Super Bandit Park Jet
Well, I thought I was going to take a break from designing park jets. But then a friend recently asked if I could design a park jet version of the BVM Super Bandit for him, and that was a challenge I just couldn’t resist! So I thought I’d share the results with this forum.
This is simply a scaled-down version of the Super Bandit, adapted for sheet foam construction using the same construction techniques as the rest of my park jet designs. In fact, the structural design of this model is almost identical to my T-38 park jet (so you can use the T-38’s construction manual as a guide to build it). About the only design change I made to the scale outline was to scale up the vertical tail area about 20%, as I usually do to compensate for the torque and gyroscopic effects of the pusher propeller and to provide better small-field handling. This ship was specifically intended for SPEED! Thus, I sized it a little bit smaller than the other park jets--220 sq in wing area instead of 250 sq in, plus it has a much smaller and lower drag fuselage than my other park jets. This sizing should allow the model to be either a good parkflyer or an all-out speedster, depending on how you set it up. I did a quick analysis in MotoCalc to determine the best power setups for this model, and the results are shown in the table attached below. I only ran Himax motors for this analysis just to keep it quick and because I’m a real fan of them. My favorite setups were: * Best Parkflyer Setup: Himax 2015-4100, TP 1320 mAh 11.1 V lipo, APC 9x7.5 prop, 15+ amp ESC. This model should weigh about 16 oz with this setup, will pull about 15 amps, and will have a top speed of just almost 60 mph. The light weight with this setup will make the model very maneuverable and great for small-field flying. Note that since the forward fuselage on this design isn’t nearly as long as the other park jets, it will have a difficult time balancing with this lightweight battery. So try to make the back end as LIGHT as possible and put all the internal components (receiver and servos) as far forward as possible. * All-Out Speedster Setup: Himax 2025-5300, TP 2100 mAh 11.1 V lipo, APC 7x6 prop, 25 amp ESC. The model should weigh about 19 oz with this setup, will pull about 20 amps, and should have a top speed of 70 mph! I sure hope the foam hangs together at those speeds… With this heavy battery, the model shouldn’t have any trouble with balance.Plans are posted below in both tiled and non-tiled formats. I’ve also posted some pics of what the plans should look like when assembled, plus some preview pics of this design and how it compares in size to my original F/A-18 Hornet Park Jet. Note these are BETA plans since I haven’t built this model yet, so there may be errors on them (and please let me know if you find any). I’ll build one of these eventually, but it won’t be anytime soon. This was more of a quick and fun design exercise. Also notice that I didn’t show any aileron or elevator linkages in the plans. I figured everyone already has favorite setups for these and will just install what they want to anyway. The split elevator will be a bit of a challenge to actuate, but a simple Y-connector on a single carbon pushrod should work OK. Enjoy, and post pics if you build one! Steve
Oh yeah, the F14 is still #1
Scott, hook me up with what you think will make this thing break 100! www.3dfoamy.com |
Waco, TX
Joined Jan 2004
I am going to try and build one for sure. I drew up some plans for one this week and was bout 1/2 way finished when I noticed your post. If I can get away with it I am going to try and swap out the geared himax for a mega 4 turn and 6x5.5 or 7x4. I have about 60-70 wide open acres to fly on so the faster it goes the better. Very nice design steve.
| Thread Tools | |
| Build Log Sukhoi Su-37 Super Flanker Park Jet | jetset44 | Pusher Prop Jet Models | 3071 | May 15, 2013 02:51 AM |
| F-100 Super Sabre 33 inch WS Depron Park Jet | fuelsguy | Pusher Prop Jet Models | 124 | Dec 17, 2009 08:39 PM |
| Video F4 Phantom w/ Little Screamers Super Park Jet | Bajora | Electric Plane Talk | 84 | May 06, 2009 01:08 PM |
| New Product super park jet | ouluckydogu | Power Systems | 2 | Mar 23, 2007 02:33 PM |
| Video Little Screamers Super Park Jet on 4S (6mmflyrc F4 Phantom II) | Bajora | Electric Plane Talk | 10 | Mar 04, 2007 02:30 PM |
