Old Apr 20, 2001, 10:09 PM
Sal C is offline
Find More Posts by Sal C
Giddy up!
Sal C's Avatar
Woodridge, Illinois
Joined May 2000
Bungee Hook - constructed of?
I've been reading some of the posts on bungee launching and I'm building a pedal launcher.
My question is what is the best way to make a hook to mount on the plane? How do attach it?
I was thinking of using music wire doubled up and bent to form a hook. My plane (a foamie) has coroplast doublers and I was planning on fixing the hook to the coroplast bottom. Think this will work?
http://albums.photopoint.com/j/View?...562&p=46940909
Does anyone have photos of their arrangements?
Sal C is offline Find More Posts by Sal C
Old Apr 20, 2001, 10:42 PM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
I use 1/8" L-screws which are screwed into a hardwood block which is embedded into the model. The block is usually 2-3" long and 1/2" thich. The width is not critical so 1/2" there is fine.
I use this arrangement on my <50oz EDF's.
Haldor is offline Find More Posts by Haldor
Old Apr 20, 2001, 11:05 PM
Sal C is offline
Giddy up!
Sal C's Avatar
Woodridge, Illinois
Joined May 2000
Originally posted by Haldor:
I use 1/8" L-screws ...
I guess I was thinking about more of a curved hook. Is this wrong? Will a curved hook (as in my picture) hang onto the ring as it is supposed to release. Is it best to use a L type screw/hook?
Old Apr 21, 2001, 04:33 AM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
A curved one wont hurt as long as the ring can fall of easily by itself when the tension is gone.
Old Apr 21, 2001, 07:44 AM
Sal C is offline
Giddy up!
Sal C's Avatar
Woodridge, Illinois
Joined May 2000
Thanks Haldor.
Old Apr 21, 2001, 08:09 AM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
I'm currently bungee launching two planes.
The launch hook for my Kyosho T33 is made from a piece of 1/8" x 1/2" x 6" light ply, embedded into the landing skid. This works well for this 40 oz. plane.
The launch hook from my Electro Screamer is the light ply elevator control horn supplied with the kit. This has been embedded in the balsa nose block so only about 1/8" of the hook protrudes from the bottom. Works just fine on the 18 Oz, ES.
Both are held in place with epoxy.
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Apr 21, 2001, 04:04 PM
Balin is offline
Find More Posts by Balin
San Diego, CA. USA
Joined Nov 2000
I used a curved hook from hardware store with the end of the hook cut off so it was practically just straight with a little angle backwards. On a Zagi. Worked perfect, but each landing bends it backs farther.
Balin is offline Find More Posts by Balin
Old Apr 21, 2001, 04:36 PM
Sal C is offline
Giddy up!
Sal C's Avatar
Woodridge, Illinois
Joined May 2000
Anyone have pics of bungee hooks mounted on their plane?
Old Apr 22, 2001, 05:57 AM
Bill72pa is offline
Find More Posts by Bill72pa
Bill72pa's Avatar
United States, PA, Bucks County
Joined Jan 2000
And is there a rule of thumb as to where to mount it w/respect to cg?
Bill72pa is offline Find More Posts by Bill72pa
Old Apr 22, 2001, 09:14 AM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Sal C - I can get some pics later.
Bill72 - locate the hook ahead of the CG. I place mine halfway between the nose and CG. Anywhere from the leading edge and halfay as described will work as the location is not critical. Gliders want height from the pull and are therefore much more dependant on a proper hook/CG position. We just want airspeed...
Old Apr 22, 2001, 09:15 AM
Sal C is offline
Giddy up!
Sal C's Avatar
Woodridge, Illinois
Joined May 2000
From what I've read (I'm new to bungee as you can see) it's usually 1/2 way between the LE & the nose. I'll just have to make sure on my first launch that I wait for the plane to release before I hit the throttle, otherwise chop, chop, chop!
F-16 Bungee Hook Installation Royal Electric Ducted Fan Jet Talk 8 Oct 13, 2002 01:34 AM
Where attach bungee hook and how many histart rubber meter ? dav75 Electric Plane Talk 2 Oct 09, 2002 09:24 PM
Kyosho F-16 bungee hook location Stuey Electric Ducted Fan Jet Talk 1 Apr 10, 2002 04:21 PM
1/16 Ply Bungee Hook? tiggs Electric Ducted Fan Jet Talk 4 Mar 21, 2002 05:57 PM
bungee hook positioning on k&a Mig15 terje s Electric Ducted Fan Jet Talk 3 Mar 21, 2002 02:00 PM
