Old Oct 07, 2005, 07:51 PM
Happymcc is offline
Find More Posts by Happymcc
I USE CAPS - EYE TROUBLE
Happymcc's Avatar
Joined Aug 2004
FAQ
Everything You Always Wanted To Know About A Trex
They are big and ugly,large teeth,kind of smelly,walks on two legs
No the ones with Rotating Blades on there Head
Hope this is some help to all flying a Trex .
Comments and suggestions are welcome .
How To
Finless Bob
I must compliment Finless Bob and suggest that all could benefit from his
video's . I have learned to fly Heli's with no one in the area to talk with
and believe me this was hard to do . Over this year I have had the occasion
to talk one on one with just a few Heli pilots . I find these video's almost as
good as one on one communication and I recommend them to all .
And I give a Thank You to Finless Bob for his efforts , you can find them here
http://www.rcgroups.com/forums/showthread.php?t=491558
Faster Tail
Trex versions
http://www.rcgroups.com/forums/showp...&postcount=599
Alert !!! ( Potential problems , things to check )
T-rex 450xl-se
http://runryder.com/helicopter/t216172p1/
http://www.rcgroups.com/forums/showthread.php?t=517264
Which Aline Trex
http://www.rcgroups.com/forums/showthread.php?t=381247
http://www.rcgroups.com/forums/showthread.php?t=511031
Align T-Rex 450XL Superior Edition
http://www.rcgroups.com/links/index.php?id=4921
HDE V's CDE
http://www.rcgroups.com/forums/showthread.php?t=402811
Which Trex ?
http://www.rcgroups.com/forums/showthread.php?t=407744
Trex SE
http://www.rcgroups.com/forums/showthread.php?t=506027
Align's Products
http://www.rcgroups.com/forums/showthread.php?t=327061
Beltless Trex
http://www.rcgroups.com/forums/showthread.php?t=492675
DIY Trex
http://www.rcgroups.com/forums/showthread.php?t=390988
http://www.rcgroups.com/forums/showthread.php?t=548178
http://www.rcgroups.com/forums/showthread.php?t=482757
What weight is your Trex
http://www.rcgroups.com/forums/showthread.php?t=396707
Trex canopy
http://www.rcgroups.com/forums/showthread.php?t=536958
How to fly
http://www.rcgroups.com/forums/showthread.php?t=536889
ESC
http://www.rcgroups.com/forums/showthread.php?t=533718
http://www.rcgroups.com/forums/showthread.php?t=527351
Servo
http://www.rcgroups.com/forums/showthread.php?t=533153
Show off your Trex
http://www.rcgroups.com/forums/showthread.php?t=359165
Manuals
450XL HDE
http://www.trextuning.com/manual_all.pdf
450XL CDE (CCPM)
http://www.trextuning.com/Trex%20450...M%20Manual.pdf
Linkage Length Sheet
http://www.rcgroups.com/forums/showthread.php?t=440578
Free Pitch Gauge
http://www.rcgroups.com/forums/showthread.php?t=342799
Upgrades
Microheli
http://www.rcgroups.com/forums/showthread.php?t=420611
Aline Bling
http://www.rcgroups.com/forums/showt...ighlight=trex+
Sparrow Blade Grips
http://www.rcgroups.com/forums/showthread.php?t=389659
Microheli
http://www.rcgroups.com/forums/showthread.php?t=418631
Which upgrades to get
http://www.rcgroups.com/forums/showthread.php?t=416370
Duzi
http://www.rcgroups.com/forums/showthread.php?t=397407
Things you might need after a minor crash
http://www.rcgroups.com/forums/showthread.php?t=426746
Show off you Trex
http://www.rcgroups.com/forums/showthread.php?t=410170
http://www.rcgroups.com/forums/showthread.php?t=412896
Which Blades
http://www.rcgroups.com/forums/showthread.php?t=529021
Which Motor ( need more links here please send them to me )
http://www.rcgroups.com/forums/showthread.php?t=514047
http://www.rcgroups.com/forums/showthread.php?t=308151
http://www.rcgroups.com/forums/showthread.php?t=536039
http://www.rcgroups.com/forums/showthread.php?t=415345
Tech info on the 450th ( not RCgroups )
http://www.justgofly.com/tech_450TH.htm
Batteries
Keeping them cool
http://www.rcgroups.com/forums/showt...50#post4802359
Problems
Tail Wag
http://www.rcgroups.com/forums/showthread.php?t=547890
Motor
http://www.rcgroups.com/forums/showthread.php?t=421020
Vibration
http://www.rcgroups.com/forums/showthread.php?t=416830
Glitching
http://www.rcgroups.com/forums/showthread.php?t=415187
