Old Dec 08, 2005, 01:56 PM
VACaver's Avatar
Usually underground in Virginia
Great. Thanks.
I normally cover my foam with Monokote, but I'm afraid that will add too much weight to this plane.
VACaver is offline Find More Posts by VACaver
Old Dec 08, 2005, 03:34 PM
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Originally Posted by VACaver
Steve,
You mentioned painting it with craft paint thinned 50/50 with windshield wiper fluid. Permit me to ask a possible stupid question...
Why windshield wiper fluid as a thinner?
Thanks.
Well, the reason I use it is because wiper fluid is alcohol-based, thus it evaporates much quicker than water--which means there's less chance of getting runs in the paint. I've thinned with both water and wiper fluid and thought both looked the same when dry.
Steve
jetset44 is offline Find More Posts by jetset44
Old Dec 08, 2005, 03:36 PM
Why aren't you out flyin?
colbyweb's Avatar
Overland Park, Kansas, United States
Joined Mar 2004
I've been using widshield wiper fluid for years as a thinner for acrylic paints. I don't claim to be an expert, but I've never noticed that it did anything for the finish. The reason I use it is that (one) it dries much faster than water and (two) it gives the paint a better consistency. It's also very cheap.
-Rick
colbyweb is offline Find More Posts by colbyweb
Old Dec 08, 2005, 09:24 PM
Frank Rys's Avatar
Monson,MA
Joined Mar 2000
Rubbing alcohol works great for thinning water based paint for airbrushing also, but washer fluid is cheaper....
Frank Rys is offline Find More Posts by Frank Rys
Old Dec 08, 2005, 11:13 PM
On patrol.
Cary Reeves's Avatar
Broomfield, Colorado
Joined Jun 2004
Another claimed advantage of washer fluid and the like (as opposed to plain water or alcohol) is that they contain wetting agents that help the paint to flow out better.
Cary Reeves is offline Find More Posts by Cary Reeves
Old Dec 11, 2005, 01:58 PM
London, UK
Joined Aug 2005
Just seen this thread and must comment your Fokker Dr1 looks really beautiful...I like the detailing "Fokker" logo in the back. I am a big fan of the shape and look of the the Dr1 unfortunately the consistent comment is that it is too difficult to fly for a newbie like me .... so I can only look but not touch
one day by heart will rule my head and I will begin a Dr1 build
arukum17 is offline Find More Posts by arukum17
Old Dec 11, 2005, 02:45 PM
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Thanks, arukum. Well, I hope you progress past the newbie stage quickly so you can build and fly your own DR1. This one certainly isn't a trainer, but it's also not all that hard to fly, either. Once you can comfortably fly a GWS Tiger Moth you can handle this. Of course, practicing on a flight simulator can also help prepare you for it.
Steve
Old Dec 11, 2005, 04:36 PM
VACaver's Avatar
Shaping Depron...
My order of Depron won't arrive until the 14th and I'm dying to get my hands on it (never seen any before).
Thinking about sanding leading edges on it got me to wondering if it's dense enough to round out with a table router without melting or chewing up the edge.
Anyone tried it?
Thanks.
Old Dec 11, 2005, 05:24 PM
Joined Feb 2005
Hi VACaver; I dremeled a small groove in the leading edge with a dremel and placed a 6mm carbon fiber rod in it. That really helped for the odd bash it got loading and unloading from the truck.
Gemitaur is offline Find More Posts by Gemitaur
Old Dec 11, 2005, 07:35 PM
colbyweb's Avatar
Joined Mar 2004
You've seen foam to go boxes from restaurants haven't you? It's almost identical. Or foam dinner plates or foam meat trays
Anyone tried it?
Thanks.
Should work if your cutters are sharp. I've done a lot routing on depron with a dremel tool. Also many parts have been cutout with a router for depron kits.
-Rick
Old Dec 11, 2005, 08:54 PM
Eject! Eject! Eject!
AeroDude's Avatar
Dayton, OH
Joined Sep 2004
I actually got to see 6mm Depron for the first time a the LHS, they had a high performance 3D plane made from Depron. It has a little higher density than the stuff I use, but what I use is only 4mm but works very very well, I stiffen all my wings with a spruce or CF spar and run a strip of straping tape from tip to tip on the top and bottom of the wing(s).
here are a few pic's of the Pitts bipe I built for my son for Xmas..
AD
AeroDude is offline Find More Posts by AeroDude
Old Dec 13, 2005, 07:55 PM
VACaver's Avatar
Hey, Aerodude,
How'd you wind up doing the single-servo for aileron thing? Looking at your pics, it reminds me kind of a GWS set-up.
Like you, I want to save weight and money.
Any chance you could post or PM me some detailed pics of how you did it?
No hurry...my Depron arrives tomorrow and I probably won't start on it until next week.
Thanks.
Old Dec 14, 2005, 06:25 AM
AeroDude's Avatar
Dayton, OH
Joined Sep 2004
VACaver,
In the case of the Pitts, the last pic (previous post) is of the bottom, you can see the servo installed into the bottom wing just ahead of the spar with the linkage running at an angle to each aileron, it's a Hitec HS-55 servo with an E-Flite S75 servo arm I had left over, fits perfect and works great. I attached the plans for the pitts if you want them as well. The plans are for a flat fuse version which I used as templates for my full fuse version with rounded wing tips and tail to be more Pitts like.
In the case of the DR-1, I did it the same as before in the 24" version, but used the E-Flite S75 servo with the large servo arms, see the last three pics in this post, you can see the linkage from the servo to the torque rods for each aileron, note for maximum travel you need to keep the torque rod arms short as possible, the farther out they come the less travel you will have. the last pic shows the servo installed vertically in an added bulkhead just ahead of the cockpit.
I would highly recommend using the new E-Flite S75 ($13.99) servo for the ailerons which is much stronger (17.02 oz/in) than the GWS or others of the same size and comes with larger servo arms.
http://www.horizonhobby.com/Shop/ByC...ProdID=EFLRS75
I hope all this helps, this was not a complicated build, take your time and it will workout great.
AD
Old Dec 14, 2005, 12:20 PM
Derick Veliz's Avatar
United States, MA, Warren
Joined May 2002
Dr-1
Another DR-1, just bigger not a 3D but still a parkflyer.
check out the video:
http://www.rcgroups.com/gallery/show...cat=510&page=1
Derick.
Derick Veliz is offline Find More Posts by Derick Veliz
Old Dec 23, 2005, 06:11 PM
VACaver's Avatar
Found a local cabinet maker who can laser cut my wood pieces for me. In fact, he seemed excited about it!
Hopefully, he won't charge me an arm and a leg.
I'm dying to start this build and will probably start cutting foam next week.
Video Fokker DR1 Parkflyer loyn Electric Plane Talk 0 Jun 14, 2007 06:27 PM
Help With Simprop Fokker DR1 CybaGirl Parkflyers 28 Aug 03, 2005 01:41 PM
Anybody built Simprop Fokker DR1 Toybox Foamies (Kits) 4 Oct 26, 2002 08:01 AM
Question Fokker Dr1 Guillows - Fly It? jimmyray Parkflyers 16 Dec 30, 2001 03:06 AM
Dare Models Fokker DR1 SMB Parkflyers 10 Nov 30, 2001 06:09 PM
