Old Oct 11, 2005, 06:22 PM
John Webb is offline
Find More Posts by John Webb
San Francisco Bay Area
Joined May 2001
Will 6 micro servos overload my Jeti Advance 40 Plus BEC?
I am setting up a new e-Telemaster 40 with a modified "no dihedral" full house wing
I'll end up with 6 servos. I'm using a Jeti Advance 40 plus ESC with a TP 3S2P 4200 mAh lipo, and an AXI 2826/12 motor.
Does anyone have an opinion of whether this will fry the Jeti, or will I need a UBEC, or an additional on board battery? I'd love to avoid the extra weight from an additional battery!
thanks in advance
John
John Webb is offline Find More Posts by John Webb
Old Oct 11, 2005, 06:33 PM
Ghost 2501 is offline
Find More Posts by Ghost 2501
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
the esc BEC should cope ok with 6 servos, for what current they would pull, it would be naff all, even if ALL 6 SERVOS WERE OPERATING AT THE SAME TIME
Ghost 2501 is offline Find More Posts by Ghost 2501
Old Oct 11, 2005, 08:37 PM
davecee is online now
Find More Posts by davecee
I'd rather be Flying
davecee's Avatar
Nashville, NC, USA
Joined Mar 1999
Your Jeti Advance 40 plus ESC will handle 4 servos on a 3S Lipo pack, according to information posted on the Hobby Lobby site. It also says to decrease the number of servos by one if you're using "cheap micro servos" and decrease by two if using digital servos. Make your own decision. I wouldn't do it.
Dave
davecee is online now Find More Posts by davecee
Old Oct 11, 2005, 08:54 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
I'm with davecee. It might work, but too close to the edge for me.
Bill
ebill3 is offline Find More Posts by ebill3
Old Oct 12, 2005, 11:59 AM
Al Offt is offline
Find More Posts by Al Offt
Boston, MA subburb
Joined Sep 2004
I'll third the recommendation not to try it because you will loose control at the worst time in your flight. On the ESC I was using (not a Jeti), when the BEC overheated, it removed voltage from receiver and servos but held motor speed. I was at the top of a loop, ~250feet AGL, full throttle, partial up elevator and starting a roll when everything frooze. The plane completed 2 1/2 rolls before making a 1 inch deep hole in the ground - all within the 5 second thero-overload recovery time I measured later on the bench.
At the very least, do a bench test, move all servos simultaneous for about 45 seconds and then feel the ESC for a very hot chip (most likely located opposite the heat-sink). Even if it passes on the bench, that test cannot replicate the real aerodynamic loads placed on the servos so you cannot be really sure. If the test fails, you've saved a plane.
Alan
Al Offt is offline Find More Posts by Al Offt
Old Oct 12, 2005, 12:28 PM
Comatose is offline
Find More Posts by Comatose
Dimension Engineering
Akron, Ohio
Joined Jan 2002
What servos are they? It makes a huge difference. If its 6 HS-81s, then the answer is no chance. If they're six hs-55s then maybe.
Comatose is offline Find More Posts by Comatose
Old Oct 12, 2005, 12:38 PM
Andy McCowan is offline
Find More Posts by Andy McCowan
Mmmm.
Andy McCowan's Avatar
Selkirk, Scotland.
Joined Jun 2001
I would not risk it, some of those smaller servos are a bit Amp hungry.
Andy McCowan is offline Find More Posts by Andy McCowan
Old Oct 12, 2005, 01:36 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Alan
Not as bad as you, I had a mere 4HS55's on a 12A brushed ESC on 3s LIPO.
I was pottering around 1/2 throttle or less, 7-8 minutes in to a flight, using lots of aileron corrections in the mild turbulence.
In my case the throttle closed and all servos ran to their end stops. Thank heavens it was 'up' elevator not 'down'. Spun in from 30 feet. A lot of damage, but reparable.
She runs with a bigger ESC and more cooling these days - so far without trouble.
I am putting together a 3s/4s ship with 6 servos. NO WAY will I use a linear BEC.
But them those nice guys at SMARTBEC sent me a free unit in return for making up a silly advert line.
Weighs very little, and if it does what it says 'on the tin' it will be perfect..
Why risk the plane for a few oz of servo battery or a few dollars of switching BEC?
Would you run with potentially intermittent crystal, or a servo which has any potential to fail on you in mid air?
No, and this is potentially worse..
Don't risk it. Its not worth it.
3s LIPO and 4 servos is the limit for linear BECS.
Old Oct 12, 2005, 01:53 PM
fly_boy99 is offline
Find More Posts by fly_boy99
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
For godsake just get a BEC because the money you will spend on it will more then be made up in time NOT spent repairing your plane or keeping someone out of the hospital!!!
fly_boy99 is offline Find More Posts by fly_boy99
Old Oct 13, 2005, 04:52 PM
Joined May 2001
thanks all...
I think I have my answer and will use either a dedicated NIMH for the receiver/servos (HS-81's), or a UBEC.
I haven't been able to find much information about the reliability of UBEC's. Does anyone have any experience with them (good or bad) that they can share?
John
John
Old Oct 13, 2005, 06:55 PM
davecee's Avatar
Nashville, NC, USA
Joined Mar 1999
I've been using a UBEC in a 20 cell NiMH plane which then was changed to 6S LiPo. I'm running 4 servos, which is no where it's full capability. It's been flawless.
Dave
AXI 2820/10 + Jeti Advance 40 plus (BEC) = crash Mike Seale Power Systems 21 May 07, 2008 08:32 AM
Sold JETI Advance 40 Plus ESC monjo Aircraft - Electric - Power Systems (FS/W) 2 Jun 24, 2007 04:23 PM
Sold Jeti Advance 40 plus ESC, Like new! Speedo125 Aircraft - Electric - Power Systems (FS/W) 1 Dec 08, 2006 05:32 PM
Found Jeti Advance 40 Opto plus 34Ford Aircraft - General - Miscellaneous (FS/W) 3 Jan 13, 2006 07:05 PM
Sold Jeti Advance 40-3P opto plus with ultimate BEC electric-flyer Aircraft - Electric - Power Systems (FS/W) 4 Oct 28, 2005 08:59 PM
