Old May 18, 2002, 07:32 PM
frankenfoamy is offline
Find More Posts by frankenfoamy
Strange Plane Central
frankenfoamy's Avatar
Poway (near San Diego), CA US
Joined Dec 2000
Prop saver for GWS props
GWS prop saver.
The GWS props have a recessed hole that keys to the nut on the shaft.
Due to this Keying, the retention part does not need to be non moving.
I made a prop saver using one servo arm, one rubberband and one nut.
Check the tips section on my page
frankenfoamy is offline Find More Posts by frankenfoamy
Old May 19, 2002, 06:04 PM
erashby is offline
Find More Posts by erashby
Flying Free
erashby's Avatar
Utah
Joined Aug 2001
Couldn't get the link to work. Can you post pictures and describe?
erashby is offline Find More Posts by erashby
Old May 19, 2002, 06:14 PM
Joined Dec 2000
site temporarily down due to bandwidth consumption.
It will be up in less than two hours.
The picture is too big to post. That is why I placed it on my page.
It is so simple you will shoot yourself that you did not think of it
Old May 19, 2002, 10:01 PM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
It looks kinda like this one but different.
Picture originally posted by tim_j-rome in this thread:
http://www.rcgroups.com/forums/showt...threadid=20421
Basketcase is offline Find More Posts by Basketcase
Old May 20, 2002, 12:09 AM
WrongwayFeldman is offline
Find More Posts by WrongwayFeldman
Joined Jan 2002
Basketcase...where do you get...
those small rubber bands! I remember back when dental braces were "in vogue" you could get them where ever dental products were sold, I looked at our local grocery store and at a pharmacy, but no luck. Also, does the nut behind the servo arm need to fit in the recessed servo arm hole?? I need to build a prop saver (because I fly so well ;-) ) but the prop nuts are too large to fit inside the recessed part of the mounting hole on the arm I would like to use, can I just use a washer and tighten the nut against the arm?
Inquiring "prop busters" need to know ;-)
Thanks for any suggestions!
Mark
P.S. I posted a new thread regarding my question above by mistake, please disregard if you see it :O
WrongwayFeldman is offline Find More Posts by WrongwayFeldman
Old May 20, 2002, 01:50 AM
Joined Dec 2000
The rubber bands I use are from the pet store.
They wrap them around the plastic bag you get fish or crickets in.
Old May 20, 2002, 03:48 AM
ybanrab is offline
Find More Posts by ybanrab
Teddington, UK
Joined Dec 1996
Very nice and simple idea. I shall do that on the next GWS powered plane I do.
ybanrab is offline Find More Posts by ybanrab
Help! Prop Saver for GWS Schnupper Power Systems 4 Jan 02, 2007 06:20 PM
New Prop Adapters for GWS Props and Johnson motors! Acer Foamies (Kits) 10 Sep 10, 2004 09:02 PM
Bob Selman Designs Prop Adapters for GWS 4mm Bore Props Gordon Johnson Scratchbuilt Indoor and Micro Models 17 Mar 31, 2004 12:08 PM
Idea Prop adapter for APC Props on GWS G-Boxes PaddyinDublin GWS (Grand Wing Servo) 8 Mar 11, 2004 04:27 AM
Prop saver for GWS IPS systems GHarvey Parkflyers 10 Oct 10, 2002 11:23 PM
