Old Oct 19, 2005, 01:58 AM
zumzum5150 is offline
Find More Posts by zumzum5150
Joined Aug 2005
Sirio Oneway bearing
Hi guys,
I have a problem with the oneway bearing thats on the Sirio 12. The oneway refuses to grab the pullstart shaft after a full tank of fuel has been digested. I'm on the third tank and each emptied tank I've had to dismantle the pullstart to get to the bearing. The bearing will grab once the excess oil has been cleaned off. The motor sounds great. It starts and idles perfectly. Am I experiencing this problem do to the fact that its still being broken in and running rich? A buddy suggested that I switch over to 30%. I'm thinking of just changing the oneway with a stock or after market bearing. Is anyone having problems with their sirio 12s oneway. Are you guys using 20% or 30% for this motor? The bike is almost complete. I am just waiting for the fail safe and batteries to arrive.
Steve
zumzum5150 is offline Find More Posts by zumzum5150
Old Oct 19, 2005, 04:31 AM
pat1967 is offline
Find More Posts by pat1967
Australia
Joined Sep 2003
Hey Steve,
EVERYONE has experienced the same problem with the oneway bearing on the sirio, it's put simple a crap bearing. You need to replace it with a branded bearing. What you're looking for is a 10mm OD x 6mm ID x 12mm one way bearing. Be carefully when ordering, some have a HEX outer shell, these ones wont fit, you need the one with a round outer shell.
Part # 6392K22 from www.mcmaster.com
As for fuel, I ran the sirio in on 5%, then after a few tanks 16% nitro:11% oil.
You'll want to change the glow plug to an OS A3. Personally I feel the motor is fine for learning the limits of the bike and getting used to controlling it, and worth the $15 to replace the one-way. Before long though you'll be itching for a little more torque and top end, that just wont be there. By then the engine will probably be nearing the end of it's life anyway, and it'll be time to get something higher end, like an OS, REX or NR
HTH
Pat
pat1967 is offline Find More Posts by pat1967
Old Oct 19, 2005, 04:48 AM
metomwhou is offline
Find More Posts by metomwhou
metomwhou's Avatar
United States, CO, Colorado Springs
Joined Jan 2004
That helps Pat!! What are you running now? I'm thinking of putting in the Force .12 I've got since I can't use it on the TTN.
Tom
metomwhou is offline Find More Posts by metomwhou
Old Oct 19, 2005, 05:04 AM
pat1967 is offline
Australia
Joined Sep 2003
Hi Tom,
I've still got the sirio sitting in the bike, I haven't had a chance to run it over the past few weeks so I haven't been too worried about it. It still runs, but has absolutely no top end, it splutters and gurgles away. I'm sure the piston/liner is shot, the motor is really loose once it warms up.
I've got a couple of force 12's here, and as soon as I get around to making a set of mounts one will be going in, if I can't find a reasonably priced REX between now and then.
Pat
Old Oct 19, 2005, 05:15 AM
metomwhou's Avatar
Joined Jan 2004
Ah, thats right, the Sirio mounts to the chassis through the starter. I forgot about that, I'll probably have to order a set myself at some point, but its about to get pretty cold here so I think I have some time to spare!
Tom
Old Oct 19, 2005, 10:06 AM
Joined Aug 2005
Hey Pat,
Very helpful indeed. I appreciate you giving the part# aswell. I've gone and ordered the part and should arrive next week. For now, break-in procedure will just have to be monotonous. As soon I get this to move about I will need to order you disk breaks. Do you sell them only in sets? I only need the rears.
BTW: Can I just hammer out the old needle bearing when installing the new one?
steve
Originally Posted by pat1967
Hey Steve,
HTH
Pat
Old Nov 05, 2005, 07:21 AM
metomwhou's Avatar
Joined Jan 2004
I just wanted to add that the TT OWB seems to be the same as the one Pat mentioned for the Sirio. I'm gonna order one and I will let you know. BTW, anybody know how to remove the bearing from the TT unit? It seems like its pressed in there pretty good, I was thinking of putting it in the oven for a little while but someone here mentioned that I should try and freeze it. I thought the oven would make the metal expand and the bearing would come out easier but this guys says the bearing will expand too? Whats the consensus here?
Tom
Old Nov 05, 2005, 08:10 AM
mollycbr123 is offline
Find More Posts by mollycbr123
STeve B in NC
mollycbr123's Avatar
North Carolina, USA
Joined Sep 2003
Tom, I haven't had much luck removing bearing by freezing, but I have gotten various bearings out, including a press fitted OWB from one of my crappy rotostarters, by boiling them.
just my experience. HTH
mollycbr123 is offline Find More Posts by mollycbr123
Old Nov 05, 2005, 09:40 AM
Joined Aug 2005
Don't know how easy it is with the TTN but with the sirio I was able to gently tap it out. If you plan on ordering the part from MCMASTER-CARR the part # is
6392 K22. Let the rep know that you need the rounded outer shell one.
Old Nov 05, 2005, 01:50 PM
STeve B in NC
North Carolina, USA
Joined Sep 2003
Just eyeballing my TTn is the part that's getting broken the bearing itself, or a retainer for the bearing? If it's a retainer, why would the McMaster bearing help?
STeve B (ain't broke it yet) in NC
Old Nov 05, 2005, 07:39 PM
slawsonb is offline
Find More Posts by slawsonb
Bruce
Palmdale, CA
Joined Sep 2005
The part that breaks is the retainer for the bearing.
slawsonb is offline Find More Posts by slawsonb
Old Nov 05, 2005, 07:59 PM
metomwhou's Avatar
Joined Jan 2004
can you post a picture of what is breaking? I thought it was the bearing itself.
Old Nov 05, 2005, 08:15 PM
slawsonb is offline
Bruce
Palmdale, CA
Joined Sep 2005
Here is the broken TTN thingee that goes around the bearing. Sorry about the quality; camara phone.
Old Nov 15, 2005, 09:27 AM
metomwhou's Avatar
Joined Jan 2004
Just an update, the bearings from McMaster that Pat mentioned are exactly the same as what comes with the TTN. We still need to see a pic of that homemade ring from an axle spacer.
Tom
Old Nov 16, 2005, 05:52 AM
Tom H is offline
Find More Posts by Tom H
richmond, va.
Joined Nov 2005
Owb
just bought 3 of the OWB from my LHS yesterday, they got the parts from Ace, i paid 8.99 each. have'nt had bearing problem, just breaking the ring.
Tom H is offline Find More Posts by Tom H
Sold 12V starter Oneway bearing hex starting wand,con yttutty Aircraft - Fuel - Helis (FS/W) 2 Jun 06, 2005 06:53 PM
oneway bearing for the corona- Buy it here eytan Electric Heli Talk 1 Jul 27, 2002 11:59 AM
Corona - oneway bearing - mission completed. eytan Electric Heli Talk 7 Jul 22, 2002 11:55 PM
Longer main shaft for Corona oneway bearing mod eytan Electric Heli Talk 11 Jul 17, 2002 01:08 PM
Corona-oneway bearing eytan Electric Heli Talk 3 Jul 06, 2002 07:02 PM
