Old Oct 24, 2005, 04:25 PM
kizzy is offline
Find More Posts by kizzy
Joined Sep 2005
Radio Shack 12vdc Cigarette Lighter to Banana Jacks Adapter
This converts the cigarette lighter in your car to banana jacks. Could I use it to safely power my Hobbico MKII charger?
http://www.radioshack.com/product/in...tId=2102439&cp
My battery packs are 7-cell 8.4v 1150mah NIMH's, and I charge them usually at the 0.8A setting. So even if I were to charge both at the same time, my total power draw would be less than 2A. Should my cigarette lighter (and car battery) be able to handle this?
kizzy is offline Find More Posts by kizzy
Old Oct 24, 2005, 05:05 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
That will work just fine.
Bill
ebill3 is offline Find More Posts by ebill3
Old Oct 24, 2005, 05:39 PM
Ghost 2501 is offline
Find More Posts by Ghost 2501
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
having seen it, it converts ur hobico to something along the lines of my ansmann unit battery charger from the cig lighter of the car
http://www.ansmann.de/en/index.htm?view=list&pr2id=14
Ghost 2501 is offline Find More Posts by Ghost 2501
Old Oct 24, 2005, 06:22 PM
Popsflyer is offline
Find More Posts by Popsflyer
Oldie but goodie
Popsflyer's Avatar
United States, CA, Orange
Joined Jun 2003
Gadget Shack (Radio) also sells a lighter plug that you can wire up yourself, then add whatever connector you need on the other end. I have one of my older chargers set up this way.
12VDC Cigarette Lighter Adaptor Plug
Popsflyer is offline Find More Posts by Popsflyer
Old Oct 24, 2005, 06:43 PM
kizzy is offline
Joined Sep 2005
Just got back from there now...picked up the 12vdc adapter with banana jacks (Radio Shack #270-1521) for $7.99. Should do the trick. Planning to keep the amp load on it down to a minimum though, so as to not fry my cigarette lighter wiring.
Old Oct 24, 2005, 07:46 PM
kizzy is offline
Joined Sep 2005
OK, I tested out my MKII with the Radio Shack adapter. Charged up one of my 7-cell 1150mah packs to its peak. Worked perfectly, with no noticeable drain on the car battery. It started right up as usual, but I did let the engine run for a few minutes afterward to let the alternator restore any used amps. Even so, I really can't see that the charger used any more power than simply listening to the radio would have done (probably less).
Radio Shack banana plug problem ch2s Electric Plane Talk 7 May 25, 2004 08:29 PM
On/Off Charge Jacks from Radio Shack parts thelocust Slope 2 Dec 10, 2003 07:02 PM
Radio Shack USB joystick adapter. HankF Simulators 0 Jul 23, 2003 02:46 PM
Question Radio Shack Jacks efurche Batteries and Chargers 1 May 25, 2003 04:29 PM
Cigarette lighter adapter for Astro 110D houdini Batteries and Chargers 8 Dec 20, 2002 04:53 PM
