Old Oct 16, 2005, 07:23 PM
kdwzagi is offline
Find More Posts by kdwzagi
(madkev :) )
kdwzagi's Avatar
United Kingdom, England, Stafford
Joined Dec 2002
Build Log
JDC II boulton paul 111a
hi
the boulton paul 111A project
kev
kdwzagi is offline Find More Posts by kdwzagi
Old Oct 16, 2005, 07:30 PM
King_Ice_Flash is offline
Find More Posts by King_Ice_Flash
King_Ice_Flash's Avatar
WI
Are those the original plans for it
King_Ice_Flash is offline Find More Posts by King_Ice_Flash
Old Oct 16, 2005, 07:33 PM
kdwzagi is offline
(madkev :) )
kdwzagi's Avatar
Joined Dec 2002
the design
hi
i played around with the idea of a larger version for a while with foam venier wings and a glass fiber fuselage but after my wing joiner failed a strength test i decided to think again, a complete rethink redesign is now under way
i first drew it up with cad and created a 3d model that could be sliced up to give the shape of the formers, wing ribs and spars
Old Oct 16, 2005, 07:50 PM
kdwzagi is offline
(madkev :) )
kdwzagi's Avatar
Joined Dec 2002
the design part II
hi
with the fuselage and wing sliced up in all the correct places i could start to plan the layout
this is as far as i've got so far
there will be 3/16 spruce spars with vertical 1/8 shear webs, these will support a 1/8 hard balsa spar that will run full span at 1/3 chord, the leading and trailing edges will be 1/4 and the ribs will be 3/32 medium
the wing will be skinned as far as the 1/3 chord spar with 1/16 sheet
the fuselage formers will be 2 cross grain laminations of 3/32 balsa and there will be 4 3/16" spruce longerons and 4 1/8" soft balsa longerons
i'm not sure if the fuselage will be completely skinned in balsa yet, i will need to weigh it as i go along, this is my first EDF and my first balsa design so it may end up a bit heavy
see pic below of my progress, the fuselage formers need to have holes in them of course but thats as far as i've got
kev
Old Oct 16, 2005, 07:51 PM
kdwzagi is offline
(madkev :) )
kdwzagi's Avatar
Joined Dec 2002
3 view
no just nice 3 view drawings
kev
Old Oct 16, 2005, 08:37 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
I've seen one of these in a magazine (EFI I think). It was yellow.
Steve C
Steve C is offline Find More Posts by Steve C
Old Oct 16, 2005, 10:05 PM
WeMoTec is offline
Find More Posts by WeMoTec
Willich / Germany
Joined Nov 1998
I do not want to disappoint you, but this design is around for ages, and there is even a commecial plan around for Mini Fan:
http://members.aol.com/offshoreel/modelle2.htm
So at least I can tell you, that it flies excellent.
Oliver
WeMoTec is offline Find More Posts by WeMoTec
Old Oct 16, 2005, 10:10 PM
WeMoTec is offline
Willich / Germany
Joined Nov 1998
One more pic:
http://www.rcgroups.com/forums/showa...hmentid=&stc=1
Old Oct 17, 2005, 10:39 AM
kdwzagi is offline
(madkev :) )
kdwzagi's Avatar
Joined Dec 2002
disqaulified i am
hi
its a fair cop
i searched for ages when i was doing my research and never found this oh well bye bye
can someone please remove my thread from the competition
kev
Old Oct 22, 2005, 02:00 PM
kdwzagi is offline
(madkev :) )
kdwzagi's Avatar
Joined Dec 2002
edf ducting question
hi
i know i have been disqualified from the competition but i still intend to build the boulton paul 111a, see the design and future build here
anyway i have a question
the scale inlet size of the 111a is going to be a lot bigger than the fan sweep area, nearly 160 percent
i've read that anything over 110 percent is too big, i'm going to have to make a light weight ducting to go up and over the wing spars so should i just slowly reduce the duct size as it travels up and over the wing or should i reduce it down to 110 percent as soon as posible and then keep the ducting an equal area as it travels backwards
thanks
kev
ps this is my first duct fan model so please be gentle with me
Old Oct 22, 2005, 03:46 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Any airflow not taken into the fan is spilled out of it, the associated drag is much much less than the effects of a propellor would have and the added area in the intake is not that bad of an idea. I normally try and make my intake area for smaller fans arround 120% or a little more and have had no ill effects on the speed of the aircraft, please note the Nano Bandits thread as that airframe has intake area over 125% and flies fine. The KC F-18(HET) has an intake arround 120% and it performs well enough.
Eric B.
PS: let the duct taper to the inlet evenly, no need adding extra drag in the intake with changing tapers.
AirX is offline Find More Posts by AirX
Old Oct 22, 2005, 04:14 PM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
Back in competition
Boulton paul p120
grtz+ Good luck!
Erik
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Oct 22, 2005, 04:16 PM
Joined Dec 2003
last pic
Old Oct 22, 2005, 04:25 PM
Joined Dec 2003
last of the Offshore plans designed by Heino Ditmar. pioneer of edf flight
Old Oct 22, 2005, 04:30 PM
Joined Dec 2003
not the dude on previous pic. but this one
Build Log JDC II EDF-50 ( x 4 ) BAe146 keven64 Electric Ducted Fan Jet Talk 406 Aug 07, 2006 07:51 AM
JDC II Microfan Angel Interceptor keven64 Electric Ducted Fan Jet Talk 41 Mar 05, 2006 07:09 PM
Build Log JDC II EDF-40 or MicroFan SnowSpeeder EDF King_Ice_Flash Electric Ducted Fan Jet Talk 43 Jan 05, 2006 09:13 AM
JDC II Roteblitz / Ptera Helihead Electric Ducted Fan Jet Talk 11 Nov 17, 2005 12:55 AM
JDC II Vasa 55 Tsybin HM-1 Robert May Electric Ducted Fan Jet Talk 21 Oct 13, 2005 03:09 PM
