Old Oct 15, 2005, 09:17 PM
phoneguy is offline
Find More Posts by phoneguy
phoneguy's Avatar
Tarpon Springs, FL
Joined Apr 2002
Goldberg's new speed 400 Husky, 6 servos required, what ESC should I use?
Carl Goldberg is getting ready to release a favorite plane of mine, the good ol' Husky. The problem is that this plane, requires six servos because of the flaps. I plan on using a geared 6.6:1 Himaxx 5300. I have pushed a CC Phoenix 25 with four servos, but six I think it will smoke. Is the CC Phoenix 35 the way to go for this?
phoneguy is offline Find More Posts by phoneguy
Old Oct 15, 2005, 09:42 PM
Griffin is offline
Find More Posts by Griffin
WAA-08 Survivor
Griffin's Avatar
Joined May 2004
Consider the ParkBEC. 6 grams and will handle 6 servos and you can use your CC25 or other brand of ESC. $16 or so and you can order them from Stevensaero.com. I have two and since they are so light and cheap, plan to use one any time I have 4 servos or more. -Steve
Griffin is offline Find More Posts by Griffin
Old Oct 16, 2005, 06:53 AM
phoneguy is offline
phoneguy's Avatar
Tarpon Springs, FL
Joined Apr 2002
Thank Steve, You have saved my Husky from an "internal hazard", Now I will have to blame my crashes on pilot error.
Old Oct 16, 2005, 07:04 AM
jmolwitz is offline
Find More Posts by jmolwitz
Straight up is all I ask
Fairfield Ct USA
Joined Apr 2002
Will this be a kit or ARF?
jmolwitz is offline Find More Posts by jmolwitz
Old Oct 16, 2005, 07:21 AM
phoneguy is offline
phoneguy's Avatar
Tarpon Springs, FL
Joined Apr 2002
It is an ARF, and has a stick mount, you can look at the instructions on Goldberg's website.
www.carlgoldbergproducts.com
Old Nov 15, 2005, 11:36 AM
a320jockey is offline
Find More Posts by a320jockey
a320jockey's Avatar
Ecuador, Pichincha, Quito
Joined Aug 2002
Which ParkBEC version is better? ParkBEC with 4 servos?
Hello Griffin,
I too have the same problem, with six Hobbico CS-5 Nano Servos (equivalent to the Hitec HS-55) to be used on my nearly completed Hobby Lobby Super Cub. It will use two servos on each wing (one for aileron and one for flap) apart from those for Rudder and Elevator. Power system will be PHX 25 or E-Flite 40 AMP ESC, with an E-Flite Park 400-3700 motor with 4.4:1 reduction and a 9X6 SF APC prop; Ultra 1500 3S1P battery. The receiver will be a Hitec Electron 6.
My first question is about the ParBEC's: I read at the Stevensaero page that there are two versions of the ParkBEC, one for 5V and the other for 6V. Which one do you consider better?
My second question relates to the use of four servos with the PHX 25 ESC. I am presently flying a Mini Funtana with this controller, 6.6:1 reduction, a 12x6 prop and a Thunder Power 2100 3S1P battery; no problems at all, however sometimes while flying I have heard the motor current unstable. Am I forcing the ESC, hence the current cuts? The ESC's instructions only mention that 4 servos is OK with the installed power system.
Many thanks for any help or recommendations.
Carlos A. Cordova
QUITO - ECUADOR
a320jockey is offline Find More Posts by a320jockey
Old Nov 15, 2005, 03:00 PM
Comatose is offline
Find More Posts by Comatose
Dimension Engineering
Akron, Ohio
Joined Jan 2002
About your first question, the 5v version is the "standard" one and probably what I'd go with in this case. 6v will get you somewhat improved servo speed, torque and centering, at a cost of increased power consumption and slightly shorter servo lifespan. If you're flying a competition type plane or a helicopter, then the 6v is the right way to go. For a scale Super Cub, which probably won't be doing hard-core aerobatics, the 5v version will work fine.
Comatose is offline Find More Posts by Comatose
Old Nov 15, 2005, 03:09 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Not to mention that some manufacturers don't recommend over 5v anyway. Picos are one, several other sub-micros do also.
5v is better IMHO.
wtb: new speed 400 and long can 400's snowfallonme Aircraft - Electric - Airplanes (FS/W) 0 Aug 01, 2004 10:51 PM
New speed 400 KI-46 Dinah kits Ken Williams Vendor Talk 5 Jun 23, 2002 11:19 PM
New Speed 400 motors and props FS mickydee Aircraft - Electric - Airplanes (FS/W) 3 Jun 13, 2002 10:54 PM
New Speed 400 6v Motors funfly Aircraft - Electric - Airplanes (FS/W) 0 May 22, 2002 07:40 AM
New Speed 400 EZ-400! sal Parkflyers 2 Jun 16, 2001 07:22 PM
