Oct 26, 2005, 10:54 AM
Salt Lake City
Joined Sep 2004
The power was Axi 2212/34, used an 11x7 prop, which I think I like better than a 12x6 that I also tried. Batteries - TP 1320 3-cell lipo, also 1500 and 1700 mAh 3 cells work fine. CC PH35 ESC. I have Hitec H56 servos on the ailerons (1 for both ailerons) and rudder, and a Eflite servo on the elevator. I like the HS56's as I'm always accidentally backdriving my servos when I fit the plane in the old Miata.
The plane has a wide fuse so that must be why it knife-edges well. It hovers almost as well as my FoamtanaS, although it's a little smaller. I'm building another Foamtana and I will get a little more motor on that one. But the Hammer is really great for flat rudder turns, and the rudder is tons of fun. There is the typical weak point at the back of the wing, I have braced it with flat carbon fiber strips down the outsides of the flat fuse sides after a crack.
The blue fff is toughter than Depron, not as brittle. But Depron is nicer to work with.
This Hammer has a special adaptation on it that I plan on testing soon.
