Old Oct 10, 2005, 10:07 AM
down_shift is offline
Find More Posts by down_shift
down_shift's Avatar
United States, VA, Leesburg
Joined Feb 2003
Excite F5D lightweight
I will be using the Aveox 27/26/1.5 in the Excite F5D with the long nose cone. The APC 5x5 and 10 GP2000 cells pull around 50 amps. I would like to prop up to 60 amps burst, but be able to run all day long at 40 amps.
What is the next size prop to increase the current to 60 amps? Also, what would be a good lipo pack for this application?
down_shift is offline Find More Posts by down_shift
Old Oct 10, 2005, 10:17 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
5.2x5.2, or pitch up the 5x5?
..a
Old Oct 10, 2005, 10:18 AM
davidfee is online now
Find More Posts by davidfee
davidfee's Avatar
San Diego, CA, USA
Joined Mar 2001
APC 6x5.5E is what we use on our F5D-SD models. It may do what you're looking for.
-David
davidfee is online now Find More Posts by davidfee
Old Oct 10, 2005, 10:57 AM
jaywatay is offline
Find More Posts by jaywatay
electron liberator
jaywatay's Avatar
United States, GA, Suwanee
Joined Mar 2003
I use a 5.2x5.2 Graupner on my TL but the Graupner props break much easier than the APC's. I wish APC had a 5.5x5.5.
jaywatay is offline Find More Posts by jaywatay
Old Oct 10, 2005, 12:05 PM
sayno2glo is offline
Find More Posts by sayno2glo
I plan to take over world
sayno2glo's Avatar
Helsinki, Finland
Joined Jul 2002
Boil graupner props for few hours and keep them in wet plastic bag. They are then much stronger.
sayno2glo is offline Find More Posts by sayno2glo
Old Oct 10, 2005, 12:24 PM
down_shift's Avatar
Joined Feb 2003
Thanks for the prop suggestions. I did not know that APC made a larger prop for small pylon planes. Will try that graupner, too.
So what kind of speed should I expect? 120mph-ish?
Old Oct 11, 2005, 01:17 PM
ptxman is online now
Find More Posts by ptxman
Calgary, AB, Canada
Joined Oct 2002
APC has these 2 +/- sizes which might be made to work. It seems to me the Graupners run as though they de-pitch a bit from their nominal sizes compared to the APC's, mind you some of teh ones I run are carbon which are stiffer than the regulargrey. You can snip & repitch apc's too.
5.5 x 4.5E
5.25 x 6.25
http://www.ecubedrc.com/propsandadaptors.htm
ptxman is online now Find More Posts by ptxman
Old Oct 13, 2005, 07:23 PM
tufnik is offline
Find More Posts by tufnik
F5B, helis...too much
Fairfax, VA
Joined Mar 2002
apc
I do the same thing. Buy APC 6x5.5 and trim the tips down.
tufnik
tufnik is offline Find More Posts by tufnik
Old Oct 13, 2005, 07:25 PM
jaywatay is offline
electron liberator
jaywatay's Avatar
Joined Mar 2003
Thanks for the suggestion. I will do that as I like the APCs better anyway.
Old Oct 15, 2005, 02:49 PM
down_shift's Avatar
Joined Feb 2003
Could not get the plane to balance w/ 10 GP2000 in the traditional 5 by 5 pack. CG works with the two rows of 3 over 4 triangle.
Some old and tired FAUPs were used for the mock-up.
Old Oct 15, 2005, 02:50 PM
down_shift's Avatar
Joined Feb 2003
AUW is 31.1 oz.
Old Oct 15, 2005, 07:06 PM
tufnik is offline
Fairfax, VA
Joined Mar 2002
elevator
Good pics, Russ.
Am about to get started on mine. Please describe the elevator install in more detail. Does the rod curve up in the vertical? Is a thinner wire attached to the rod up toward the elevator? Where does that white tube start? Is tube glued to the fuse? I'm thinking about using a tube-in-tube cable and route it up the vertical stab, but maybe your set-up is better.
thanks,
tufnik
Old Oct 15, 2005, 07:15 PM
tufnik is offline
Fairfax, VA
Joined Mar 2002
Flight pack
Russ,
What size flight pack will you use and where do you get them from? Or are you using BEC?
tufnik
Old Oct 15, 2005, 07:32 PM
down_shift's Avatar
Joined Feb 2003
Originally Posted by tufnik
Good pics, Russ.
thanks,
tufnik
Yes, the rod curves up in the vertical. The 0.8mm wire is in the 1.0mm white tube for its entire length. The tube starts 1" behind the servo and is glassed to the bottom of the fuse every few inches. I used a CF rod (ex leading edge from a Shockie that is great for working in long and deep fuses.....) to dangle 1/4"x1/2" pieces of soaked glass to secure the tube to the fuse. Then for added measure, I pushed in some 3/16" balsa bulkheads that were sanded to shape. The tube is epoxied at the top of the fin and at the balsa rub in the vert fin. It is not going anywhere.
Download Excite F5D lightweight - video down_shift High Performance 23 Feb 07, 2006 04:02 PM
Discussion Excite F5D Fastest Setup soulys High Performance 42 Jan 18, 2006 04:05 PM
Excite F5D tufnik High Performance 55 Nov 28, 2005 02:31 PM
Sold Excite F5D MarcusT Aircraft - Electric - Airplanes (FS/W) 2 Nov 28, 2005 09:24 AM
News from the Excite F5D + !! videos !!! Elektrofly High Performance 15 Sep 27, 2005 10:29 AM
