranke is offline
Find More Posts by mfranke
Joined Oct 2005
Mk2 fan? Mega 16/7/4
Did I miss something. I got a new MK2 fan from H-Lobby and a Mega 16/7/4
The motor is anout 1mm too big for the housing?
Whats Up? I'm sure others on the theard have used this combo. How did you open up the housing?
Mark Franke
Alfa Sabre
mfranke is offline Find More Posts by mfranke
Old Nov 07, 2005, 08:10 PM
roccobro is offline
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
Mine came from Euromodels already machined. You can take a dremel with a sanding drum or cut off wheel and open it up. OR see power's thread about how to machine a (WeMo Microfran) housing by hand here . You will also notice you will have to open up the rotor adapter hole to fit the Mega's 3.2mm (1/8th) shaft.
Let me know if there is any other Q's or problems. They are fun packages for the weight!!
Justin
Old Nov 07, 2005, 09:38 PM
mfranke is offline
Joined Oct 2005
MK 2 Fan
Justin
does the fan drop right in? This must be a different version of the MK2.
How long did it take you to get the fan from them. It also looks like their adapter is pre drilled out too?
Mark
Old Nov 07, 2005, 09:45 PM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
hehehe
Okay, looks like I'm in business!
I got a CC phoenix45 ESC and a tiny 32gram 300mah 4cell receiver pack.
I'll start soldering everything and make a series connector to 4S my 2 2cell packs
Bruce
maybe I should leave the 25A esc in.....
It'd be cool to see a trail of smoke coming out the back!
Old Nov 07, 2005, 09:46 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Justin, they can be pulled apart but the front and back are what holds the canopy.Guess we could just use tape again?
Scott
Old Nov 07, 2005, 09:50 PM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Tape is my friend!
Scott, is the CG attainable with that much battery? what was it..11oz!
Old Nov 07, 2005, 11:05 PM
roccobro is offline
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
Mark- That fan does come machined- it is a mk2 fan unit machined out just for using a Mega 16/7/x motor. The adapter with it is also opened for the Mega shaft size.
Bruce-I did not look into the fuse of his Huck to see how far back they can go, but with the 4.2oz batt, it was all the way up front almost touching the servo (definitely touching after a backflip! ) Don't know the space constraints in the Mig or F-86.
Scott- Maybe a new molded canopy if you want to preserve the original? The batt heigth would require some cockpit to be removed if the canopy is to be on. Tape is friendly, so is the paint!!!
Cycling packs to be ready...
Justin
Old Nov 07, 2005, 11:32 PM
roccobro is offline
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
At one point Scott saw some "smoke" trailing behind when we were using his new/old stock 8c Kokams. Quick land and all was well. When we hooked up the 4s setup and gave her the first throttle, a bit of dust blew out the rear and was funny.
I've been thinkin about some small smoke pyrotechnics that would looks really cool trailing behind.
Justin
Old Nov 08, 2005, 12:00 AM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
let us know about the pyrotechnics if you ever find something!
Back to soldering......
I must have a small fortune invested in these deans ultra connectors!LOL
Old Nov 08, 2005, 12:10 AM
Paul DF jet man is offline
Find More Posts by Paul DF jet man
MORE POWER IS THE KEY
Paul DF jet man's Avatar
South Australia
Joined Jun 2004
if you want a smoke system how about these
http://www.hobby-lobby.com/atricks.htm
Paul DF jet man is offline Find More Posts by Paul DF jet man
South Australia
Joined Jun 2004
got my F-86 today. I will try to build it ASPA and get that 4200 on 5s fired up.
For Sale For Sale - FS - GWS 350 Motor / Power System - D Geared - Prop, Spinner, Deans inc. freedomflyer Aircraft - Electric - Power Systems (FS/W) 1 Jun 26, 2006 04:25 PM
For Sale FS - GWS 350 Motor / Power System - D Geared - Prop, Spinner, Deans included! freedomflyer Aircraft - Electric - Power Systems (FS/W) 1 Jun 09, 2006 05:16 PM
Discussion Alternate airframe for Alfa Mig fan/motor?? gambit7 Electric Ducted Fan Jet Talk 5 Feb 21, 2006 05:29 PM
Hobbico Press release - Ultrafly D/13/32 Brushless Motor Power Upgrade Kit Dave Lauck Product Announcements 0 Sep 28, 2005 04:01 PM
hyperion motor and Alfa fan? andre petit Electric Ducted Fan Jet Talk 0 May 12, 2005 05:59 PM
