Old Oct 09, 2005, 01:09 PM
RCTyp is offline
Find More Posts by RCTyp
Smashes Things
RCTyp's Avatar
Montpelier, VA
Joined Feb 2005
Slow Ramp and Soft Start on Direct Drive Motor
Hi all,
When I use gear boxes I set the start to very soft and any throttle ramp to slow to protect the gears (when I don't I tend to strip them).
With direct drive, Hacker A30-28S and A30-16M in this case) does it matter to have a slow ramp on throttle? Can I just wham the throttle back and forth and not worry about the motor?
One more, exactly how many poles constitute high pole count?
Typ
RCTyp is offline Find More Posts by RCTyp
Old Oct 09, 2005, 02:50 PM
Sabrejock is offline
Find More Posts by Sabrejock
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Rapid throttle-up can cause spikes in Amps and momentary drops in voltage. Both might cause the controller to burp. Treat 'em gently. Tex.
Sabrejock is offline Find More Posts by Sabrejock
Putting GWS Direct Drive Motor on My Hummingbird. STaNgXs Micro Helis 6 May 18, 2005 11:27 AM
Question Prop adapter for 4mm prop on Direct Drive tail motor shaft? 14U2NV Parkflyers 1 Apr 20, 2004 04:01 PM
Question Prop adapter for 4mm prop on Direct Drive tail motor shaft? 14U2NV Micro Helis 0 Apr 20, 2004 01:39 PM
Astro 020 direct drive motor turning wrong way. kushal_22 Power Systems 1 May 12, 2002 05:17 PM
7x3 prop on direct drive 400 ferrite motor? daveh Power Systems 11 Dec 25, 2001 10:26 PM
