Old Oct 08, 2005, 11:36 AM
War Bird Radio is offline
Find More Posts by War Bird Radio
"Superior Air Power"
War Bird Radio's Avatar
Stayton, Oregon, USA
Joined May 2003
Converting a Talon to Super Talon EP
After seeing a Talon sloper then reading Kevin McDonalds thread on the Super Talon, I decided to do my own Super Talon EP conversion.
For more info on the Super Talon http://www.kjmdesign.com/kjm_m04_stalon.htm
I started with a standard Talon kit. The balsa is on the dense side but the density is consistant and the wood is of good quality. The Talon has die cut parts. The die cutting is not bad as die cutting goes.
Using the kit, Kevin's conversion instructions and a little ingenuity I shall proceed to build a relatively light 60" powered glider... I hope!
John
War Bird Radio is offline Find More Posts by War Bird Radio
Old Oct 08, 2005, 11:41 AM
Joined May 2003
The build has begun.
Old Oct 08, 2005, 11:47 AM
Joined May 2003
The fuse and CF are coated with ployurathane varnish. The idea is light but strong.
More fuse pics.
John
Old Oct 08, 2005, 12:07 PM
Joined May 2003
Tail group assembly and installation.
Since the wing span is being extended 10" (50" to 60") and the fuse was lengthend 1", I thought to enlarge the tail group too. I scanned the tail group from the plans and enlarged them 120%. Used 3/16 balsa instead of 1/8 for the tail group.
The supplied contol horn assembly of steel and brass is 11 grams... Too heavy! Used carbon fiber tube and rod to build one at 1 gram.... Much better.
The fuse with tail group and push rod installed weighs 3.4 oz
John
Old Oct 09, 2005, 03:12 PM
Joined May 2003
Wing panel build.
Cut two extra root ribs per wing panel and extended plan at root.
Noticed on Kevin's Super Talon page that his wings taper again near the tips. I've tried to duplicate that added taper on the plans and will build it into my wing.
John
Old Oct 17, 2005, 11:53 AM
JLSalas is offline
Find More Posts by JLSalas
JLSalas's Avatar
Santiago Pudahuel, Chile
Joined May 2003
Hi John, you are building a "Super" model
Very nice indeed!!. Did You reinforce with cf the inside of the fuse?
Your weight is very light, and with the increase in wing span will be very well manered in flight.
You can see my conversion at http://www.rcgroups.com/forums/showthread.php?t=120807.
JL
JLSalas is offline Find More Posts by JLSalas
Old Oct 17, 2005, 08:44 PM
Joined May 2003
JL,
Yes, I have read your thread on your powered Talon. That was nice work on converting your Talon to electric.
My Super Talon EP is now a Super Talon sloper. I decided to not make it electric. Also, I used a wing from a Filip 400 RG I had. My Filip was set up to be a hot liner but the fuse is very fragile. After about 10-15 flights cracks started to form around the cockpit. I reinforced the forward part of the fuse with carbon fiber but the cracks grew until the fuse was not usable. I removed the gear from the Filip and saved the wing. The wing is 60 inch span with about 0.5 inch more cord then the original Talon wing. I was able to mount it like the Talon wing only the bolt block was moved forward of former #2 and reinforced with carbon fiber.
Yes, I reinforced the inside of the fuse with carbon fiber, tho the Talon has a strong fuse compared to the Filip.
I now need to install the radio gear and the Super Talon is ready for the slope.
John
Old Oct 17, 2005, 09:43 PM
JLSalas is offline
JLSalas's Avatar
Joined May 2003
wow!!
your Super is super!! The wing seems to be designed for the super Talon.
JL
Old Nov 05, 2005, 09:40 PM
Joined May 2003
The Super Talon flew it's maiden voyage on Nov. 4. Everything went great. I actually had to put a couple clicks of down trim and it was very stable. It stays up on very light lift keeping up with my friends Spinner but retains energy better and handles a good deal of wind. The carbon fiber control horn assembly for the flying horizontal stab is working out nicely. I was concerned aobut the CF flexing too much, doesn't seem to be an issue. I also made my own servo covers for the wing since I lost the origianls.
I am very pleased how this plane turned out. I can say it is really one of a kind being part scratch built, part kit and part ARF.
Old Nov 06, 2005, 08:05 PM
Tshires is offline
Find More Posts by Tshires
Oregon, United States
Joined Jul 2004
War Bird,
Very Nice! Very nice indeed!
Tony
Tshires is offline Find More Posts by Tshires
Old Nov 06, 2005, 08:34 PM
Joined May 2003
Hi Tony,
I hope people aren't getting tired of me posting pics of this plane here and other places. I'm just excited with how well it turned out that I want to share it with others.
Hey Tony, when do you plan to come to Peterson Butte? Would like to meet up with you. Mabey I'll have the camera installed in the 2 mtr by then, I could take pics of your planes in the air! Plane to plane slope photos!
Let me know when you can make it and I'll try to be there. This weekend was little wind and much rain.
John
Old Nov 06, 2005, 09:08 PM
JLSalas is offline
JLSalas's Avatar
Joined May 2003
John:
The Talon retains energy and flies with wind very well.
Did you perform some aerobatics with your Super?
JL
Old Nov 06, 2005, 09:22 PM
Joined May 2003
JL,
Yes, I did loops, rolls and stall turns. Loops are very tight, large loops are easy, it has a tendency to snap roll if you pull up hard and fast. Rolls are on the slow side because of the medium aileron throws, I can always increase throws. Inverted flight is a bit sloppy because of dihedral in the wing. Stall turns or half pipes are great. Last wedensday I was formation flying with a Mog, we were half pipeing at each end. The Super Talon really pics up speed coming out of a turn and retains it so I could go farther vertical in the next turn. I'll have to get some video.
John
Old Nov 07, 2005, 08:58 PM
JLSalas is offline
JLSalas's Avatar
Joined May 2003
That would be great!
JL
Old Nov 08, 2005, 07:49 PM
Tshires is offline
Joined Jul 2004
War Bird,
Never get tired of looking at pics of sailplanes. I have a Talon in the box and now am wondering if maybe I should make it into a super talon? But I also noticed that they are on sale at Hobby People for only $34.99! So maybe Ill do the first one stock and get a second to modify? I need to get some other projects off the build board first.
Hoping to make it down to Peterson Butte in the next few weekends. Ill PM you a day or two in advance and hope we can fly together. Plane to plane photos sound really cool.
Tony
Discussion Converting a Super Sportster EP to LiPo Batteries sdemster Electric Plane Talk 22 May 05, 2007 02:15 AM
Super Talon KJMDES Slope 8 Aug 17, 2005 05:57 PM
Super Talon KJMDES Sailplane Talk 3 Aug 16, 2005 11:50 AM
Super Talon KJMDES Slope 0 Aug 16, 2005 06:35 AM
