Old May 15, 2002, 09:50 AM
CHRIS_00 is offline
Find More Posts by CHRIS_00
LOS ANGELES CA. USA
Joined Feb 2001
What Type Of Amperage Are You Guys Pulling On 40 Amp Brushless Controllers
I just ordered a Hacker master 77amp speed controller from Kirk over at New Creations. I was a little nervous about trying to put 51 amps on my other Hacker Master controller because it is only rated for 40 amps.
My question is what kind of amp draw are you guys out there putting on the various 40 amp brushless speed controllers (Hacker Master, Kontronik, Kontronik Beat, Jeti or any others out there) I am very interested to see how far some of you are pushing these babies. How far over the rating can these controllers go.
Thanks guys in advance.
CHRIS_00 is offline Find More Posts by CHRIS_00
Old May 15, 2002, 02:28 PM
dr.E is offline
Find More Posts by dr.E
Don't cut the Yellow Wire
dr.E's Avatar
Ridgewood ,NJ
Joined Jan 2000
A friend of ours runs a Phasoar 30-3 with 40 amp jeti controler on 10 cells 12x8 prop on a Bandit draws 52 amps hot off the charge.
Goodtill is running a phasoar 30-3 jeti 40 esc on 8 cells and a 12x10 prop at 41 amps hot off the charge.
dr.E is offline Find More Posts by dr.E
Old May 15, 2002, 06:59 PM
Ben74 is offline
Find More Posts by Ben74
Ben74's Avatar
San Francisco, CA, USA
Joined Jun 2001
i'm running 44A peak thru my MGM TMM 40e-3ph. it gets pretty hot, but i haven't let the smoke out yet
Ben74 is offline Find More Posts by Ben74
Rave What size wing bolts are you guys using on large scale? ndflicks Giant Scale Airplanes 4 Mar 15, 2005 09:27 PM
What batterys are you guys using on your CD-Rom motors? flying4fun 3D Flying 2 Oct 16, 2004 02:44 PM
Question What type of connector are you using on your Lipo's? mr_ken Batteries and Chargers 14 Jan 15, 2004 01:11 AM
What kinda PROPS are you guys using? APC? GWS?? Tram Parkflyers 37 Jun 04, 2003 11:02 AM
What kinda AMPS are you guys pulling with the mega16/15/3? kushal_22 Foamies (Kits) 2 Jun 16, 2002 08:51 AM
