Nov 30, 2005, 01:05 PM
United States, CA, Meadow Vista
Joined Nov 2004
P61C Black Widow series (#32) - SETBACK!!!
Well -------- SETBACK!!!!!!
It would appear that KlassKote is WAY too hard to effectively burn/melt rivets into! Bummer! The rivets that I did add using this method were more indentations rather than clean rings. The indentations were not even and their surface clarity depended on too many variables to get them to look good. The results were poor to say the least. I did not seem to matter what temperature, pressure or time on surface was used, the results were poor.
So, what to do????
I decided to experiment with the titebond/water glue mix with the Gaunt Industries hypo-25 oiler. I thinned the mix of titebond to water to about 60% water, 40% Titebond and applied rivets to a scrap piece of material. Once cured, and given the mix ratio of glue to water, I found that the rivets were flatter that the typical rounded style. I then proceeded to lightly sand the tops off the flattened rivets and achieved a slightly raised, but flat topped rivet string. So, would this work?
I called a few scale modelers and found out that this method is somewhat commonplace and the effect after weathering with washes results in small half-moon type surface features that do quite well at rivet simulation. Certainly not the desired look I was aiming for but adequate for this aircraft given the fact that it was already painted in KlassKote!!!
In further discussions with fellow modelers, it is apparent that if you want burnt/melted flush rivets, they should be done in the primer as this paint is much softer than a surface paint. Likewise for the panel lines.
So, this tells me that the method I have used on this aircraft was perhaps the wrong one due to the fact that most of the rivets on the P61 are flush. For raised rivets, this method works well.
Anyway, rivets have now been applied with Titebond to the fuse and the wing tips. I will need to re-work the surface of the stabilizer which was attempted with the soldering iron so that it is flat again for titebond rivets!!
Also, the Dzus fasteners were OK in places and poor in others using the soldering iron method. I have decided to fill some of these in, sand flat and then apply laser cut stick-on fasteners using monokote trim where they are really visible, like the cowls for example, and then paint over them. The remaining ones, which are not too bad, will stay as is and after painting and weathering should be ok. Most of these are on bottom surfaces and not readily visible.
Lesson learned!!!!
