Old Oct 25, 2005, 01:30 PM
ElSeeker is offline
Find More Posts by ElSeeker
Look out for my plane!
Michigan
Joined Sep 2005
New Tx battery for Optic 6
Does anyone know of any inexpensive battery packs that can be used in the Optic 6 transmitter and have at least 1100 mAh? I would like to be able to fast charge it as well, if possible, instead of the normal 15 hour charge that is required on the standard pack which is 600 mAh.
ElSeeker is offline Find More Posts by ElSeeker
Old Oct 25, 2005, 02:03 PM
Wolpertinger is offline
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
Your best bet is to make up your own from loose cells. Or, you can order packs from places like http://www.cheapbatterypacks.com. I made up my own 8 cell pack from some 2150Mah NiMh, and I easily get 10 hours of operating time from my Optic.
Wolpertinger is offline Find More Posts by Wolpertinger
Old Oct 25, 2005, 02:11 PM
rLu is offline
rLu
Find More Posts by rLu
rLu
Los Angeles
I don't have the Opitc 6, but I have the Elipse 7. I believe 8 AA size batteries also fit into the opitc 6. I use 8 AA size - 2000 mAhr NiMH (Lenmar from fry's electronics) and solder them up with thin copper strips. Wrap it with battery shrink wrap. So far made 2 sets and never run out of juice.
Charge it up with my Triton Charger. I believe 3 to 4 hrs charge time depends on the current setting.
RLu
rLu is offline Find More Posts by rLu
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Here's a 1800 mAh NiMH pack at a great price..
http://www.allerc.com/product_info.php?products_id=116
You should still slow charge it the first few times as new Ni packs need to be formed..
Charles
Old Oct 25, 2005, 04:15 PM
CraigF is offline
Find More Posts by CraigF
Ontario, Canada
Joined Aug 2003
Wow, I only get ~4 hours from some 2300mAh in an Eclipse...I'm presuming battery use is similar... I do think this is a bit low, considering what I get from the stock 600mAh pack...may be time for some cell maintenance. Are you using the synth. module, that really sucks the juice?
CraigF is offline Find More Posts by CraigF
Old Oct 25, 2005, 05:08 PM
Southern Pride
You should get at least 6 hours from 2300s in the Eclispe. Mine does have the synth. module . Current drain is 250 mAh..
My Tranmitter pack Thread :
http://www.rcgroups.com/forums/showthread.php?t=327288
See post # 7 which has actual voltage read outs.
Charles
Old Oct 25, 2005, 05:57 PM
CraigF is offline
Ontario, Canada
Joined Aug 2003
Ah, thanks. I thought the time was getting low, seemed shorter than before... Anyway, I found I have 2 cells that are much lower voltage than the other 6 so maintenance time... The last pack of 1600's I used gave me 4 hours, so something was up with the 2300's, so this post was timely...
Old Oct 25, 2005, 07:11 PM
Canada, BC, Comox
Joined Nov 2003
Hmmm.... maybe I better double check my time. I was fairly positive that's how long I got out of it. And I am using the Synth module. Whatever the actual length, it's plenty, now!
Discussion Battery for Optic 6 TX byhsu Radios 10 Mar 27, 2007 12:28 PM
Discussion Which battery for Optic 6 Tx? avt Micro Helis 0 Mar 27, 2007 02:16 AM
Question: Replacement Battery for Optic 6 kizzy Hitec/Multiplex USA 4 Nov 22, 2005 12:16 AM
have hitech announced any new tx's since the optic 6? Catkicker Hitec/Multiplex USA 5 Jul 28, 2005 06:41 PM
Larger Battery for Optic 6 Tx? Jack Stephens Hitec/Multiplex USA 25 Jun 20, 2005 10:24 PM
