Old Oct 10, 2005, 03:11 AM
theapodan@gmail.com
theapodan@gmail.com
Guest
n/a Posts
OS LA .40, whats it worth?
I have an O.S. LA 40, the blue version, that has never been run, and is
like new except for paint where I was markig holes and one of the
mounting holes is reamed out.
I have the muffler as well.
How much cash would I expect to get from this engine on ebay?
Thanks, Robert.
Also, if I'm thinking about buying a 1/2A trainer ARF, which one would
you suggest?
Old Oct 10, 2005, 07:11 AM
The Raven
The Raven
Guest
n/a Posts
Re: OS LA .40, whats it worth?
<theapodan@gmail.com> wrote in message
news:1128908907.328969.163740@g47g2000cwa.googlegr oups.com...
> Thanks, Robert.
> you suggest?
In Australia most people are now bypassing the 40LA for the 46LA. The price
has dropped to the point there is no reason to spend a few extra dollars and
get the 46LA.
Having said that, I have a 40LA which is a year old. It's perfectly run in
and fellow club members just can't believe how well it runs and flies
(particularly in heavy wind). It's no powerhouse and takes a while to get a
trainer upto take off speed (scale takeoff) but it's an honest engine.
If you have it, keep it. No-one will pay you what it's worth and it's good
enough to keep for a trainer or similar low powered aircraft.
PS. 40LA is selling for roughly $99AUD, 46LA is now getting down to $112AUD.
The Raven
http://www.80scartoons.co.uk/batfinkquote.mp3
** Now I will bring chaos to the world!
The Raven
The Raven
Guest
n/a Posts
"The Raven" <swilson150@yahoo.com.au> wrote in message
news:434a3e66$0$21734$afc38c87@news.optusnet.com.a u...
>> Thanks, Robert.
>> you suggest?
> price has dropped to the point there is no reason to spend a few extra
> dollars and get the 46LA.
> a trainer upto take off speed (scale takeoff) but it's an honest engine.
> $112AUD.
Correction, the 46LA in natural (non-blue) is now down to $95AUD.......
The Raven
Old Oct 10, 2005, 03:11 PM
\Doc\
\Doc\
Guest
n/a Posts
> Thanks, Robert.
> you suggest?
One aspect everyone has seemed to forget about is that one of the mounting
holes is "reamed out" which I interpret to mean "stripped." This will
require a retap and if someone doesn't have a tap and die set, the motor
will be useless to them. Depending on just how bad it is, there might not
even be room for a larger size tap, as this might put the hole too close to
the edge of the mount and be a point of weakness.
I'd list it on E-Bay for a starting price of $0.99 and see what you can get
out if it. It might be worth more in parts, so you could try selling the
carb, head, crankshaft, piston, muffler, etc. invidually.
Doc
Fubar of The HillPeople
Guest
n/a Posts
Why would you need to tap the mounting hole? My take is that it was drilled
out to a larger size for some reason. Only had 3 screws of the proper size
but a few screws of a larger size, maybe. Too far to the LHS or hardware
store but that larger drill bit was close by and handy?
None of my engines have threaded mounting holes, OS or otherwise.
Dan
AMA605992
KE6ERB
http://www.fubar1.net
"I've heard the screams of the vegetables..."
Take out the "trash" to reply
""Doc"" <nospam@noway.com> wrote in message
news:JNidnTRMnZksPNfeRVn-uQ@adelphia.com...
>> Thanks, Robert.
>> you suggest?
> to the edge of the mount and be a point of weakness.
> get out if it. It might be worth more in parts, so you could try selling
> the carb, head, crankshaft, piston, muffler, etc. invidually.
> Doc
theapodan@gmail.com
theapodan@gmail.com
Guest
n/a Posts
Yeah, I had reamed it out for a larger bolt. I hadn't messed with any
of the other screwed parts, like the head or backplate, if that's what
"Doc" was actually talking about.
Old Oct 10, 2005, 05:11 PM
theapodan@gmail.com
theapodan@gmail.com
Guest
n/a Posts
Well, does anyone want it for $45, shipped with insurance to the lower
48?
Brad Darnell
Brad Darnell
Guest
n/a Posts
Someone here would surely give you $30 for it. Ebay fees and such will eat
you up.
