Old Oct 04, 2005, 05:25 PM
R Hudson is offline
Find More Posts by R Hudson
R Hudson's Avatar
United States, CO, Denver
Joined Dec 2002
Charging large NIMH packs in series?
I'm having a bit of a brain cramp, coupled with the fact that I have never charged more than one pack at a time before.
I have two 10-cell NIMH packs that I run in series to power an electric heli. I use a Y-connector so the batteries plug-in to the ESC separately.
My question is, if it is safe to run the packs in series this way, is it also safe to charge them the same way? So, rather than charging separately, charging them together as if they were just one larger pack.
Please help! My brain isn't working properly today!
R Hudson is offline Find More Posts by R Hudson
Old Oct 04, 2005, 05:44 PM
hermperez is offline
Find More Posts by hermperez
know it all
Miami, Fl
Joined Nov 2003
if both packs have the same capacity, and they have been discharged in series then they are ok for series charging.. never parallel charging. Charge in series at the 1C rate.
If the packs have always been used in series then they should have the same capacity.
Herm
hermperez is offline Find More Posts by hermperez
Old Oct 04, 2005, 08:08 PM
Cosmic is offline
Find More Posts by Cosmic
Cosmic's Avatar
Czech Republic, Plzeň Region, Město Touškov
Joined Feb 2002
Yep, no problem. I do the same with 3 x 10 cell GP3300 packs for my Funtana.
Cosmic is offline Find More Posts by Cosmic
Old Oct 05, 2005, 09:56 AM
R Hudson is offline
R Hudson's Avatar
Joined Dec 2002
Thanks guys!
I thought that you could, but I wasn't sure.
Up to this point, they haven't been used together, but I was thinking of discharging, then charging together very slowly at say, a .1C rate to balance the cells, then using them together regularly.
Does this make sense or is it a NO-NO?
Old Oct 05, 2005, 12:09 PM
know it all
Miami, Fl
Joined Nov 2003
it is a good idea to balance the cells occasionally in a pack, 0.1c for 24 hours.. both your packs may not have the same capacity, so if you plan to use them in series dont discharge them all the way.. always land with a 20% reserve.. that should prevent a pack or cell from frying. Only matched packs should be discharged near 100%.
I use a countdown timer from the kitchen section at walmart, I attach it to my Tx antenna with a clothes pin. I always land with a 20% reserve.
Both packs have approximately the same amount of cycles?
Herm
Old Oct 05, 2005, 02:06 PM
R Hudson is offline
R Hudson's Avatar
Joined Dec 2002
Yes, approximately the same cycles.
Also, am considering the same for two NICAD packs as well, same scenario.
Charging LiPo packs in series olly Batteries and Chargers 2 May 28, 2009 05:18 PM
Charging Large LiPoly Packs in Series? Brill 1 Batteries and Chargers 12 Apr 23, 2005 05:31 PM
Charging 2 packs in series with Supernova? Tram Batteries and Chargers 2 Oct 14, 2004 05:44 PM
charging 2 packs in series JerseyJerry Batteries and Chargers 4 Sep 05, 2004 10:29 PM
Charging packs in series Reco Power Systems 5 Jun 15, 2002 03:21 AM