http://www.rcgroups.com/forums/showthread.php?t=394176
Belt Tracking
http://www.rcgroups.com/forums/showthread.php?t=418198
Twitching
http://www.rcgroups.com/forums/showthread.php?t=401388
Did not like
http://www.rcgroups.com/forums/showthread.php?t=360384
Belt Pully
http://www.rcgroups.com/forums/showthread.php?t=403218
Trex V's Other Heli's
Shogun
http://www.rcgroups.com/forums/showthread.php?t=419614
X-400
http://www.rcgroups.com/forums/showthread.php?t=417515
Trex Video
http://www.rcgroups.com/forums/showthread.php?t=432260
http://trextuning.com/videos.htm
http://www.rcgroups.com/forums/showthread.php?t=421318
http://www.rcgroups.com/forums/showthread.php?t=422911
Opps I hit the Ground
http://www.rcgroups.com/forums/showthread.php?t=508316
http://www.rcgroups.com/forums/showthread.php?t=416756
http://www.rcgroups.com/forums/showthread.php?t=409734
Other interesting stuff
Flight case
http://www.rcgroups.com/forums/showthread.php?t=422163
Tail rotor
http://www.rcgroups.com/forums/showthread.php?t=418954
Telebee gyro
http://www.rcgroups.com/forums/showthread.php?t=418016
Belt tension
http://www.rcgroups.com/forums/showthread.php?t=416927
Trex going scale
http://www.rcgroups.com/forums/showthread.php?t=376848
How heavy is your Trex
Flybarless
http://www.rcgroups.com/forums/showthread.php?t=403573
Happymcc is offline Find More Posts by Happymcc
Old Oct 07, 2005, 07:54 PM
Happymcc is offline
Happymcc's Avatar
Joined Aug 2004
I started with a V2 and was disappionted .
I read a lot here at RCgroups in Micro Helis .
Then I chose to buy these parts for my Trex
Aline Parts
CCPM Carbon Frame
Carbon Boom ( Stretch Kit )
Carbon Tail Fins
Gears and Shaft
Landing Gear
Metal Tail Case and Blade Grips
Tail Controler Control Set ( XL )
Complete Metal Head Set
Metal Swash Plate
Black Plastic Ball Link Set
Motor Heat Sink
Trex 400XL Case
Other Parts
Futaba 401 Gyro
Mega 16/15/3 Brushless
Castle Creations 35 Phoenix Controler (What a company
Hitec HS56 Carbonite
Thunder Power Pro Lite 3 Cell 2100 Mah 15C
SAB 320MM Carbon Main Blades
I think I would like to have one of the Black Plastic CCPM versions also .
Old Oct 07, 2005, 08:09 PM
will p3 is offline
Find More Posts by will p3
Joined Aug 2003
I like your canopy, you are probably one of the few people out there that actually believes that there is no pilot and no need for a window for him to see through, nice one .
will p3 is offline Find More Posts by will p3
Old Oct 07, 2005, 08:51 PM
cat5 is online now
Find More Posts by cat5
United States, KY, Florence
Joined Aug 2005
Someday I might try a trex. What is the differences in the versions? X, XL, ect??
cat5 is online now Find More Posts by cat5
Old Oct 07, 2005, 09:09 PM
ozace is offline
Find More Posts by ozace
Renewed interest
ozace's Avatar
Melbourne , Australia
Joined Jun 2002
My Trex wisdom, skip all the plastic stuff and go to the CF frames and all the ali bling, while you are shoping get a neu motor and have some fun. The only downside is the cost. I have been thru 5 trex's now and only the latest all bling version is worth keeping.
ozace is offline Find More Posts by ozace
Old Oct 07, 2005, 09:32 PM
McDanger is offline
Find More Posts by McDanger
Aberdeen,Scotland, UK
Joined Jun 2005
loving the idea of this thread guys..thnx!
im in the process of getting a "semi blingy" 1st proper cp micro,, been about,,,ooh err.. 6 months? with a V3 fp hummer,,been loving it,,finally something clicked, and my brain is more or less heli flying wired now ...side on, nose in, piros,circuits, wonky looking 8's , i will always keep and use my hummer i think for all the indoor fun(not to mention how much ive now spent on it) .......anyway..it is time,basically from what ive been reading the last week or so is..."wait for the XL SE,released any day now", is going to be vastly better than the XL CDE CCPM? (semi bling remember) ,,, i will be watching here lots now to see whats cooking, oh,,,anyone got a release date or something for the XL SE ?