Brad
news:1128967708.527764.78770@g49g2000cwa.googlegro ups.com...
Old Oct 10, 2005, 09:11 PM
Guest
n/a Posts
I would keep it.
They are not bad engines, great for trainers. Also good for putting on .25
sized planes, people do it all the time.
My father flies his LT-40 ARF with one and it flies great. Usually has to
reduce the throttle to 1/4-1/2.
My first good engine was the .46LA. I still have it. Its been on more than a
few planes, gallons of fuel thru it, still runs like a champ.
Dan
AMA605992
KE6ERB
"Brad Darnell" <bdarnell1966@comcast.net> wrote in message
news:NY2dnReOTJASWtfeRVn-uw@comcast.com...
> you up.
> Brad
Old Oct 11, 2005, 07:11 AM
The Raven
The Raven
Guest
n/a Posts
>> Thanks, Robert.
>> you suggest?
The beam mounts aren't tapped to start with, just a plain hole that won't
take the more common sized mounting bolts found in most hobby shops (at
least in my case - Australia).
Why strip and sell and otherwise new engine? You'll never get much for it.
If the perceived value (to the current owner) is that low they may as well
give it to their club to raffle off.
The Raven
Old Oct 11, 2005, 11:11 AM
Carrell
Carrell
Guest
n/a Posts
> you suggest?
Take a look in the "Airplanes" section at www.sigmfg.com
The Neofun ARFs are 1/2A, as well as some of the Hacker models.
From www.quantummodels.com, the Norvel Vision and Classic are other
possibilities.
I think the Neofun and Norvel planes may actually be the same; just sold
under names.
There may be lots of others but these were easy to find.
1/2A engines are not cheap. The AP Wasp .061 is 40 bucks, Norvel engines are
slightly more expensive. The Norvel ARF planes are $75.
Unless model size or flying space is an issue, and you already have it, I'd
put the 40LA on an LT-40 ARF (or just about any 40 size trainer). The LT-40
ARF costs $132, and the Tower Hobbies Trainer 40 ARF costs $70; and lots
fall between these prices.
Just another opinion...
Carrell
Old Oct 11, 2005, 04:34 PM
indoruwet is offline
Find More Posts by indoruwet
God's gift to mankind for flying anything.
Joined Aug 2004
Built a "Battle Floyd" (about 45 USD). Stick that little engine on that and have a ball !!!
indoruwet is offline Find More Posts by indoruwet
Old Oct 12, 2005, 03:11 AM
theapodan@gmail.com
theapodan@gmail.com
Guest
n/a Posts
The reason I'm thinking about a smaller plane is that I have a small
car and small apartment.
Old Oct 12, 2005, 12:07 PM
Joined Aug 2004
The Battle Floyd fits in my trunk (Honda Accord), in one piece (wings attached).
How much smaller do you want it ?
Old Oct 13, 2005, 09:11 AM
Guest
n/a Posts
What, where, who makes the "Battle Floyd"?
Never heard of it, but being a rabid Pink Floyd fan, anything that has Floyd
in the name gets my attention.
Dan
AMA605992
KE6ERB
"indoruwet" <indoruwet.1wsu4b@rcgroups.com> wrote in message
news:indoruwet.1wsu4b@rcgroups.com...
> attached).
> indoruwet
> indoruwet's Profile: http://www.rcgroups.com/forums/member.php?u=38910
> View this thread: http://www.rcgroups.com/forums/showthread.php?t=425946
Alert Fs Os La 40 dubbs123 Aircraft - Fuel - Airplanes (FS/W) 11 May 28, 2005 04:28 AM
WTB: OS LA 40 or 46 crashed/wore-out/broke harikay Aircraft - Fuel - Airplanes (FS/W) 4 Feb 05, 2005 11:16 AM
OS la 40 muffler baffle sideways Engines 5 Jan 30, 2005 09:22 AM
OS LA .40- The best prop for this size! babenson Engines 3 Jan 26, 2005 11:54 PM
Idea FS: OS LA .40, OS FX .25, TT GP.15, starter, etc. KStelly Aircraft - Fuel - Airplanes (FS/W) 1 Feb 26, 2003 09:24 PM
