Old Oct 16, 2005, 06:59 PM
drift_n_shift is offline
Find More Posts by drift_n_shift
Joined Oct 2005
what is mAh? can i use a higher mAh?
hey
another total newb question from me I have a 7.2V 1700mAh battery for my electric r/c car. If i were to buy a battery, would it have to be a 7.2V 1700mAh battery, or can I go for a 7.2V 3000mAh battery!? tahnks again guys
drift_n_shift is offline Find More Posts by drift_n_shift
Old Oct 16, 2005, 07:01 PM
Jim_W is offline
Find More Posts by Jim_W
Jim
North Alabama
Joined Mar 2004
Yep. Go for the 3000mah. Just means a longer run.
Jim_W is offline Find More Posts by Jim_W
Old Oct 16, 2005, 07:02 PM
Silent is offline
Find More Posts by Silent
Silent's Avatar
New York City
Joined May 2005
"mAh" is the capacity of the battery.
Silent
Silent is offline Find More Posts by Silent
Old Oct 16, 2005, 07:04 PM
Joined Oct 2005
thanks guys really do appreciate it
DMACK is offline
Find More Posts by DMACK
Power in the hands of few
DMACK's Avatar
San Francisco, CA
Joined Jul 2004
The issues are size & weight. Go as big as you can, but not so big or heavy as to not fit in the car.
DMACK is offline Find More Posts by DMACK
Old Oct 16, 2005, 08:28 PM
Joined Oct 2005
so if a car comes with 7.2V 1200mAh, it wont do any damage to the car or motor because a newer battery is 7.2V 3000mAh?
Old Oct 16, 2005, 08:47 PM
lexi is offline
Find More Posts by lexi
Georgia
Joined Jun 2005
I had the same question before, my freind explained it to me like having a bigger gas tank in your car.
Lexi
lexi is offline Find More Posts by lexi
Old Oct 16, 2005, 11:55 PM
kwilliby is offline
Find More Posts by kwilliby
Omaha, Nebraska, United States
Joined Aug 2002
The mah rating on the battery is like the size of the gas tank on a car like Lexi mentioned.
Here is one way to look at it. Someone please correct me if I'm wrong.
A battery's capacity is rated in mah or milliamp hours. A 1700 mah battery is rated to deliver 1700 mah (or 1.7 amps) per minute for one hour. So this battery will deliver 102,000 mah (or 102amps) in one hour. 1700 mah x 60 minutes = 102,000 mah.
Now take the amp draw of your car motor. Let's just say it pulls 20 amps or 20,000 mah.
Take the capacity of the battery which is 102,000 mah or 102 amps. Divide by 20,000 mah or 20 amps, which the motor is pulling and you get a total motor runtime of 5.1 min. i.e. (102,000 / 20,000)
So a basic formula could be;
total motor runtime = (battery mah capacity x 60) / motor amp draw
for your 1700 mah battery;
total motor runtime = (1700 mah x 60) / 20,000
total motor runtime = 102,000 / 20,000
total motor runtime = 5.10 min.
for a 3000 mah battery;
total motor runtime = (3000 mah x 60) / 20,000
total motor runtime = 180,000 / 20,000
total motor runtime = 9 min.
So bigger battery = more gas in the tank to run your motor.
There are other ways to calculate this as well.
I hope this makes sense and helps a bit.
Where you can get into trouble is if you have a motor that pulls a higher amp draw than the battery is designed to deliver. Pull 30 amps on a GP2200 battery and it will be no problem. This cell is designed for high amp draw applications.
But pull 30 amps on a 2300 mah AA cell that is designed for digital cameras etc. and that cell will be toast.
kwilliby is offline Find More Posts by kwilliby
Old Oct 17, 2005, 12:15 AM
JohnMuchow is offline
Find More Posts by JohnMuchow
CamLight Systems
New York City, USA
Joined Oct 2003
Another way to do it...
Assume 20A motor load.
1700mAH cell = 1.7AH cell
(1.7 ampere-hours) / (20 amperes) = .085 hours
(0.085 hours) * 60 = 5.1 minutes
3000mAH cell = 3.0AH cell
(3.0 ampere-hours) / (20 amperes) = 0.15 hours
(0.15) hours * 60 = 9 minutes
Notice that when you divide ampere-hours by hours that you're left with hours, i.e., your run time. Just convert the run time to whatever units you need (hours, minutes, seconds, etc.).
JohnMuchow is offline Find More Posts by JohnMuchow
Old Oct 17, 2005, 02:43 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Your conclusions are spot-on, but just one correction A 1700mAh battery is rated to deliver 1700mA (or 1.7 amps) for one hour: Not mah per minute for one hour
Once you get the units right, it all begins to make sense: 1700mAh (or 1.7Ah) divided by 20A leaves you with time (Ah/A = hours).
abenn is offline Find More Posts by abenn
Old Oct 17, 2005, 10:07 AM
kwilliby is offline
Joined Aug 2002
thanks for the correction. guess i was up too late.
Old Oct 17, 2005, 10:26 AM
abenn is offline
Joined Jul 2004
No problem Now you're up too early, aren't you?
Old Oct 17, 2005, 10:47 AM
kwilliby is offline
Joined Aug 2002
no kidding. need to find more sleeping time. just can't get everything done. i understand the battery mah stuff, just don't do a good job of transfering it from my brain to words.
thanks again.
Old Oct 17, 2005, 10:55 AM
kwilliby is offline
Joined Aug 2002
I know this may seem backwards but it is easier for me to calculate the motor amp draw per minute then divide battery capacity by the per minute draw.
20 amp draw / 60 min. = 333 mah per min.
1700 mah battery / 333 = 5.1 min.
just another way to look at it i guess.
Zagi 400 and what ESC can I use livinma1 Foamies (Kits) 3 Apr 19, 2004 09:27 AM
What planes can I use a Nippy 0808 in? jra111 Parkflyers 19 Feb 13, 2004 10:41 AM
What is hinge tape made of? What else can I use? Magna Electric Plane Talk 11 Jan 28, 2004 07:20 PM
What material can I use to practice soldering aluminum tabs? Mesmer Batteries and Chargers 7 Jan 19, 2004 09:36 AM
What plane can I use a Kyosho F-16 ducted fan in? Chris K Electric Plane Talk 0 Feb 10, 2002 10:31 AM
