Old Oct 17, 2005, 12:24 PM
mrebman is offline
Find More Posts by mrebman
Cincinnati, Ohio USA
Joined Nov 2000
Is it OK to charge an 1800 MaH Lipo at 2 Amps??
Is it OK to charge a Polyquest 1800-2S Lipo pack at 2 Amps (2000 MaH)??
My charger has a setting for 1.5 Amp & 2.0 Amp, since the pack is rated at 1800 Mah, I am thinking I can get away with charging at 2 Amp, am I correct or am I going to let the smoke out??
-Thanks-
mrebman is offline Find More Posts by mrebman
Old Oct 17, 2005, 12:32 PM
fly_boy99 is offline
Find More Posts by fly_boy99
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
Mike-
I think you are better off using the 1.5A charge rate as overcharging can dimish a packs ability to deliver. Besides most advocate at charging at .8C to elongate your packs life which turns out to be roughly 1.5A charge rate(1.4 actually).
fb
fly_boy99 is offline Find More Posts by fly_boy99
Can I charge a 2100 mAh LIPO at less than a 1C rate? Armchair Bronco Batteries and Chargers 7 Sep 07, 2005 03:31 AM
Sold THUNDER POWER 2S2P Lite 4000 mAh lipo - x 2 NEW punkindrublik Aircraft - Electric - Airplanes (FS/W) 11 Jul 02, 2005 03:00 AM
Charging 4200 tp at 2 amps Fordplay Batteries and Chargers 10 Jun 17, 2005 11:05 AM
Is 22 AWG (0.711mm) wire suitable for an IPS DD motor at 2 amps? stu78 Power Systems 3 May 12, 2005 09:21 AM
Is it OK to charge a 7x270AA battery pack at 2 amps? Ryan Nau Power Systems 7 May 11, 2001 08:57 AM
