Old Oct 08, 2005, 02:08 PM
Rusted is offline
Find More Posts by Rusted
Wheres my money gone?
Rusted's Avatar
Colwyn Bay North Wales
Joined Apr 2005
how do i know when my engine is worn out???
i have had ym rush evo a whle now and i have had just over a gallon of feul through it. how do i know when its worn out??? the engine keeps stalling after a little while and i have tried everything else and the only thing i have brought it down to is the engine being worn out.
any help would be great!
Cheers
Chris
Rusted is offline Find More Posts by Rusted
Old Oct 08, 2005, 03:39 PM
Gorge Spencer is offline
Find More Posts by Gorge Spencer
just one person!
Gorge Spencer's Avatar
utah
Joined May 2005
how good of compression does ur engine have???
Gorge Spencer is offline Find More Posts by Gorge Spencer
Old Oct 08, 2005, 04:10 PM
Rusted is offline
Rusted's Avatar
Joined Apr 2005
on and off really sometimes wheni go to accelatrate the engine sounds like its drowning and sometimes the engine shoots off.
Old Oct 08, 2005, 04:30 PM
just one person!
utah
Joined May 2005
turn ur engine around past the compression and if it is hard to turn then ur engine should still be good
Old Oct 08, 2005, 10:25 PM
Kimber is offline
Find More Posts by Kimber
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Sounds like an intake air leak, loose carb or fuel line!!
After one gallon, it should be just broke in good!!
Do you take good care of the airfilter??
Kimber is offline Find More Posts by Kimber
Old Oct 09, 2005, 01:28 AM
trdmatrix is offline
Find More Posts by trdmatrix
Joined Apr 2005
Two ways I check my compression:
1. with the head and glow plug on, I turn the flywheel until about 10 degrees BTDC (before top dead center) and hold it there for a few seconds and then see if it is much easier to go past TDC.
2. Take the head off and see how tight the piston and sleeve are; again turning the flywheel see how much of a pinch you get near TDC.
trdmatrix is offline Find More Posts by trdmatrix
Old Oct 10, 2005, 03:32 AM
Rusted is offline
Rusted's Avatar
Joined Apr 2005
i take quit good care of the filter but it might need a bit of a clean. how does it effect the cutting of the engine apart from being blocked?
Old Oct 10, 2005, 08:40 AM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
If the airfilter is blocked, it will make the engine run rich!!
If you don't clean it often, it will also add to early engine
wear out!!
We have four spares and change about once an hour!!
If it is real dusty, more often!!
My car has three gallons of fuel through it and it
runs fine!!
Brad has a boat motor, OS 21, with about 25 gallons of fuel
through it and it runs great!! It is about 15 years old!!
Old Oct 10, 2005, 02:38 PM
Rusted is offline
Rusted's Avatar
Joined Apr 2005
it turns out it was a bad glow plug and it wasnt working properly.
i changed it and it works allright now
i also took the dust cover off fo the airfilter and its running even better now!
Cheers guys
Chris
Old Oct 10, 2005, 05:00 PM
Eeeeky is offline
Find More Posts by Eeeeky
Eeeeky's Avatar
Roosevelt UT
i was thinken that at first cause that is the symptoms of a bad glow plug. but my friend said to ask if ur engine was broke in but it turns out that i was right. glade that u figured out ur problem
jake
Eeeeky is offline Find More Posts by Eeeeky
Old Oct 10, 2005, 05:05 PM
just one person!
utah
Joined May 2005
jake
sorry i was logged in as my friends user name and i forgot to log out of his so i am fixing my mistake sorry for any confusion
Jake
Discussion how do i know when my engine is shot?? car guy Nitro and Glow Power Cars 8 Apr 23, 2012 08:47 AM
Help! How do I know if my tail motor's burned out? trashmanf Micro Helis 16 Jan 26, 2006 06:38 PM
How do I know if my rx battery is toast? cruzomatic Batteries and Chargers 6 Jun 07, 2003 10:29 PM
Question Ni-Cad batteries, how do I know when they are fully charged gaseousfool Batteries and Chargers 7 Mar 05, 2003 08:18 PM
How do I know if my Zagi is balanced? RandyK1 Foamies (Kits) 2 Dec 27, 2002 11:45 PM
