Came across this thread while doing my weekly search for JustGoFly to see what you guys are chatting about. PTGlass - thanks for the kind words !
You own a 48" Razor Wing ? That is one of my favorite wings and the second wing I bought after the Wattage Hyperwing. I have my maiden flight on video below. As you'll see from the landing I expected it to land at my feet and it just kept hanging in the air and wouldn't drop. I finally had to dump it in the grass before it went into the street. The Wattage drops like a brick once you remove power. Razor Wing - First Flight and this flight after I had crashed it doing about 80mph into a sign post and took a huge chunk out of the front of the wing and when trying to repair it - the glue dried warping the wing - but I tried to revive it here - and ... well you'll see what happened. Final Flight of the Razor I had full left when I gunned the motor and it pulled hard right. I killed throttle but couldn't get it slowed enough. Great Wing ! I'd buy another in a second if I could find it. Vinnie |
Which motor for my Razor
Thanks |
Numbers, Numbers, Numbers
77mph and 30 oz's of thrust 319 watts or 87mph and 21.3 oz's thrust at 292 watts or 95mph and 16.7 oz's thrust at 248 watts That's what I intend to run on my heavy wings. If you can't provide the high amps - we can drop the amps down with a different prop for : 82mph 13.7 oz's trust at 204 watts This is a 2250 KV motor. I've been experimenting with a 1700 KV 450 motor that was running my 24 oz wing that is very draggy yesterday. I started with 6x3 prop which was nice but less than 1:1 and ran about 12 amps 3S. Then upped it to a 7x3 for more thrust and about same speed at slightly more amps. This motor can handle 30 amps at 3S. So I upped it again to a 6x4 and speed increased nicely - but still I wanted more. I ended my test at a 7x5. Nice speed, a little better than 1:1 thrust on a fresh pack and only 25 amps on 3S. This motor doesn't have a name yet - and I need to compare it to the 2250KV 450FT motor. I have a suspicion the 450FT is more efficient but won't drive a 7x5 prop at reasonable amps. These 450's are absolutely unreal motors. Check out http://www.JustGoFly.com and I will get that 450FT direct drive data posted. Vinnie |
| Thread Tools | |
| Wanted looking for an Old wanderer or gentlelady kit or wing | theclaw | Aircraft - Sailplanes (FS/W) | 19 | May 29, 2007 06:56 AM |
| Help! I need plans for an indoor flying wing | Munkey | Indoor and Micro Models | 2 | Apr 09, 2006 10:19 AM |
| CG for an FVK Nobody | avalanche | Electric Sailplanes | 9 | Jul 11, 2004 05:05 PM |
| New look for an old Razor | Tres Wright | Foamies (Kits) | 15 | Apr 17, 2002 11:02 PM |
