Old Feb 10, 2013, 09:32 PM
Peter Mack is offline
Find More Posts by Peter Mack
Mack
Peter Mack's Avatar
Australia, VIC, Mentone
Joined Jun 2004
Originally Posted by 3d astronaut View Post
I am running the spektrum ar6400 brick, well a clone that you can get for $25 online and then the brushed p51 motor. Comes in at 38.xx grams and flys like a beaut!
Great work 3D, and to the others who have been successful with the Acro Bipe. Looking back, my failure was almost certainly due, at least partially, to a rearward CG position, so the advice provided in the above posts should help those new to the model. The AR6400 or HK Orange Rx plus 1.7 gm servos, with a geared 8mm motor would be the way to go if I ever try again.
Peter Mack is offline Find More Posts by Peter Mack
Old Feb 10, 2013, 09:55 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
It seriously flies a treat Pretty much the same speed as the champ, I also use a 300mah 1s battery for 8 or so minutes of flight time. Its a tad bit slower with the 160mah pack but not that much of a difference. Gotta love these old birds!
3d astronaut is offline Find More Posts by 3d astronaut
Old Feb 17, 2013, 04:17 PM
Tankogen is offline
Find More Posts by Tankogen
Tankogen's Avatar
USA, AZ
Joined Jun 2010
Well I want a few more of these. TO learn on etc. Here is a couple full flights with park 250 motor.
Acrobipe Park250 Nov. 2012 The Hollies Fpv 2.4ghz (3 min 27 sec)
Acrobipe.Park250.2.4ghz.Fpv.72mhz (5 min 32 sec)
Tankogen is offline Find More Posts by Tankogen
Old Mar 13, 2013, 10:25 PM
Tankogen is offline
Tankogen's Avatar
USA, AZ
Joined Jun 2010
I enjoy love flying mine with HD key chain cam or not, but park 250 wow the power with 2 cell 360 mah lipo and 10amp esc. I found one on ebay, but wish to know 1st- where can these still be purchased? Is there a way to get someone to sell it again?
Its very crash resistant even at over 20mph. Love fast flying!
P.s. Thanks
Old Mar 15, 2013, 05:51 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
used to be on hobbyking. i got mine a year ago or so. it was called the 'acrobipe'. came with 3700kv 2s bl motor and esc. i flew it on 1s with real gws prop(stock one sucked bad).
one thing to keep in mind, this plane has massive torque roll. if you get a warped upper wing, consider building it with the twist in it, as it appears HK shipped the warped wing that would IMPORVE the flight. WMMV.
i built the twist out of it, and regretted it.
nemoskull is offline Find More Posts by nemoskull
Old Mar 15, 2013, 09:05 PM
Joined Sep 2011
Haha I took out some of the twist and was really worried about it still being in the wing.. It actually flies better than my original harbor freight conversion
Old Mar 18, 2013, 01:26 AM
Tankogen is offline
Tankogen's Avatar
USA, AZ
Joined Jun 2010
Here is some video
Recent footage and some crashes, and speed runs
AcroBipe FunCraft Crashes (12 min 0 sec)
Old Jul 12, 2015, 07:52 AM
Spring is offline
Find More Posts by Spring
CH Spring
Canada, ON, Osgoode
Joined Mar 2008
Just when you guys thought we were done with this thread
This is my version. Just completed it.
Recently my brother handed off two kits NIB, plus all the running gear save rx.
I used a Spektrum 400. To get it in I had to take the pilot out.
With a 2s 610 mah battery the AUW is 4.15 oz.
I would love to fly it today but the winds are not suitable.
Cheers!
Spring is offline Find More Posts by Spring
Old Jul 12, 2015, 10:56 AM
Janusz Jawien is offline
Find More Posts by Janusz Jawien
Janusz Jawien's Avatar
Los Angeles Van Nuys, California, United States
Joined Apr 2002
Make sure to have minimal travel on ailerons - it is easier to make big , lazy circle than small violent one...;-0
Good luck!
Janusz Jawien is offline Find More Posts by Janusz Jawien
Old Jul 12, 2015, 11:02 AM
Spring is offline
CH Spring
Canada, ON, Osgoode
Joined Mar 2008
Janusz.
I have my DX9 set up with 3 rates for ailerons. I have 100%, 50%, and 25%. My default position is 20% expo.
I will likely do the first take-off with 100% on everything. Once I get away from the ground I can sort trims and rates. At least that is the plan. I left the original dihedral in. That could be a factor in roll control.
I get what you are saying though, these things do not require much aileron deflection. No doubt the same is true with elevator.
I'll let you know how I make out.
Cheers!
Old Jul 13, 2015, 06:14 AM
jhspring is offline
Find More Posts by jhspring
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
LOL, that was quick. Break a leg, brother. J
jhspring is offline Find More Posts by jhspring
Old Jul 13, 2015, 10:57 PM
Ricomon is offline
Find More Posts by Ricomon
Ricomon's Avatar
USA, SC, Charleston
Joined Oct 2002
I built one of these with RET using a WLToys V911 heli brick and a Hobby King 8.5mm gearbox. It flies OK, but it's not my cup of tea. The elevator is at its shortest throw and very sensitive. It'll slow down like a Champ, but if I fly slowly, the rudder is pretty dead feeling. If I fly fast, the rudder is OK, but I fly mostly in the street in front of my house, and I run out of sky too fast.
Here's the maiden flight from a few weeks ago.
Funcraft Acro-Bipe R/C Conversion Maiden Flight (1 min 37 sec)
Rick
Ricomon is offline Find More Posts by Ricomon
Acro Bipe and RFFS-100 dhurd Scratchbuilt Indoor and Micro Models 89 Jun 03, 2003 05:26 AM
Fyi about Acro Bipe and Viper. Wilber Scratchbuilt Indoor and Micro Models 6 Apr 26, 2002 04:34 PM
Acro-Bipe (Firefly-powered) Greg Covey Scratchbuilt Indoor and Micro Models 24 Apr 10, 2002 12:56 AM
Acro Bipe Wilber Scratchbuilt Indoor and Micro Models 7 Apr 05, 2002 01:47 PM
Store of Wonder Acro Bipe? Acer Scratchbuilt Indoor and Micro Models 9 Apr 04, 2002 10:08 AM
