Old May 18, 2002, 02:38 AM
701 Super Jet is offline
Find More Posts by 701 Super Jet
Elk Grove,Ca.
Joined Mar 2002
Will I fry my esc
I'm currently running dd sp400,5.5x4.5 prop, 8-cell 600AE and jeti 10 esc in my S&B corsair. AUW right now is 16.04 oz.
Can I put an sp480 in it with out frying something?
Thanks, Glenn
701 Super Jet is offline Find More Posts by 701 Super Jet
Old May 18, 2002, 03:43 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
You damage the ESC if you put too much current through it. So you could use 480 if you put a small prop on it so the current stayed low. There wouldn't really be much point doing that.
If you want the full power available from a 480 it would need more current than that ESC (and probably the battery) would safely take.
Steve
steve lewin is offline Find More Posts by steve lewin
Old May 18, 2002, 07:11 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
A stock Speed 480 is a 7.2V motor, and will draw less current with the same prop and battery when compared to a Speed 400 6V. However, I wonder if you're running a 6V motor as it would draw over 12A with this setup (the stock Speed 480 would draw 11A and give almost identical performance, as it's a larger and more efficient motor, although it is much heavier). The 7.2V Speed 400, however, is only drawing about 8.5A, so it's probably what you have - in that case, moving to a stock 7.2V Speed 480 would make a difference, but would be too much for that speed control.
..a
Old May 18, 2002, 10:50 AM
Elk Grove,Ca.
Joined Mar 2002
Thanks for saving my esc guys.
Andy I am running a 6v 400. 5 flights so far, two of the with a 3 blade 6x4 prop. Guess I should get a 7.2v before cook the esc.
Thanks again for the info guys, Glenn
Discussion Did my son fry my ESC? FlyBoy72 Power Systems 34 Sep 04, 2007 07:58 PM
Discussion Will this FRY my ESC or RCVR? king-fisher Power Systems 5 Apr 06, 2006 09:24 PM
Will I Fry My TP2100-3S? HavingFun2002 Batteries and Chargers 7 Apr 30, 2004 04:58 PM
DYMOND SUPER TURBO on 75 AMPS?!?! WILL I FRY MY CHARGER? mike98624 Batteries and Chargers 10 Apr 12, 2003 03:23 PM
Will it hurt my esc? die fleidermaus Power Systems 3 Feb 27, 2002 12:42 PM
