Closed Thread
This thread is privately moderated by Jeff Meyers, who may elect to delete unwanted replies.
Old May 21, 2002, 03:16 PM
Jeff Meyers's Avatar
Fayetteville, GA
Joined Oct 2000
Trader Rating: 3
NEW PRODUCT ANNOUNCEMENT - The Ultimate BEC
At last....we are ready to ship the "Ultimate BEC". This is an external BEC that is used to replace receiver battery packs.
Max input voltage - 35 volts
Max output current - 3 amps continuous / 5 amps peak
Weight - 20 grams
The price is $30 + $2 shipping.
Please take a moment to check it out on our site.
http://www.koolflightsystems.com/ultimatebec.htm
Best Regards,
Jeff Meyers
Jeff Meyers is offline Find More Posts by Jeff Meyers
Old May 21, 2002, 03:47 PM
United States, FL, Starke
Joined Apr 2002
Trader Rating: 13
I've got mine!
dd.
Doc Data is offline Find More Posts by Doc Data
Old May 21, 2002, 05:27 PM
ScotY's Avatar
Joined Feb 2001
Trader Rating: 12
Jeff,
Glad to see your UBEC finally make it to market! I've been impatiently waiting! I've read over the details on your website, but have a question. I'd love to use this in one of my gliders but would need to place the unit right next to the receiver...virtually on top of it. There's some carbon in the fuselage and the plane will likely get pretty far away. I don't use PCM receivers. Are you confident it will work okay?
Thanks!
P.S. One request...if I had a choice, I would prefer a long, skinny UBEC unit...one that would fit down a skinny glider tailboom. Twice the length, half the width would be perfect for most of my planes. Any chance of getting one of these?
ScotY is offline Find More Posts by ScotY
Old May 21, 2002, 05:46 PM
Fayetteville, GA
Joined Oct 2000
Trader Rating: 3
To prove a point...I used the first production UBEC in my Embat. The UBEC was taped to the floor of the fuse....then I taped my Rx to the UBEC.
The UBEC does not have to be "mounted" anywhere. Just stick any place it will fit. Since it taps off of the ESC input leads...it could just lay on top of the ESC.
Carbon fiber does not affect the UBEC. All it's doing is taping power out of your battery and regulating it to 5 volts for your Rx.
I have personaly been using the unit since last summer in my own planes.
A few months ago we sent out units all over the country for guys to use them in their planes. 100% reported excellent results.
As far as size goes... the UBEC is smaller than most 35 amp and up speed controls. If your ESC fits...the UBEC should fit. We cannot change the dimensions as we had the board custom made for this particular product.
Best Regards,
Jeff Meyers
Old May 21, 2002, 06:29 PM
Joined Apr 2002
Trader Rating: 13
You can see it installed in an Omega 2M E in this photo...
dd.
Old May 21, 2002, 06:54 PM
Tullahoma, TN
Joined Jul 2000
Trader Rating: 18
Can we pick one up at SEFF?
EricBjorn is offline Find More Posts by EricBjorn
Old May 21, 2002, 08:17 PM
Fayetteville, GA
Joined Oct 2000
Trader Rating: 3
Hi Eric,
I will have a load of UBECs and Kool Charge Tubes at SEFF.
That reminds me...I need to add Kool Flight Systems as a sponsor.
Regards,
Jeff
Old May 21, 2002, 10:50 PM
Recruiter - 60 Amp Club
Ed Lyerly's Avatar
Rutherfordton, North Carolina, United States
Joined Apr 2001
Trader Rating: 114
Jeff,
Save me (2) .....my check is in the mail. This is a much needed product !!
Ed
Ed Lyerly is offline Find More Posts by Ed Lyerly
Old May 22, 2002, 06:13 AM
ScotY's Avatar
Joined Feb 2001
Trader Rating: 12
Jeff,
Thanks for the reply. Did anyone test the UBEC in a 24-27 cell F5B plane, by chance? What about a helicopter?
Old May 22, 2002, 10:01 AM
Really?!?
ChrisS's Avatar
Lost ...on the 3rd rock out
Joined Sep 2001
Trader Rating: 7
Jeff, I'm interested. How much will you charge me for a unit that can run on 32 cells? I will be using this in a heli with three 9202's and a 9205, is cooling going to be a problem?
Chris
ChrisS is offline Find More Posts by ChrisS
Old May 22, 2002, 10:35 AM
Fayetteville, GA
Joined Oct 2000
Trader Rating: 3
Scott,
The UBEC was not tested in a heli or a F5B plane. It was tested in a 24 and 28 cell sport plane. (and many others)
However, it will work fine with those two applications. Remember that with a heli...when the pack starts to drain you are landing anyways. I have already had many heli pilots order the UBEC.
My friend / business partner is the one who designed the UBEC. His primary interest is LMR events. His original reason for designing the UBEC was that it is well know that trusting the BEC in a speed control during high current runs is not wise. Every year a few planes go down at the NATS for this reason. (So I've been told, I'm not a NATS competitor)
Regards,
Jeff
Old May 22, 2002, 10:42 AM
Fayetteville, GA
Joined Oct 2000
Trader Rating: 3
Chris,
The UBEC can be upgraded to handle 40 volts input. This would cover your needs. Volts do not heat up the UBEC...current heats it up. I will clarify this on the site.
Long story short...an upgraded UBEC will work fine for you.
As far as special orders go...these are made to order.
It will take 2-3 weeks to get the "high voltage" UBEC shipped once payment is recieved.
The cost for a 40 volt UBEC is $40 + $2 shipping.
This lead time will be reduced once more parts arrive.
Best Regards,
Jeff Meyers
Old May 22, 2002, 10:52 AM
Really?!?
ChrisS's Avatar
Joined Sep 2001
Trader Rating: 7
Very cool. I have been debating designing one of these myself, and now I don't have to. Do you take credit cards? Can I just call the number on your site with my info?
Chris
Old May 22, 2002, 10:54 AM
Fayetteville, GA
Joined Oct 2000
Trader Rating: 3
Sent you a PM Chris...
Currently, all we can take is checks, money orders and Pay Pal.
Being a two item "business"...we aren't all that fancy.
Although...product #3 is already in the works.
Old May 22, 2002, 02:20 PM
Rochester, NY, USA
Joined Aug 2000
Trader Rating: 8
The yellow thing under the white 8-cell pack is my Ultimate BEC that replaces my receiver battery on my Astro Flight 625G power system. Not only have I eliminated the hassle of having to charge my Rx. battery but I also dropped 2.5 ounces in weight.
Great product, Jeff!
Click here for a larger image.
Greg Covey is offline Find More Posts by Greg Covey
Closed Thread
Eflightpacks new product announcement rcdude Aircraft - Electric - Airplanes (FS/W) 6 Oct 01, 2002 10:49 AM
New Product Announcement eflyer1234 Vendor Talk 2 Sep 19, 2002 12:15 PM
New Product Announcement eflyer1234 Ornithopters 4 Sep 19, 2002 12:13 PM
