Go Back   RC Groups > Aircraft - Electric - Airplanes > Parkflyers
Old Oct 18, 2005, 11:59 AM   #1
Mr.RC-CAM's Avatar
ParkZone Stryker & P-51: Finally, a Painless Brushless Upgrade!
PowerZone Brushless Adapter Project Updates:
10-29-2005: PowerZone price & ordering info is found here: Click For Details.
10-18-2005: Stryker/P-51 instructions are found here: Click Me.
08-08-2006: Generic installation instructions are found here: Click Me.
10-28-2005: Blade Micro-Heli Brushless tailrotor conversion project: Brushless Blade E Z Upgrade
10-30-2006: Photos that show how to install the PowerZone into a Walkera micro heli are posted here (these photos are helpful in other model heli installations too): Brushless Walkera Upgrade
12-12-2006: Brushless heli users that experience an odd high-stick throttle problem should contact me for the free V1.2 firmware upgrade. Details: Blade Cp Brushless Problem
02-01-2007: Version 1.3 now available. New DSP filtering eliminates glitchy operation on models that have "noisy" ESC signals.
11-11-2007: Yes, PowerZone is still available.
Start of original discussion:
What if I said that you can upgrade your Stryker/P-51 to brushless *without* replacing the ParkZone R/C system? You know, keep the servos and Rx and just slap on a new brushless motor and controller. Fast and easy. And the X-Port interface still works, so you can still use the popular combat module and other X-port accessories. How does that sound?
All it takes is a little interface board that is slightly bigger than a US dime. The board has a standard servo connector on it that the Brushless ESC plugs into. It also has a single wire that goes to the original black motor lead. That is all there is to it. You can use any regular Brushless ESC that has a BEC (the popular Phoenix 25 is a reasonable choice for these models).
I'm working on pricing (it will be under $30 or so) and I will be releasing it in a few days. In the meantime, let's have a contest to name the new brushless interface board. Keep in mind that it is small, easy to use, and works only with the ParkZone Stryker and ParkZone P-51 R/C system.
So far I'm leaning towards "JetPac." However, I'll bet one of you folks can do better. If I use your name entry, you will earn one of these little boards at no charge (Free, nada).
For more name-it inspiration, below is a photo of the brushless interface board.
  • Name: pcb1.jpg
Last edited by Mr.RC-CAM; Nov 12, 2007 at 02:24 AM. Reason: Added Firmware Upgrade Info
Mr.RC-CAM is offline Find More Posts by Mr.RC-CAM   Reply With Quote
Old Oct 18, 2005, 12:13 PM   #2
It sounds great. I assume you have tested it? I don't get how it works tho because the ESC that is connected to the RX in the stryker will try to LVC too late right? Or does the brushless ESC override it?
I'd have to see it completely hooked up but if it works, that's pretty cool.
Travy is offline Find More Posts by Travy   Reply With Quote
Old Oct 18, 2005, 12:35 PM   #3
I'll start...
Speedzone
Zonelink
ZoneControl ( I kinda like that one best)
I'm sure I can think up a few more.
Neat idea, BTW. Out of curiosity could this thing convert a normal (ie. Castle Creations) ESC to handle a brushless?
rutat is offline Find More Posts by rutat   Reply With Quote
Old Oct 18, 2005, 12:47 PM   #4
Mr.RC-CAM's Avatar
The LVC is actually determined by the new brushless ESC's settings. FWIW, the early ParkZone Rx's did not seem to have a true LVC and will operate down to very low voltages (mine goes below 5V). The newest Rx's have a LVC that provides 5.7V and 8.8V cutoffs. Just set the Rx jumper to 5.7V and program the intended LVC into the ESC instead. BTW, do not exceed a 3-cell LiPO or the servo life might be reduced.
All the features of your chosen brushless ESC are still supported. Things like LVC, prop braking, softstart, and the like, all work according to the ESC's original instructions.
It is specifically designed for the special R/C system that is used on the Stryker and P-51. ParkZone may introduce more models with this particular radio system, but until then, that is all it will work with.
Old Oct 18, 2005, 12:48 PM   #5
hlondono111's Avatar
How about:
parkzone speedfreak
hlondono111 is offline Find More Posts by hlondono111   Reply With Quote
Old Oct 18, 2005, 04:05 PM   #6
Mr.RC-CAM's Avatar
Those are some great product names! Keep 'em coming. I'll keep the contest open for a few days and then announce a winner.
Old Oct 18, 2005, 04:22 PM   #7
FLYWINGFAN's Avatar
Send a message via AIM to FLYWINGFAN
Awesome!
P-Link
Turbo-Link
EZ-UpgradeLink
P-Converter
Saver-Link
PZ-linx
Sam
FLYWINGFAN is offline Find More Posts by FLYWINGFAN   Reply With Quote
Old Oct 18, 2005, 04:24 PM   #8
Afterburner
Hot Button (based on size)
Hot Zone
Old Oct 18, 2005, 04:32 PM   #9
I JUST want to FLY!
JustFly's Avatar
Send a message via AIM to JustFly
How about Outa'-the-parkzone
JustFly is offline Find More Posts by JustFly   Reply With Quote
Old Oct 18, 2005, 05:18 PM   #10
Moncho
Brushmax
Ultimax
Minimax
(I like the -max suffix)
Moncho is offline Find More Posts by Moncho   Reply With Quote
Old Oct 18, 2005, 06:33 PM   #11
Go Tide!!!
gouda's Avatar
BIT
(Burshless interface technology)
OGMD (OGGMOD)
(Upgradeable motor device)
gouda is offline Find More Posts by gouda   Reply With Quote
Old Oct 18, 2005, 07:22 PM   #12
How about Pro-Pack. Since it take a proprietary system and coverts into a power packed system.
Alternatively
Speed Plus
Flug plug
Jet Chip
And to steal a little from gouda
Bit Chip
Congrates on showing some excellent ingenuity
defcon1 is offline Find More Posts by defcon1   Reply With Quote
Old Oct 18, 2005, 07:24 PM   #13
Brushcutter
Brushminator
C U Later
Above the Brush
Brushstryker
Brushless Park
Caliber5 is offline Find More Posts by Caliber5   Reply With Quote
Old Oct 18, 2005, 08:00 PM   #14
Prying Open My Third Eye
slo_dave's Avatar
How about
The Lipogater
slo_dave is offline Find More Posts by slo_dave   Reply With Quote
Old Oct 18, 2005, 08:04 PM   #15
on a vacation
Silent's Avatar
Originally Posted by slo_dave
How about
The Lipogater
YEAH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Nice!
Silent is offline Find More Posts by Silent   Reply With Quote
EPP P-51 w/020 brushless Inferno Foamies (Kits) 1 Dec 24, 2007 09:12 AM
Yippee! GWS P-51 Finally Works with Stock config ksubram295 GWS (Grand Wing Servo) 0 Feb 12, 2004 03:02 PM
Flight Video : GWS P-51 + Razor-400 Brushless Foam Crazy Parkflyers 18 May 04, 2003 11:38 PM
Stealth P-51 finally done Deltawing Parkflyers 9 Jan 29, 2003 12:17 AM
GWS P-51 HELP..on Brushless setup Doc Dyer Parkflyers 4 Jan 27, 2003 11:55 PM
Congratulations SimpleM!
