Jul 23, 2001, 02:52 PM
Walled Lake, MI, USA
Joined Feb 2000
Rather than "permanently" attaching the wings, which will only cause more extensive damage in future crashes, there are other options in addition to Fred's suggestion to make the chopsticks fit more firmly in the mounts. You could use a little rubber-type cement, which remains flexible and will pull apart in an impact. Or you could use a couple of small pieces of tape. Thousands of R/C flyers over the years have proved conclusively that not allowing the wing to pop off in a severe impact will result in more damage to the aircraft.