McDanger is offline Find More Posts by McDanger
Old Oct 08, 2005, 03:05 AM
Tonystott is offline
Find More Posts by Tonystott
Its all fun
Tonystott's Avatar
Australia, NSW, Forster
Then again, why reinvent the wheel? trextuning.com has everything you have suggested and way more. but it is a good idea anyway.
Tonystott is offline Find More Posts by Tonystott
Old Oct 08, 2005, 03:07 AM
ozace is offline
Renewed interest
ozace's Avatar
Joined Jun 2002
cos the spam site is full of glowing reviews for stuff that he was given
Old Oct 08, 2005, 03:18 AM
Its all fun
Tonystott's Avatar
Actually Will, I disagree with you on that front. While of course there isn't a little pilot in there, but to me, I reckon most of the pod and boom canopies have become total charactitures (sp?).
I just painted up a clear canopy, and tried to give it at least a touch of realism, by extending the window-line to make it reminiscent of a BA Hawk or 2 seat glider. Even if I do say so myself (why hold back ), I reckon the difference it makes is worth the effort.
Old Oct 08, 2005, 03:25 AM
will p3 is offline
Joined Aug 2003
yeah that looks real i saw a full size fly past the other day, looked just like that one, did 3d and everything, looks good though, i like the ba lines, youve captured well!
Old Oct 08, 2005, 09:45 AM
Happymcc is offline
Happymcc's Avatar
Joined Aug 2004
Please stick to helpful info for readers . I know I do not like to read a thread
where people are bickering , so none of that please .
I know that I almost lost my above mentioned Trex
Do to installing all the Blue Metal Head Bling and not rechecking the screws
on the ball links . Was showing it off and noticed one screw about to fall out .
Took all the ball link screws out that went into metal and found only two that
had Loctite on them . Put them all back in with blue Loctite .
Old Oct 08, 2005, 09:48 AM
Happymcc is offline
Happymcc's Avatar
Joined Aug 2004
Tonystott
I love the canopy .
As I am starting to get , well I am 50 years of young . But my eyes need all
the help they can get . Good colors to see in the air .
Old Oct 08, 2005, 12:37 PM
tommyeflight89 is offline
Find More Posts by tommyeflight89
ARF Hater Club
tommyeflight89's Avatar
Toronto, Ontario
Joined May 2004
My B-Day is on the 14th and i have asked for a Rex XL hde. It will be the grand rc combo with 4x hs56, an electron 6, MAP Antenna, align 25 esc and align motor. I already know i am getting this because my parnets gave me the Gy401 early, thinking i could use it without the heli (shows how much they know) I am gonna get either 3s apogee 2480 or a tp 2100 3s prolite. Hows this all sound to you guys? Ill post some pics in about a week when i get all the goodies!
tommyeflight89 is offline Find More Posts by tommyeflight89
Old Oct 08, 2005, 01:24 PM
Happymcc is offline
Happymcc's Avatar
Joined Aug 2004
Sounds Great Tommy . Happy Birthday and have fun
Be sure to look back here when you start the build
(This thread and RCgroups in general )
Old Oct 08, 2005, 01:51 PM
Rickenbacker is offline
Find More Posts by Rickenbacker
Sunday Flier
Rickenbacker's Avatar
Sweden
Joined May 2005
Some short tips:
Don't bother with upgrades in the beginning, just buy them as you break stuff. It flies fine out of the box.
Buy a good gyro, like the Futaba Gy-401. You might still get some tail wag, since the tail linkage isn't the worlds most solid, but it'll save you some headaches like drifting etc that you get with cheaper gyros.
Use the wood blades. If you should somehow manage to track the plastic ones, they'll still fly like ****, and probably won't break in a crash, which means more force transferred to more expensive parts in the head and frame.
Paint you canopy in a two-tone pattern (and if you mount the "glass", preferably paint it black) with clear and contrasting colors. I know black looks cool, but this heli is hard enough to see at a distance, you'll need any help you can get.
Rickenbacker is offline Find More Posts by Rickenbacker
Discussion CROSS COUNTRY PROJECT... OR... EVERYTHING YOU WANTED TO KNOW ABOUT XC on the Cheap :) steelhead Cross Country Soaring 319 May 15, 2010 07:03 AM
Discussion You guys wanted to know about the Phantom revjwb32 Micro Ready-to-Fly 13 Apr 23, 2007 04:34 PM
Discussion Everything You Wanted To Know About Anything hoppy Electric Plane Talk 1 Nov 18, 2006 10:37 AM
All you wanted to know about motors but was afraid to ask DanC Power Systems 1 Sep 11, 2001 08:41 AM
