Old May 18, 2002, 11:56 AM
Parkflyer is offline
Find More Posts by Parkflyer
Richmond, VA
Joined Apr 2002
How do you straighten a fuselage on a Edge 540
Hey fellas,
Need some expertise in kit building. I'm putting together a Radical Edge 540 and the fuselage is warped about 5 degrees to the left. I didn't really notice till after I painted it with magic markers. I'm sure it will affect flight, so can I put a little water on the right side and put it between some books or something? It's warped from the cockpit to the nose.
thanks,
Parkflyer
Parkflyer is offline Find More Posts by Parkflyer
Old May 18, 2002, 04:59 PM
Richmond, VA
Joined Apr 2002
any ideas? any?
Old May 19, 2002, 01:43 AM
art4242 is offline
Find More Posts by art4242
art4242's Avatar
Northern CA, USA
Joined Nov 2001
how about spraying some water and then using a sealing iron to heat flatten it?
art4242 is offline Find More Posts by art4242
Old May 20, 2002, 11:06 AM
tom_yellowblue is offline
Find More Posts by tom_yellowblue
Sunnyvale, CA
Joined May 2001
I would spray water on it and then weight it down while it dries. I've never tried the iron method, that might work. Some people also recommend using Windex instead of water.
You say it's bent to the left. In that case, you'll want to put the water on left side because you want that side to expand. I'd actually just soak both sides.
tom_yellowblue is offline Find More Posts by tom_yellowblue
Old May 20, 2002, 11:57 AM
russ6421 is offline
Find More Posts by russ6421
russ6421's Avatar
ny
Joined Dec 2000
The reason they say Windex is because of the ammonia. You can get the same reasults using ammonia and water. Ammonia will soften the fibers in the wood and make it easier to bend.
russ6421 is offline Find More Posts by russ6421
Old May 20, 2002, 05:31 PM
Richmond, VA
Joined Apr 2002
Tom,
So if it's bent to the left then soak the left side? That will make it expand? I'll give it a try.
thanks,
parkflyer
Old May 20, 2002, 06:59 PM
Sunnyvale, CA
Joined May 2001
Yep. The idea with wetting one side only is that the balsa will absorb the water and expand. If it's curved to the left and you wet the left side, the left side will expand and force the tip and tail to move to the right, thus straightening it out.
Old May 21, 2002, 07:03 PM
Richmond, VA
Joined Apr 2002
thanks for the suggestions. I'll give it a try.
Question How do you remove adapter on EDF55?? hyperknight Power Systems 2 Jan 30, 2004 07:01 PM
How do you post videos on RCgroups? I FO nut Site Chat 8 Nov 18, 2003 03:00 AM
how do you transport sailplanes on real airplanes? Tim Green Electric Sailplanes 4 Nov 11, 2003 08:05 AM
How do you Balance the blades on a hornet? JStory Electric Heli Talk 2 Oct 03, 2001 06:09 PM
How do you disable BEC on Jeti Brushless ESC Paul Susbauer Electric Plane Talk 10 Jul 16, 2001 01:17 AM
