Old Nov 07, 2005, 03:06 PM
Jason M is offline
Find More Posts by Jason M
20 years on RCG!
United States, IL, Champaign
Joined Dec 1996
Yesterday I flew the Mini Ultra Stick at the local Las Vegas electric club flying field and everyone was absolutely amazed by the performance of this model! This particular model is equipped with 4 S75 servos (no quad flaps, but flaperons can be used) and the new Park 450 outrunner motor using the new E-flite 10x8E prop (EFLP1080E). Max current draw is 15 amps when using 3S 2100 packs (160 watts of input power) delivering great speed and nearly unlimited vertical for the 21 ounce model. Its hard to beat this setup for all around sport flying and great duration using 2100mAh packs (It allows the use of 1320mAh packs too).
However if you are looking for even more vertical performance and speed, especially when built with quad flaps and using an additional BEC or receiver pack, I would suggest one of the new Park 480 motors that will be available about the same time as the MUS. If you have lots of 10-12C discharge capable 2100mAh packs on hand, go with the 910Kv motor and an 11x7 or 12x6E prop. Max current draw will be around 22 amps, delivering extremely strong vertical performance (we use this power package in the Mini Funtana with great results). If you have 15C discharge capable 2100mAh packs on hand (like Thunder Power Pro Lite 2100s), go with the 1020Kv motor and an 11x7 or 12x6E prop. Max current draw will be around 28 amps, delivering incredible vertical performance (we use this power package in the Mini Edge and the vertical power is outrageous!).
http://www.horizonhobby.com/Search/D...&OverallCatID=
For most pilots who will fly the MUS though, just like all of those guys who were at the field yesterday and saw the model fly or had the chance to fly it, the Park 450 setup will be perfect for great power and the best possible duration when using 1320-2100mAh packs. With the 450 motor and 10x8E prop Im actually able to hover the model and slowly climb vertically with full power. The speed is very good too, offering a perfect blend of smooth and strong performance.
As a note, all of the motors recommended above fit the included outrunner firewall perfectly with no modifications required for installation in the MUS. You cant go wrong with any of them!
Jason M is offline Find More Posts by Jason M
Old Nov 07, 2005, 03:17 PM
txfly is offline
Find More Posts by txfly
txfly's Avatar
frisco,tx
Joined Oct 2003
it seems like outrunners are the wave of the future. i always thought a high performance geared inrunner was more powerful and efficient.
txfly is offline Find More Posts by txfly
Old Nov 07, 2005, 03:33 PM
cadconversions is offline
Find More Posts by cadconversions
Around the World
cadconversions's Avatar
Scottsville, KY
Joined Jun 2002
TX, the inrunner and gearing gives you more options where you are pretty stuck with the outrunners and the prop choices that the motor works with. For instance, you can put the 2500 in a "C" gearing with a smaller diameter prop and really pull some speed out or you can go into a "D" gearing with a 12x6 and go crazy. However, the outrunner does what it does at the best prop. Nothing to really play with but a few prop sizes in the range.
A way that I think of it is like this... A Glow engine runs the same you only have a few prop choices to get the performance you want. Same thing with an outrunner. As long as you are putting a .60 size motor on a .60 size plane you've got great performance. However, with an inrunner, you can put a .50 size motor on a .60 size plane and gear it to get pretty close to .60 size performance.
Gee, now I'm confused. For my money, I like outrunners but I also really love the Razor 2500. Infact, if you decide to sale the rz and it's in good shape. Just PM me.
cadconversions is offline Find More Posts by cadconversions
Old Nov 07, 2005, 03:52 PM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
I know Horizon can afford a video camera. I am itching to see this thing fly.
bildo baggins is offline Find More Posts by bildo baggins
Old Nov 07, 2005, 04:33 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Actually... if your considering selling the 2500, don't PM cad.. PM me..
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Nov 07, 2005, 04:43 PM
txfly is offline
txfly's Avatar
frisco,tx
Joined Oct 2003
i know the advantages of gearing , but i thought with the same prop and battery, an inrunner was more powerful and efficient -from an engineering standpoint. (disregarding noise factor)
Old Nov 07, 2005, 04:46 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
It is...
Old Nov 07, 2005, 04:51 PM
Around the World
Scottsville, KY
Joined Jun 2002
Yep, but I've always considered the efficiency lost in gearing to negate the efficiency difference. Maybe I'm wrong.
Old Nov 07, 2005, 04:52 PM
Around the World
Scottsville, KY
Joined Jun 2002
BTW, Tram doesn't need another 2500. He only has about 12 of them!
Old Nov 07, 2005, 05:03 PM
txfly is offline
txfly's Avatar
frisco,tx
Joined Oct 2003
i have noticed too that outrunners usually have a lower amp limit than inrunners of the same watt class.
Old Nov 07, 2005, 05:06 PM
Around the World
Scottsville, KY
Joined Jun 2002
Than they're not the same watt class.
250 watts on 3s li-po = 22.5 Amp draw regardless of motor. V x A = Watts
Old Nov 16, 2005, 04:07 PM
jaywebguy is offline
Find More Posts by jaywebguy
jaywebguy's Avatar
Idaho Falls, Idaho
Joined Dec 2004
Wonder how a axi 2826 12 would do on it. Only reason I ask is I've got one, with a 35 amp speed control and need home for it.
jaywebguy is offline Find More Posts by jaywebguy
Old Nov 16, 2005, 06:17 PM
papasmurf is offline
Find More Posts by papasmurf
"I passed on the kool-aid"
Waco, TX
Joined Jan 2004
That is about 2-3 motor sizes too big...You might have to mount the batteries in the tail to get it to balance.
papasmurf is offline Find More Posts by papasmurf
Old Nov 17, 2005, 09:48 AM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
That is the motor you need for the .40 size one....
Old Nov 17, 2005, 08:17 PM
dribbe is online now
Find More Posts by dribbe
dribbe's Avatar
United States, FL, Venice
Joined Jan 2005
Hi,
Put up a video in my gallery of this one.
It is ripped down from a video we used at the LA show. (has no audio)
Hope you guys find this helpful.
Motor is the reccomended EFL Park 450 Outrunner.
2100 3s THP Pro Lite
EFL 20 amp v2 speed control EFLA311B
4 EFLRS75 servos
EFL 10 x 8E prop.
http://www.rcgroups.com/gallery/show...cat=500&page=1
Hope to get it on Horizon Hobby and e-fliterc.com tomorrow.
Enjoy,
David
dribbe is online now Find More Posts by dribbe
Site Sponsor
Sold RTF E-Flite mini Ultra Stick bruff Aircraft - Electric - Airplanes (FS/W) 2 May 19, 2006 02:05 PM
Found E-Flite Mini Ultra Stick. smileyz Aircraft - Electric - Airplanes (FS/W) 2 Mar 07, 2006 08:27 PM
Sold E-Flite Mini Ultra stick gouda Aircraft - Electric - Airplanes (FS/W) 4 Feb 17, 2006 04:29 AM
Sold For Sale: NIB E-Flite Mini Ultra Stick $88.00 shipped dawnron1 Aircraft - Electric - Airplanes (FS/W) 2 Dec 27, 2005 09:03 AM
E-Flite Mini Ultra Stick ARF bildo baggins Parkflyers 13 Nov 07, 2005 06:27 PM
