Old Oct 06, 2005, 05:26 PM
Santini is offline
Find More Posts by Santini
The Great Santini
Santini's Avatar
Madison, NJ 07940
Joined Dec 2004
I have two GWSDFs. I keep the blades pretty loose... so they move freely. They fly great. I find that the death wobble comes from one or more of the following issues, which takes a little time to learn how to identify and fix:
Is your main gear/shaft bent?
Are the paddles aligned and sit precisely the same distance from the head?
(Can you spin up the heli without the main blades on and have zero vibration?)
Are the blades perfectly balanced for cog, and dynamically? This is really critical IMHO.
Is the tracking off?
Anyway, I step through these and seem to have consistent success, so I am really not a buyer of the idea of tightening down the blades or other remendies to advance the blades. I have been running stocks and like 90s both loosey goosey. The problem with tightening the blades is you may snap them in a crash.
Santini is offline Find More Posts by Santini
Old Oct 06, 2005, 05:36 PM
Eeeeky is offline
Find More Posts by Eeeeky
Eeeeky's Avatar
Roosevelt UT
ok somethings really been driving me absolutely NUTS what the hell does "IMHO" mean???
thanx
Aeryk
Eeeeky is offline Find More Posts by Eeeeky
Old Oct 06, 2005, 05:45 PM
imodel is offline
Find More Posts by imodel
USA, CT, Farmington
Joined Nov 2003
IMHO = In My Humble Opinion
imodel is offline Find More Posts by imodel
Old Oct 06, 2005, 06:32 PM
kryptoniteRxn is offline
Find More Posts by kryptoniteRxn
NO NO come back...spLAT!!
United States, CA, Anaheim
Joined Sep 2005
add to that frustration, what does BTW mean???
to stay on topic, when trying to screw a bolt or allen screw into hard to reach places (like the two allen screws that secure the motor to Trex v3 frame), rip a piece of tissue or paper and wrap the tool head, then insert the screw, then guide it in place, it's alot easier for me than to put the screw with my big fiingers then try to fit the tool into the screw and screw it in.
here's a pic, speaks for itself
kryptoniteRxn is offline Find More Posts by kryptoniteRxn
Old Oct 06, 2005, 06:35 PM
VACaver is offline
Find More Posts by VACaver
VACaver's Avatar
Usually underground in Virginia
If plastic, take the head assembly apart and clean/remove any excess flashing. My Blade had a ton of it.
VACaver is offline Find More Posts by VACaver
Old Oct 06, 2005, 06:53 PM
More Power!! is offline
Find More Posts by More Power!!
Billings MT
Joined Apr 2002
BTW= By The Way
Scott
More Power!! is offline Find More Posts by More Power!!
Old Oct 07, 2005, 11:08 AM
Happymcc is offline
Find More Posts by Happymcc
I USE CAPS - EYE TROUBLE
Happymcc's Avatar
Joined Aug 2004
Had to ask to make sure .
Flashing is the plastic that ozzes out of the mould when you make plastic
parts . This will bind if you dont remove it . VACaver took the head of his
Blade CP apart and scraped or cut with a #11 blade the flashing off the
head parts , and as he said
a ton of it
Happymcc is offline Find More Posts by Happymcc
Old Oct 07, 2005, 11:15 AM
mj147 is offline
Find More Posts by mj147
mj147's Avatar
MS
Joined Jul 2005
Here is an oldie but goodie:
If all else fails RTFM
mj147
mj147 is offline Find More Posts by mj147
Old Oct 07, 2005, 01:38 PM
mazakari is offline
Find More Posts by mazakari
Raptor 50 + TRex 450
mazakari's Avatar
Norwich UK
Joined Mar 2005
mj147
Read the 'fantastic' manual.
Jon
mazakari is offline Find More Posts by mazakari
Old Oct 28, 2008, 10:29 PM
heli_ebook is offline
Find More Posts by heli_ebook
heli_ebook's Avatar
Joined Apr 2006
Centripetal?
heli_ebook is offline Find More Posts by heli_ebook
Old Oct 29, 2008, 12:40 AM
Larry227 is offline
Find More Posts by Larry227
Larry227's Avatar
Canada, BC, Creston
Joined Jul 2008
On my HBFP I flipped the paddle control frame over so the grub screws that hold the flybar are on top.
Larry227 is offline Find More Posts by Larry227
Data EPP Sources, building tips, tricks, links and free plans leadfeather Foamies (Scratchbuilt) 1229 Mar 09, 2016 10:23 PM
Discussion 122 Tips and Tricks for building airplanes cracker39 The Builders Workshop 5 May 21, 2007 09:00 AM
Idea Building tips and tricks ( please post yours here AeroNut45 Australia 49 May 19, 2006 08:53 AM
Discussion Wing building tips, tricks, advice! toyotatruckin Flying Wings 42 Feb 18, 2006 05:23 PM
Simple 400 Building Tips? 99esq High Performance 4 Sep 10, 2001 07:07 PM
