Old May 20, 2002, 07:36 PM
alaric is offline
Find More Posts by alaric
Oxford, CT
Joined Sep 2001
Cutting wood for a scratch build...
I'm trying to figure out how to make nice square cuts for my first scratch project. My primary concerns is that the ribs are well formed.
So, any suggestions?
alaric is offline Find More Posts by alaric
Old May 20, 2002, 08:58 PM
zebra is offline
Find More Posts by zebra
The Original
Oklahoma City
Joined Feb 2002
alaric,
I'll start the suggestions out by saying....make sure you work from an accurate and stiff template; I normally make my rib templates out of 1/32" ply....also, always work with a good sharp #11 blade and change it frequently. They dull quicker than you think. Above all....take you time and be very patient I know sometimes the patience part still gets to me every now and then And I've been scratch building for many years.
Have a good one & stay cooool Jim
zebra is offline Find More Posts by zebra
Old May 20, 2002, 11:55 PM
Paul Susbauer is offline
Find More Posts by Paul Susbauer
Balsa Builder
Paul Susbauer's Avatar
United States, OR, Hillsboro
Joined Apr 2001
Alaric,
When I cut out ribs for a wing (a constant chord or straight wing) I just cut a whole bunch of rectangle shaped pieces of balsa from the appropriate thickness of balsa sheeting, then stack them, then draw the rib template on the top rib, then cut them out all at once with a bandsaw, or what I do, just take them to a stationary belt/disk sander. Then I cut any spar notches with a razor saw.
There you have it, perfect wing ribs in about 10 minutes. I usually do one wing panels worth at a time, otherwise the stack of ribs gets too thick. I just secure them all together with a few pins.
--Paul
Paul Susbauer is offline Find More Posts by Paul Susbauer
Old May 21, 2002, 12:19 PM
The_Giver is offline
Find More Posts by The_Giver
Master Nursery Builder
The_Giver's Avatar
Canton, GA
Joined Jan 2001
Yep, scrollsaw/bandsaw and a disk/belt sander.
I like this MUCH better than cutting out each individual rib with a knife.
The_Giver is offline Find More Posts by The_Giver
Old May 21, 2002, 11:44 PM
Balsa Builder
Joined Apr 2001
With tapered wings its harder to do the method I described above, but is possible. It would be just as easy to cut each one for a tapered wing.
--Paul
Discussion What scale P-40 for a scratch build? rcsubs Scale Kit/Scratch Built 8 Jun 11, 2006 08:32 PM
Discussion Where do you buy balsa for a scratch build gabe6090 Fuel Plane Talk 9 Jan 13, 2006 10:05 PM
CG for a scratch build? Lift Crazy* Slope 14 Dec 03, 2004 03:03 AM
Plans for scratch build playboy OT-like hobby-lobbys new one mike3976 Parkflyers 1 Apr 28, 2002 07:04 PM
