Old Oct 25, 2005, 12:50 AM
thenetpoet is offline
Find More Posts by thenetpoet
Kalamaki, Greece
Joined Mar 2004
Question
whats the best single strator cdrom you ever made?
I've been making home made cdroms for my planes for about a year now.
I'm mostly doing single *** EDIT gobrushlless type *** strators, 22.7mm for my 150-170 grams (AUW) 3D planes, delta wind for 2S packs.
The best performance I've managed so far is :
- 300 grams of thrust @ 7 amps with a 8040 GWS HD prop, and
- 380 grams of thrust @ 10amps with a 7035 GWS HD prop.
What is the best single you have ever made for 3D flying?
Did you notice any significant improvement by using curved magnets instead of flat ones?
Also, did using double or triple strands of wire instead of a single wire give an overall improvement?
thenetpoet is offline Find More Posts by thenetpoet
Old Oct 25, 2005, 09:54 AM
ImaBiggles is offline
Find More Posts by ImaBiggles
Master of 1 point landing
Naperville, IL
Joined Jul 2005
I'm mostly doing single strators, 22.7mm for my 150-170 grams (AUW) 3D planes, delta wind for 2S packs.
It all depends upon the stator design. The gobrushless stators start to heat really quick if you exceed 50-60 watts input, the komodo stators can take up to 120 watts. Your best bet to judge have you are doing is to plug the data in motorcalc - if you are hitting 80-85% eff - you are doing very well.
Multi-stands will do you no good, unless you are attempting to wind really thick wire (<20awg) - then it is just a matter of ease of winding. Multi strands will decrease copper fill and generally increase heat.
Curved magnets may provide better efficiency, as long as the gap is not increased. Stronger mags are better bang for the buck, unless you are using N50's already. Are you just looking at total thrust or prop speed for your criteria? I would assume thrust since you are '3Ding' - in which case I think you are doing just fine for a standard type of stock CD motor.
Off course if you want to diverge from DD, wind one 8 turns 22AWG and put it in a gear box - that will open entire new possibilities for ya.
ImaBiggles is offline Find More Posts by ImaBiggles
Old Oct 25, 2005, 10:38 AM
Kalamaki, Greece
Joined Mar 2004
Thank you for your answer.
My question was intended to compare my motors performance to other similar motors so that I see if there is room for improvement.
My strators are the gobrushless type and I found out (as you also mentioned) that 70W is almost the safest maximum per strator without fear of shorting the wires or damaging the magnets.
I'm mostly interested in thrust because of 3D and generally I decided to avoid gearboxes (at least for now) and stay DD because of the extra components and noise of the gearbox. That said, I'm following the "cdrom and gearbox" thread to keep up to date with what is possible and perhaps at a later time I'll experiment with a GB.
Old Oct 25, 2005, 10:44 AM
Boss248 is offline
Find More Posts by Boss248
ProBro # 501
Boss248's Avatar
Austin Tx
Joined Jul 2005
Can you post the link for the gearbox/cdrom thread you have been following.??
Boss
Boss248 is offline Find More Posts by Boss248
Old Oct 25, 2005, 11:15 AM
Malves is offline
Find More Posts by Malves
Joined Jun 2004
GBx1/23T/26g/Y/3s/9x5DD = 480g @ 8.5A
Malves is offline Find More Posts by Malves
Old Oct 25, 2005, 11:44 AM
Kalamaki, Greece
Joined Mar 2004
http://www.rcgroups.com/forums/showt...cdrom+gearbox+
Old Oct 26, 2005, 04:15 PM
galloping gimp is offline
Find More Posts by galloping gimp
galloping gimp's Avatar
Ohio, USA
Joined May 2002
Just for clarity, in case any newbies are following this thread, the word is "stator" not "strator."
- Jeff
galloping gimp is offline Find More Posts by galloping gimp
Old Oct 27, 2005, 01:38 PM
jj1 is offline
jj1
Find More Posts by jj1
jj1
jj1's Avatar
Finland
Thats a nice GBx1, Malves,
have made only 1 GBx1 sofar: 19T/24g/Y.
Little more thrust but also more wasted energy ...
...heats little with 8" props at long periods WOT.
Kv ~1700
Readings below from cold motor.
Volt Amp Thrust Prop
11,2V 4,8A 350g 0735
11,8V 10,0A 560g 0804
10,6V 10,0A 550g 0843 eff ~64%
-JJ
jj1 is offline Find More Posts by jj1
Old Oct 27, 2005, 02:21 PM
Ohio, USA
Joined May 2002
Malves -
Very nice!
I have GBv single stator with the same wind. I know it won't be as good as your GBx, but it will be interesting to see how it compares. I have not measured its performance yet.
All of my GBx motors have been double stators, which are dandy motors.
- Jeff
Discussion Whats the wierdest thing you've ever made fly?? TDisaster Electric Plane Talk 51 Apr 09, 2008 01:48 PM
Discussion WHats the best flying time for you? BowerR64 Micro Helis 13 Jun 04, 2007 10:20 PM
Whats the best soaring flying wing model ever? hardlock Modeling Science 13 Nov 21, 2005 04:18 PM
Whats the best price you have seen for GWS flight pack? AMTJIM Electric Plane Talk 7 Feb 09, 2002 02:07 PM
