Old Oct 15, 2005, 01:05 PM
darren.karp is offline
Find More Posts by darren.karp
Joined Sep 2005
Great Planes U-Can-Do 3D EP
Has anyone tried the U Can Do 3D EP plane from Great planes? What's it like? Is it really as hardy as they make out?
darren.karp is offline Find More Posts by darren.karp
Old Oct 15, 2005, 04:39 PM
tim hooper is offline
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
Hi Darren,
Is the super-flexible all foam model, with the zip-up battery compartment? If so, I've seen the components folded double and stood on the model shop, so it looks like the sort of model that your kids will inherit in later years!
Not a trainer though, I'd guess.
tim
tim hooper is offline Find More Posts by tim hooper
Old Oct 15, 2005, 09:58 PM
martimer is offline
Find More Posts by martimer
USA, MO, O'Fallon
Joined Dec 2003
I have one. It is my second one - I left the first one in the car on a hot day and the seams melted and several parts warped. I bought the second one because it is so much fun to fly.
It is not necessarily a good first aircraft because it is a bit fast and aerobatic, but it is a good first aerobatic type plane because it is not horribly fast and it is pretty durable. If you are good on a simulator with aerobatic planes, than this is a good first plane. I have let a couple of the experienced pilots in the club fly it and they enjoyed it - it has some good habits. The stock power system is well suited for the airframe, but it is not overpowered (something that a lot of experienced pilots like).
Most of the criticism I have heard involves the problem of the wings and fuselage flexing too much in flight.
martimer is offline Find More Posts by martimer
Old Oct 16, 2005, 10:33 AM
TommyBurger is offline
Find More Posts by TommyBurger
Corona, CA, USA
Joined Jan 2004
I broke mine on the first flight, and every subsequent flight after glueing back together. Far from unbreakable.
TommyBurger is offline Find More Posts by TommyBurger
Old Oct 16, 2005, 10:45 AM
Joined Sep 2005
Hi,
Thanks for the info. I and others would really benefit from a description of the crash and the subsequent repair attempt. Do you have pictures as well?
Darren
Old Oct 16, 2005, 10:54 AM
Andycap is offline
Find More Posts by Andycap
Inspired by the wings of an An
Andycap's Avatar
Leeds
Joined Mar 2003
I'm the one tim refers to as folding it double in the model shop, and yes i stamped on the cowl too. Dont be fooled as no model is unbreakable. But this is one tough cookie. The model is a 3D trainer! and as such is designed for practicing 3D manouvers such as Prop hanging, High alpah manouvers, harrier rolls etc. These are practised low to the ground and at low airspeeds. Make a mistake at these speeds and apart from a bent motor shaft and a broken motor stick (the only bit of wood in the model) I haven't witnessed any other damage. Smash it into the ground vertical from fifty foot at full throttle and a bin bag will be needed just like any other lightweight 3D model. No way is this the best model I have flown for flying 3D manouvers but its fun tough and a good laugh especially when you demonstrate how the fuselage will bend 90 degrees against the wall indoors! (oops!
Hope this clarifies things a little
Andycap is offline Find More Posts by Andycap
Old Oct 16, 2005, 06:17 PM
martimer is offline
USA, MO, O'Fallon
Joined Dec 2003
The actual damage that I have seen is that the linkages on the undersides of the control surfaces have been ripped off when coasting to a stop in tall grass.
I have stripped out the spur gear, but they sell replacements at my LHS.
I have chipped a prop coasting to a stop on asphalt - the stock prop saver has saved many a prop though.
I have been doing most of my practise several mistakes high, but the few low stunts have survived some impressive impacts. If you are learning 3D or aerobatics, this is a great ARF.
Article Great Planes U Can Do 3D EP FlightFlex Park Flyer ARF Review mordib Electric Plane Talk 1 Dec 01, 2005 07:56 PM
dual aileron setup for Great Planes U can do 3d EP robster94gt Parkflyers 1 Sep 19, 2005 08:44 PM
Anybody have a Great Planes U-can-do 3d ep? robster94gt Parkflyers 0 Jun 19, 2005 12:13 PM
great planes U-CAN-DO 3D EP shockflyer12345 3D Flying 1 May 31, 2005 03:24 PM
Great Planes U-Can-Do 3D Flight Flex EP arf Merkaba Foamies (Kits) 10 Mar 17, 2005 03:02 AM
