| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 |
Using my car charger as a power supply question
Ok..Im about to try out some lipos. The pack is 11.1v 1000mah and has 3 cells in the pack. My lipo charger is a DC charger with spec input 12 - 15 v input and output .8A. My question is if I want to use it in the house, I do have a car battery charger with rating 12v 2A, 12v 6A, and 6v 6A, which one should I select and is it ok to use. Thank you all.
#2 | |
I gather Radio Shack have a sale at the moment on a suitable supply, otherwise there are several 13.8v DC supplies around or even a modified old PC PSU may be used. Look it up on the Internet -- Steve |
#3 |
Wow...I guess these lipos really is sensitive. I do have a couple old pc ps, is there a guide here showing which wires to use or any modifications to it? Thanks again.
#4 |
Cat5,
Go to rcbatteryclinic.com. They will show the whole conversion. By the way, for the load on the 5volt line, get a 1ohm 10 watt resistor from Radio Shack. Little light bulbs don't cut it. You'll see after you read. |
#5 |
How about using an automotive lead acid battery to power a lipo charger WHILE simultaneously using a car battery charger on the lead acid battery? Note, the car battery charger leads and lipo charger input leads are connected to the lead acid terminals, not each other.
#6 | |
http://pinouts.ru/data/atxpower_pinout.shtml You will need to take pin14 (Green Wire) down to Ground to activate the PSU |
#7 |
Thanks all. will check it out or I just have to buy an ac charger or charge up by car battery and use it
#8 |
Ay up it's warped
I use the car battery charger and a leisure battery. That way if it is a nice day I can take the leisure battery to the field with me to re-charge whilst flying.
#9 |
B717,
I have been using the battery, charger combo for 4 years with 2 schutz 330's charging up 60 cells 3 times a day during boats races leaving the charger on all day. The only trick is to use a good charger (Schumacker in my case) that won't take the deep cycle battery above 15 volts, about 8 amps in my case. Works Great!! |
#10 |
Replikit Designer
I got a S/H ex CB power supply off Ebay. Thats used to do teh mains stuff. Was not expensive.
I have a BIG battery in my landrover. Enough to charge several packs several times. The club field is 15 miles way - plenty of time to top it off... ![]() Have a look here.. http://electronics.search.ebay.com/1...erQ20supplyQ29 Last edited by vintage1; Oct 22, 2005 at 11:50 AM. |
#11 |
Thanks Jim (twice)
#12 |
so you cant use a car battery charger ??.
then what ?. |
#13 | |
Bill |
#14 |
what about the power supply from hobby lobby
110ac convert to 12dc the fma one near bottom of page. http://www.hobby-lobby.com/chargers.htm#Supply |
#15 | |
Tom Moody |
| Thread Tools | |
| Question Using a car battery charger as a power source. What's the problem. | Boeingdvr | Batteries and Chargers | 11 | May 05, 2006 08:38 PM |
| Astro Charger as a Power Supply | Jim Keller | EFLIGHT Mailing List | 2 | Dec 01, 2003 07:03 PM |
| Using Automotive battery charger as a power supply? | DRR | EFLIGHT Mailing List | 3 | Nov 13, 2003 07:02 PM |
| Battery car charger used as a power supply?? | Sylvain | Batteries and Chargers | 7 | Feb 19, 2003 10:17 AM |
| using a car battery charger as a power source? | foss1997 | Power Systems | 14 | Jan 10, 2002 10:56 AM |
