Old Oct 07, 2005, 10:25 PM
nubebuilder is offline
Find More Posts by nubebuilder
Joined Sep 2005
Bristol M1C build
Hi all.I,m new to rc this past year,have a sig LT 40 that I built ,then modified,clipped wings ,less dihedral,now a beginner sport plane.I,ve decided to try my hand at scratch building and have started on a BristolM1C.Drawing my plans from windsock datafile 3 views scaled up to 1/6 scale.RCV 60 SP for power.Everything was going fine till I read about wash out.The wing has a flat bottom profile,kind of a thin clark y.What I need to know is,do I need to add wash out to this shape of wing? If so ,how much? all so, On the full size plane the wing was set at 0 deg incidence.I understand that clark y starts to lift at - 1.5 deg,will 0 deg be realistic to use on my plane? Thanks Guy.
nubebuilder is offline Find More Posts by nubebuilder
Old Oct 24, 2005, 06:49 PM
Tom Cz is offline
Find More Posts by Tom Cz
Central Florida
Joined May 2005
Bristol M1c
0 incidence will work fine
Tom Cz is offline Find More Posts by Tom Cz
Old Oct 24, 2005, 11:26 PM
Joined Sep 2005
Tom,thanks for the answer.Any other tips you can give me? Do you use aileron differential ? Do you use flying wires to keep the thin wing where it,s supposed to be ? Any info you can pass along is greatly appreciated .Your plane is very sharp! Guy.
Old Oct 27, 2005, 05:08 AM
Tom Cz is offline
Central Florida
Joined May 2005
bristol m 1
all wires are functional, no differential used.....wing mounting bolts on bottom of wing
Old Oct 28, 2005, 02:03 PM
Joined Sep 2005
Thanks again. Ive been driveing myself nuts trying to figure out a good way to mount the wing,yours is good.Where did you put ailerol hinges? Top ,bottom or centered? Guy.
Old Oct 28, 2005, 05:47 PM
Kiwi is offline
Find More Posts by Kiwi
Kiwi's Avatar
New Zealand, Otago, Harwood
Joined Sep 2004
Plenty of photos on the web of the sample (replica) in the RAF Museum which is where I got my scheme came from.
Kiwi is offline Find More Posts by Kiwi
Old Oct 29, 2005, 09:06 PM
Tom Cz is offline
Central Florida
Joined May 2005
m1c
Hinges are centered
Old Oct 30, 2005, 12:31 AM
Joined Sep 2005
Tom,Thanks for the info. Photo is great.You have a lot of detail in your plane that I had not noticed in your other photos.Any suggestions on what to use to make a sturdy and safe spinner? Guy.
Last edited by nubebuilder; Oct 30, 2005 at 12:41 AM. Reason: Found answer in search
Old Oct 31, 2005, 07:36 AM
Tom Cz is offline
Central Florida
Joined May 2005
m1c
Spinner is fabricated from a recessed light fixture's reflector......special starter is self explanatory
Old Nov 01, 2005, 06:39 PM
Joined Sep 2005
Hmmm,Maybe I can find a small light fixture to use,my plane is a bit smaller than yours.The starter cone is great! Thanks for the help and shareing your ideas.Guy.
SIG Bristol Scout Build (A Novices Saga) Wasi28 Parkflyers 429 Aug 24, 2016 05:36 PM
Build Log Peter Rake's Bristol M1c Pat Lynch Scale Kit/Scratch Built 340 Aug 04, 2016 12:49 AM
Build Log Bristol F2B Build Tim Farrar Scale Fuel Planes 719 Jan 29, 2012 06:15 PM
Jim Wilkerson's Bristol Scout build JIMA Scale Kit/Scratch Built 67 Oct 22, 2003 01:16 PM
Bristol M1C...from across the waves.... gpw Foamies (Kits) 9 Jan 23, 2003 08:36 AM
