Old Oct 04, 2005, 08:59 PM
LGM30F is offline
Find More Posts by LGM30F
Aduentes Fortuna Juvat
LGM30F's Avatar
Joined Jan 2005
That terrifying sound before the silence. Migrating my F27 guts to a new fuselage.
It took hundreds of flights and 4 months, but I critted out. With a brief lapse in situational awareness, I corkscrewed my stryker into the ground. Knowing the law of entropy, I picked up a replacement fuselage a few weeks ago.
Are there any tips I should know about building out the new fuselage? I'm interested in setting the powerplant angle of attack. Is there a limit to how much torque to put on the screws so not to damage the foam or affect the angle of attack for the prop? Are there any critical tolerances or settings to remember?
LGM30F is offline Find More Posts by LGM30F
Old Oct 04, 2005, 10:57 PM
crash test dummy is offline
Find More Posts by crash test dummy
Foamsmithing forever!!
crash test dummy's Avatar
Sugar Grove, Il.
Joined Aug 2004
Check out this thread. I can help you make your Stryker Stronger than almost anything in thr air. Read this thread and PM me back.
CTD
http://www.wattflyer.com/forums/showthread.php?t=507
crash test dummy is offline Find More Posts by crash test dummy
Old Oct 05, 2005, 08:11 AM
Brian Morris
Brian Morris
Guest
n/a Posts
Re: That terrifying sound before the silence. Migrating my F27 guts to a new fuselage.
"LGM30F" <LGM30F.1weskb@rcgroups.com> wrote in message
news:LGM30F.1weskb@rcgroups.com...
> a few weeks ago.
> LGM30F
Anyone knowing and understanding entropy should have no problem with mundane
subjects such as mounting an engine. :>)
Brian
"Diesels don't deadstick."--
Old Oct 05, 2005, 09:38 AM
LGM30F is offline
LGM30F's Avatar
Joined Jan 2005
Brian,
Thanks for your input.
LGM
Old Oct 05, 2005, 09:52 AM
LGM30F is offline
LGM30F's Avatar
Joined Jan 2005
CTD,
Thanks, great info.
In that post, Glacier Girl stated:
Before you fly check the side to side and front to back angles on your motor. From the rear, motor should be dead straight in line with the fuselage center line. If it isn't your bird will want to keep turning in one direction. Front to back alignment is critical to proper flight. Remove one tail fin, take a straight edge(a yard stick works well), line it up with the motor shaft back to front, if you follow that line it should exit at the center of the nose cone,from the side view. Off angles on this will cause the bird to want to climb badly on acceleration,the rear of the mount is too high vs the front. Or it will dive if the opposite exists. Your bird should fly level no matter what the throttle setting is.
This is the kind info I'm looking for. Other planes I have require an offset relation to the prop rotation. I wasn't sure this craft was the same. GG seems to have a wealth of knowledge and experience with the f27.
ETX
Old Oct 07, 2005, 12:11 AM
Frank Schwartz
Frank Schwartz
Guest
n/a Posts
Who said "NOSE CONE"???? Nose cones go on rockets....spinners go
onpropellors.... nose cone? Yechhhhhh....unless of course, it is a
pusher with a rounded nose...then I suppose you could call it a nose
cone...but I still think it is incorrect.
Frank Schwartz...
building and flying for over 70 years (I'll be 80 next month!!!)
Old Oct 07, 2005, 02:11 AM
Doug McLaren
Doug McLaren
Guest
n/a Posts
In article <4345ec5d.3432901@news.bna.bellsouth.net>,
.... and in fact, it is!
(And if you have e big enough motor and battery, it's very
rocket-esque
| then I suppose you could call it a nose cone...but I still think it
| is incorrect.
Incorrect or not, it's a popular term. Especially with the glider
guys, where there's often literally a nose that fits over the nose of
the plane. (Instead of a canopy or something similar.)
Woohoo! Where's the party?
Doug McLaren, dougmc@frenzy.com
`I was at the right place at the right time -- but then I realized
that I was not the right person!'
Old Oct 07, 2005, 05:28 PM
LGM30F is offline
LGM30F's Avatar
Joined Jan 2005
Frank,
I understood perfectly, but probably from my old occupation. Search the web for LGM30F and you'll understand.
Doug,
Thanks for having my back.
Old Oct 17, 2005, 04:12 AM
agpete
agpete
Guest
n/a Posts
Catfish Frank Schwartz from Nashville?
"LGM30F" <LGM30F.1wk1gb@rcgroups.com> wrote in message
news:LGM30F.1wk1gb@rcgroups.com...
> Frank,
> Doug,
> LGM30F
> LGM30F's Profile: http://www.rcgroups.com/forums/member.php?u=52607
> View this thread: http://www.rcgroups.com/forums/showthread.php?t=423998
Old Oct 20, 2005, 11:18 AM
LGM30F is offline
LGM30F's Avatar
Joined Jan 2005
No Agpete.
Do all Hacker motors have that distinctive sound? Mike C Electric Plane Talk 9 Jun 11, 2014 04:21 PM
How long do you fly a your model before you get bored and build/buy a new one? totalboss Electric Plane Talk 51 Jun 10, 2010 12:53 AM
Rave Before n After My new war bird P-51 Mustang(EPP) powder Slope 22 Aug 22, 2003 01:27 PM
Love that Spitty sound SchiessCo Electric Plane Talk 0 Jul 31, 2002 01:26 PM
my mates done it (new eco) Robin RUKDEC38 Electric Heli Talk 1 Sep 09, 2001 04:29 PM
