Old Oct 21, 2005, 08:46 AM
Jack Hyde is offline
Find More Posts by Jack Hyde
USA, CA, Red Bluff
Joined Jun 2000
hacker 20 motor mount and prop mount
Would someone please guide me to where I can learn about how to mount a hacker 20-22 on a plane with a stick mount (Fancy Foam Edge)? I would also like to learn about options for mounting props with the various adaptors provided with the motor. Is there some way to mount GWS 1047sf props? I have all of this new stuff and not a word about how to use it correctly. I have been using a Himax 2015-4100 with gearbox and stick mount.
Jack Hyde is offline Find More Posts by Jack Hyde
Old Oct 21, 2005, 09:26 AM
guyaneze is offline
Find More Posts by guyaneze
guyaneze's Avatar
gainesville FL
Joined Jan 2002
hola senor,
ju need to git u one of these pardner:
http://www.stevensaero.com/cart/cart...category_id=71
eet weell mount your hacker a20 on a gws stick perfectly....stephens aero isn't the only one that carries em...look around....I googled and found that....i picked one up at a funfly earlier this year....its made by hacker or distributed by the hacker usa peeps....so wherever u got your motor they should be able to get em.
mounting gws 1047 props....ouch ouch...use an apc prop till i find ya an answer....how i did it?....i bought a prop saver....
well...i can't remember where i got it...but u can get one from balsapr...
like this....
http://www.balsapr.com/common/search...ductId=V830125
get one to match the shaft diameter of your motor....i think its 3mm...but don't take my word for it.
this is a list of what balsapr has...
http://www.balsapr.com/catalog/searc...ufacturerDBID=
himaxx makes one...and hyperion makes on....other manufacturers might also make em....
enjoy the weekend...stay out of wilma's path.
guyaneze is offline Find More Posts by guyaneze
Old Oct 21, 2005, 11:33 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Is that a geared B20 or an outrunner A-20?
Top Creations has several stick mounts available.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Oct 21, 2005, 11:52 AM
USA, CA, Red Bluff
Joined Jun 2000
a20-22 mount
It is the A20-22L model. I got it for another application but thought I would like to try it out on a plane I have ready to go. The plane is a Fancy Foam Edge, 15 oz.
Old Oct 21, 2005, 11:55 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Then the "small AXI 22xx mount" from www.topcreationsrc.com will be fine.
Old Oct 23, 2005, 05:44 PM
Rumple is offline
Find More Posts by Rumple
Ignint McNugget
Rumple's Avatar
behind Jaggi lines
Joined Jan 2004
The Cobri rotating case mount from http://www.e-flightline.com/ would also fit and would put the motor below the stick (in the same position your Himax was in). This may shift your thrust line down slightly, not sure if that matters.
Rumple is offline Find More Posts by Rumple
Hacker B20 Motor Mount Ralph A. D'Amelio Power Systems 10 Feb 28, 2008 09:23 AM
For Sale Himax 20-25-3200 motor, spinner, prop, mount Ebolavoodoo Aircraft - Electric - Power Systems (FS/W) 0 Jul 27, 2007 10:12 PM
For Sale AXI 4130/20 Jeti ESC, motor mount, prop mounting kit be69ar Aircraft - Electric - Power Systems (FS/W) 7 Jul 23, 2007 01:11 PM
Help! Wanted-Hacker A30 motor mount and prop mount Fred Bronk Electric Heli Talk 2 May 16, 2007 11:47 AM
M-20 and N-20 Motor/Gearbox/Prop Test Results cybermike Scratchbuilt Indoor and Micro Models 27 Jul 30, 2003 11:03 AM
