Shirley, New York, United States
Joined Apr 2002
hornet all the way
I was in the same boat you are in a few weeks ago. I went with the hornet. You can use your 5amp esc, your pico servos. You'll need a gyro- PG-03 is good. ($50 or so). Good batteries for the hornet are 8cell NIMH 720's, in square config.
Check out Dee tee enterprises (www.deeteeenterprises.com) they are one of the bigger hornet dealers in the usa. The Corona is another option - - But you'd need a bigger ESC, and I believe bigger servos? (corona guys, correct me if I'm wrong) -Adam |
Gainesville, FL, US
Joined Jun 2001
Hello
If you are just getting into helis and you are looking at micros, the Piccolo is the right one for you. This little heli can take some abuse. I accidently crashed one into my computer(battery dumped and I couldnt climb). It took me about one min to get it back together and I to fly what was left of the pack. http://www.dreamhobbies.com/dreamhome.htm There is only one mod I would recommend and that is the aluminum head bearing hub. http://www.helihobby.com/Modificatio...colo_mods.html Also, dont forget the House Fly(version 2). Troy(LS77) in Arizona learned how to fly heli on the House FLY. It already includes a aluminum swash and the aluminum head hub. To make it super strong, Mario also sells the aluminum head for it. Note it is a sub micro helicoter(smaller than the Piccolo), which means even less weight. http://www.micro-flight.com/index.htm The Hornet is more of a high preformance helicopter, and boy does scream when it is on. Personally I don think would like to fly it in my apartment. One thing I like to tell people before they start is to be smart about replacement parts. You dont have to always buy the parts sold by each company, because there are substutes(saves you lots of money). An example is booms, I purchased a length of carbon kite spar(5.5mm dia) from http://www.acp-composites.com/ for 1 dollar. I made 2 booms out of what I purchased and the tub is also stronger than the stock boom. Im pretty sure you can also purchase the carbon rods for the legs too. Jus make sure to do your home work and you will have lots of fun in this hobbie ![]() Carlo |
Gainesville, FL, US
Joined Jun 2001
Oh, what radio do you have.
If you need a mixer,to mix the tail with the main motor, I believe Mario still has these available. http://www.micro-flight.com/index.htm Carlo |
| Thread Tools | |
| Discussion looking into micro helis | mat3833 | Micro Helis | 12 | Aug 31, 2006 10:54 AM |
| Consdering getting into Micro Helis after some timer on Fixed Wing... | Mindblade | Electric Heli Talk | 9 | Nov 03, 2003 11:42 PM |
| Eager Newbie Needs Help - Please! | pfchico | Parkflyers | 11 | Nov 25, 2001 09:16 AM |
