Old Oct 12, 2005, 12:03 AM
savydad is offline
Find More Posts by savydad
Indianapolis, IN
Joined Aug 2005
Easy internal resistance (IR) measurement?
I would like to know how internal resistance is measured on a cell. Is it necessary to place a load on the cell, and if so, how is it known what load to put on it? I have some cells that are not holding their charge for more than an hour or so, and want to measure the IR of them, to see if this is the reason for failing. I have hooked them up to my DVM, with varying results. On a 200ohm scale, they are reading 190's and on a 2000ohm scale, they read 1800's. This has me confused, and I've googled for how to measure with all results saying a load is placed on a cell then IR is measured by voltage drop, or something along that line. Thanks for any input provided.
Todd
savydad is offline Find More Posts by savydad
Old Oct 12, 2005, 02:42 AM
carfiel is offline
Find More Posts by carfiel
China
Joined Aug 2005
The internal resistance is very low, usually just 10-20mΩ for a 2000mAh battery. The higher capacity the lower resistance it is. And the resistance is change every time if you diacharge with great power(more than 8C). So you must use a professional instrument. I saw some test report here contained the resistance, but I lost it. Maybe someone could tell you.
carfiel is offline Find More Posts by carfiel
Old Oct 12, 2005, 03:35 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
There is no simple way. A DVM will tell you nothing, the voltage across the battery terminals confuses (and can damage) the resistance reading. You basically need to switch between 2 different accurately calibrated loads and measure the difference in cell voltages at the 2 different currents. It doesn't much matter what the loads are but it's sensible to make them something like the load you intend to use. There's no real point measuring at 10mA if you're going to be using 40A and resistance does change with load.
Steve
slipstick is offline Find More Posts by slipstick
Old Oct 12, 2005, 07:01 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
The simplest way:
Put a load on a pack. Measure voltage (V1) and current (I). Disconnect the load, measure voltage (V2).
(V2-V1) / I = Resistance
The resistance changes with load and discharge point, so you may want to try different loads and different times in the discharge.
Gene Bond is offline Find More Posts by Gene Bond
Old Oct 12, 2005, 07:24 AM
Al Offt is offline
Find More Posts by Al Offt
Boston, MA subburb
Joined Sep 2004
I believe the open circuit voltage (V2) may not be the best choice as your second measured voltage/current pair. I would take two readings (i.e. (V1, I1),(V2, I2) close to your operating conditions (i.e. 20amps, 15amps) and use those pairs in the calculation:
Resistance = (V2-V1) / (I1-I2)
[this equation assumes the current I1 is higher than I2 to give a positive value of calculated resistance.]
I'm not implying that there is anything non-linear about the resistance, only that battery voltage under load drops over time and your two measurements may be taken at different locations on the steep part of this decline.
Alan
P.S. You can use many of the graphs in the Batteriers and Charger's forum to calculate IR. When multiple current levels are shown in one graph, you can 'measure' voltage differences between current curves at one point of charge (mahrs).
Otherwise, one of the many Whatmeters would be a good choice for obtaining your own measurements.
Al Offt is offline Find More Posts by Al Offt
Old Oct 12, 2005, 11:12 AM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
Battery University
http://www.batteryuniversity.com/partone-22.htm
hall woo is offline Find More Posts by hall woo
Old Oct 12, 2005, 02:48 PM
Sillyness is offline
Find More Posts by Sillyness
Sillyness's Avatar
Little Rock, AR
Joined Apr 2004
The Duratrax ICE charger displays the battery's internal resistance. Check out the manual. I have one on order.
Sillyness is offline Find More Posts by Sillyness
Old Oct 12, 2005, 06:10 PM
savydad is offline
Indianapolis, IN
Joined Aug 2005
Thanks for the replies guys, I plan on an emeter, when time comes...no funds right now. I will invest in some better packs before I get that. I'm using a cheap 2400 sub-c pack that loses voltage over time, and was just wondering if the internal resistance had gotten high, causing the voltage/capacity drop with time. I never measured the cells, and thought over 50mohm sounded high, but wanted to make sure I wasn't measuring it wrong, as I was. I know these cells are junk, so I will be better off using my hobby $ on packs, then on some type of meter (emeter or wattmeter) I like the emeter for ability to save things, and pc interface.
Todd
Measuring internal resistance? JBowling Batteries and Chargers 3 Oct 09, 2002 11:20 AM
Qual Comm internal resistance Rob Hair Parkflyers 1 Feb 21, 2002 10:57 PM
internal resistance of 2/3aaa nimh? singlespeed7 Parkflyers 0 Nov 05, 2001 05:03 PM
Battery Internal Resistance E-Man Power Systems 2 Jul 24, 2001 10:06 PM
